Question about Sony Cyber-shot DSC-S600 Digital Camera
The camera will not stay on
I need help with when I turn my camera on it comes on and goes right back off (just on and off) also the lens is out and won't go back in I have a DSC S600 Sony Cybershot Camera Thanks any help will help
  • bobbye50 Apr 29, 2009
    I have replaced the batteries that was the first thing I did. I wish that was the answer
That is because your battery is low
Posted on Apr 29, 2009
Panasonic DMC-ZS6 when in camera mode lens comes out and I get the message "Please turn camera off and then on again" when I turn off the lens just stays out.
There is an issue with the camera focus circuit in lens. That is why it is ok when you go into playback mode but negative when the lens is involved.
Aug 25, 2017 | Panasonic Cameras
THE LENS COMES OUT BUT GOES RIGHT BACK IN AND
I had the same problem. All I did was hold the lens out when it tun so that when it shuts off, the lens is still out. Then I moved it around a bit. Something was stuck in the lens and when I moved the lens around, it came out. So now it functions normally :] I hope I helped!
Jul 07, 2009 | Kodak EASYSHARE M1063 Digital Camera
The lens comes out then the camera turns off
Your camera has it own doctor built in, if it sees an internal error it will shut down. When a camera turns on it goes through a series of tests, if one of these test fails your camera records an error. If the lens is moving in and out your camera is trying to get the lens to function. As such you have a faulty camera.
Jul 02, 2009 | Kodak EASYSHARE M1063 Digital Camera
Fuji (A360) lens won't come out
Lens mechanism is jammed. Probably the counter wheel attached to the drive gear is hitting the sensor and stopping it from working, so will switch off. Needs a service
May 04, 2009 | Fuji FinePix A360 Digital Camera
Put camera on screen come on lens came out thwn power went off now power light wont stay on long enough lens wont go back in
maybe this works: turn your camera on in play mode (if you have play button press it to turn on camera) and if your camera hase a shoot-play switch select play mode and then turn your camera on.) repeat this until lens goes back. I hope this works...
Nov 01, 2008 | Samsung Cameras
Problem with lens
throw it on the floor again
IT WORKS!!!!! YYYYEEEEEEEEEEAAAAAAAAAAA
Jul 10, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Lens error!!!!
when i turn on my camera the lens comes out ,then goes back in saying theres a lens error.it tells me to restart my camera but im not sure how too. is it just turning it back on ,or is there a reset button?
Jul 03, 2008 | Canon PowerShot S5 IS Digital Camera
It wont stay on
the same thing happend to me just now... you have to wiggle the lens untill it goes into place then it should retract when you turn it on. :]
May 14, 2008 | Polaroid i531 Digital Camera
Camera won't stay on; date/time won't stay set
Are you sure the lens is actually going all the way out? If there is debris in the zoom gearing it can cause the lens to stop extending which would in turn cause the camera to re-retract the lens and show an error. Other possible explanations are that the sensor which determines when the lens has reached full extension has failed, so the camera keeps extending the lens until it reaches the physical limit - and then behaves just as if there was a jam as described above. The fact that this occurs both when you power on and power off the camera leads me to think this may be the case. The loss of date and time settings is due to a dead backup battery. Check your manual to see if this is replaceable by you or if it requires disassembly. David Millier Advance Camera Repair
Feb 17, 2007 | Nikon Coolpix 4300 Digital Camera
Sony Cyber-shot DSC-S600 Digital Camera Logo
229 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
