Question about Lexmark E332n Laser Printer
Factory Reset E332n Printer is hooked up to LAN . It has no interface to physically utilize on the printer such as a control panel where you can make changes therefore the only way to interface is once you have an IP for the printer utilize the GUI and make changes. When you push the print button on the printer to print out a printer setup page the printer gives you 0.0.0.0 for an IP address therefore it makes me believe someone has at sometime went into the GUI and unchecked DHCP enable and the printer will not aquire an IP address. My question is if it wont aquire an IP and you can't get to the GUI to change it because it has no IP then how are you supposed to reset the printer ? I tried looking it up in the manual for a factory reset and could not find anything other than hold in on the print button untill all lights flash however this does not work?
Remove printer drivers
Printer off.
Disconnect LAN.
Open front cover.
Hold/press both buttons on front, keep holding.
Turn on at back.
Only release button when all lights have stopped flashing, top and bottom light illuminated.
Close front cover
Connect LAN cable.
Reinstall via add network printer - will detect and reset new IP.
Posted on Apr 30, 2009
Reset brother mfc8880dn
If you wish to reset the print server back to its default factory settings (resetting all information such as the password and IP address information), please follow these steps. Before you factory reset the print server, we recommend that you print a configuration page before resetting the print server.
<For BRAdmin Professional ver.2.xx Users>
Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional Utilities => BRAdmin Professional.
  1. From the main BRAdmin screen double click the appropriate printer.
  2. Enter the print server password (The default password is "access").
  3. Click the Control tab
  4. Click the Restore Factory Defaults button
  5. Click the OK button when you have read the warning message.
  6. The print server will then reset back to its default values.
<For BRAdmin Professional ver.3.xx Users>
  1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional 3 => BRAdmin Professional 3.
  2. From the main BRAdmin screen double click the appropriate machine.
  3. Enter the print server password (The default password is "access").
  4. Click Network Configuration tab, Control Panel and select Set Default.
  5. Click on Submit button.
Via a web browser
Because web based management requires the TCP/IP protocol for communication, any reset option you see when managing the machine with a web browser, will not reset the IP address details that are set. If you wish to totally reset all the print server parameters we recommend you reset the print server by using the BRAdmin application.
To reset the print server (excluding TCP/IP parameters) follow these steps:
  1. Connect to the printer using a web browser.
  2. Click Network Configuration.
  3. Enter the print server password (the print server password is detailed in the user guide for the print server) if it's applicable.
  4. Click the Set Default link or Reset Print Server.
Via the control panel (only for network ready models)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN or Network and press Set, Menu/Set or OK.
  4. Press up or down navigation key to select Factory Reset or Network Reset and press Set, Menu/Set or OK.
  5. Select Reset.
  6. Select Yes.
  7. The machine will re-start, re-connect cables once this is complete.
Jun 19, 2014 | Brother Office Equipment & Supplies
E332n lights flashing error
We would need the secondary codes to get the root cause of the problem. Press the Continue button twice to get the secondary code.
Nov 20, 2012 | Lexmark E332n Laser Printer
My brother laser will not reset back to factory defaults
If you are using the printer in a LAN or Wireless LAN, you must assign to it an IP address compatible with your network. You do that by opening the Web admin interface of your router and assigning to the printer an address that is still free. Try 192.168.1.178 but that depends on the default gateway (192.168.1.1) that you defined for your router.
Aug 02, 2012 | Brother Office Equipment & Supplies
How to reset PC kit e332n
To reset the PC page count, while the printer is on, open front cover then press the cancel button.
NOTE: The photoconductor page count should be reset only when a brand-new photoconductor kit is installed. Resetting the page count without replacing the photoconductor kit could cause the photoconductor to operate beyond its intended life and thus create print quality issues.
Oct 01, 2010 | Lexmark E332n Laser Printer
Up wirelessly with my home network.My printer is showing as offline on my computer, how can i get it back online. I have it set
The BRAdmin Professional utility for Windows® is designed to manage your Brother network connected devices such as network-ready Multifunction devices and /or network-ready printers in a Local Area Network (LAN) environment. For more information on BRAdmin Professional, visit us at http://solutions.brother.com.
Installing the BRAdmin Professional configuration utility
1 Put the supplied CD-ROM into your CD-ROM drive. The opening screen will appear automatically. Follow the on-screen instructions.
2 Click Install Other Drivers or Utilities on the menu screen.
3 Click BRAdmin Professional and follow the on-screen instructions.
Setting your IP address, Subnet Mask and Gateway using BRAdmin Professional
2 Click Devices, then Search Active Devices. BRAdmin searches for new devices automatically.
3 Double-click the new device.
4 Enter the IP Address, Subnet Mask and Gateway, and then click OK.
5 The address information will be saved to the machine.
You can use the BRAdmin Professional utility to set a password. (See the Network User’s Guide on the CD-ROM.)
Start BRAdmin Professional, and choose TCP/IP.
Note
49
For Network Users
BRAdmin Light configuration utility (For Mac OS® X users)
The Brother BRAdmin Light software is a JavaTM application that is designed for the Apple Mac OS® X environment. It supports some of the features of the Windows BRAdmin Professional software. For example, using the BRAdmin Light software, you can change some network settings on Brother’s network ready printers and multifunction devices. The BRAdmin Light software will be installed automatically when you install the MFL-Pro Suite. Please refer to installing the driver and software in this Quick Setup Guide if you have not yet installed the MFL-Pro Suite. For more information on BRAdmin Light, visit us at http://solutions.brother.com.
Setting your IP address, Subnet Mask and Gateway using BRAdmin Light
If you have a DHCP/BOOTP/RARP server in your network, you don’t have to do the following operation. The print server will automatically obtain its own IP address. Make sure that version 1.4.1_07 or later of JavaTM client software is installed on your computer.
1 Double-click the Macintosh HD icon on your desktop.
2 Choose Library, Printers, Brother and then Utilities.
3 Double-click the BRAdmin Light.jar file. Run the BRAdmin Light software. BRAdmin Light searches for new devices automatically.
4 Double-click the new device.
5 Enter the IP Address, Subnet Mask and Gateway, and then click OK.
6 The address information will be saved to the machine.
Note
50
For Network Users
How to set the machine’s network settings to wireless
Restoring the network settings to factory default
LAN or wired LAN
To connect your Brother machine to a wireless or wired network you must configure the machine from the machine’s control panel for the network type you are using.
For wireless LAN On your machine, press Menu. Press a or b to choose LAN and press OK. Press a or b to choose Network I/F and press OK. Press a or b to choose WLAN and press OK. The wired network interface will become inactive with this setting. Press Stop/Exit.
It will take about a minute for the LAN menu on the LCD to become available again.
For wired LAN On your machine, press Menu. Press a or b to choose LAN and press OK. Press a or b to choose Network I/F and press OK. Press a or b to choose Wired LAN and press OK. The wireless network interface will become inactive with this setting. Press Stop/Exit.
To restore all network settings of the internal Print/Scan server to factory default, please follow the steps below.
1 Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
2 Press Menu. 3 Press a or b to choose LAN.
Press OK. 4 Press a or b to choose Factory Reset.
Press OK. 5 Press 1 to select Yes. 6 Press 1 to select Reboot.
7 The machine will restart, re-connect cables once this is complete.
Apr 29, 2010 | Brother MFC-665CW All-In-One InkJet...
How can I restore factory setting in Lexmark E332n laser printer? I think i messed up when i tried to configure a new ip adress in the menu config and i removed the DHCP option!
turn off the printer open the front cover press and hold the continue button turn on the printer once the error light is solid release the continue button close the front cover. press the cancel button once to turn on the continue button light, press and hold the continue button untill all of the lights cycle to perform nvram reset. then press and hold the cancel button to return to home turn th printer off then back on. should fix your problem
Nov 25, 2009 | Lexmark E332n Laser Printer
How do I take a meter reading on a Canon IR2270? Alan
Hi mate ,
It seem that u are in daze.I can assist u ,physically u can go to the machine and focus at the control panel keys and lookout for counter button on right side ,activate it by pressing it .Counter will display on panel mate good luck.Or esle ,if your machine hook up on lan network u basically can view it on remote user interface by keying the ip address for example : http://192.168.1.10 at machine on internet explorer .
Thank & best regard
Aerist01
Rate me pls!!!!!!
Nov 11, 2009 | Canon Office Equipment & Supplies
I would like to know how to reset the Lexmark E260dn to factory defaults. The printer was set with a static IP address and no longer exists on THAT network. I need to set it up as a DHCP client again to...
Restoring the factory default settings
Do one of the following:
• If your printer is on a network, access the Embedded Web Server:
1 Type the printer IP address into the address field of your Web browser.
Note: If you do not know the IP address of the printer, print a network setup page and locate the IP address in the TCP/IP section.
2 From the Settings screen, click General Settings.
3 Under Factory Defaults, select Restore Now, and then click Submit.
• If your printer is connected to a computer by a USB or parallel cable, use the Local Printer Settings Utility for Windows or Printer Settings for Macintosh.
1 Open the utility.
2 Do one of the following:
– From the Local Printer Settings Utility menu bar, click Actions Restore Factory Defaults.
– From Printer Settings, click Factory Defaults.
Warning—Potential Damage: Restore Factory Defaults returns all printer settings to the factory default settings except Network/Port menu settings. All downloads stored in RAM are deleted. Downloads stored in flash memory or on a printer hard disk are not affected.
Or please download the user guide from this link and follow the instructions
http://static.tigerdirect.ca/pdf/Lexmark-E260D-Series-Mono-Laser-Printer-Manual.pdf
Hope this will help you
thanks
Oct 01, 2009 | Lexmark E260dn Laser Printer
How to reset to factory default Dell 1720 network printer
1. Turn off the printer
2. Open the front cover.
3. While the Continue and Cancel buttons are depressed, turn the printer on.
4. When the error LED on the control panel is lit solid, close the cover.
Jul 28, 2009 | Dell 1710n Laser Printer
My hp 4250 printer makes multiple config sheets,,its set to the default of 1 copy (s)
Please perform Cold Reset and then upgrade the firwmare of the printer
HP LaserJet 4250 and 4350 Series Printers - Performing a Cold Reset NOTE: The Jetdirect LAN (such as the IP address of the printer) settings will be reset to defaults by this operation. Record LAN settings before resetting the printer. Reconfigure LAN settings after the reset if you are using a LAN connection). To avoid resetting the LAN settings disable the embedded Jetdirect before performing a Cold Reset by choosing the Disable LAN option from the choices available when you get to step 5 below. Note that after choosing to disable the LAN it is necessary to reboot the printer and then choose to perform the Cold Reset . During the power up sequence only one operation can be performed at a time. In this case, first disable the LAN, then reboot the printer and perform the Cold Reset followed by another reboot to reenable the LAN.
To perform a cold reset:
  1. Turn the printer power off.
  2. Power on the printer and watch for the memory count to begin.
  3. Hold down the SELECT (Checkmark) button, when you see the memory count begin.
  4. Continue holding down the SELECT (Checkmark) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
  5. After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until COLD RESET appears on the display
  6. Press the SELECT (Checkmark) button. The printer performs a cold reset and then continues its power-on sequence.
  7. Check all I/O settings and reset any user-set printer configuration values. NOTE: Before the I/O (LAN) settings can be reset to their correct values the embedded Jetdirect must first be renabled to make those options visible and available on the control panel of the printer. Renable it in the control panel settings then reset them to their correct values.
Link to download firmware:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=412144&prodNameId=412158&swEnvOID=54&swLang=8&mode=2&taskId=135&swItem=lj-25065-14
Steps to upgrade:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=412144&swItem=lj-25065-14&prodNameId=412158&swEnvOID=54&swLang=8&taskId=135&mode=4&idx=3
Rgds,
Nikhil
Jul 21, 2009 | HP LaserJet 4250n Printer
Lexmark E332n Laser Printer Logo
1,653 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
