Question about Acer Aspire One Netbook 8.9" Notebook
Network boot.... realtek pxe bo1 doo - Acer Aspire One Netbook 8.9" Notebook
5 Suggested Answers
leecom72
  • 4806 Answers
SOURCE: realtek media test failed check cable pxe exiting flashing
As the computer starts hit F2 to get you into the bios, look for boot options and set the HDD (hard disk drive) to the first boot device, hit F10, save the changes and exit the bios. The computer will restart and should boot from the hard drive. If it doesn't go back into the bios and look to see if the drive is recognized in the main page of the bios.
If the hard drive is not there then there could be a chance that the hard drive has failed.
Please let me know how you get on and if you need any further assistance.
Good luck.
Posted on Aug 26, 2009
  • 10 Answers
SOURCE: PXE-E61 media test failure on Acer Aspire 5050 laptop
Yes, your analysis of the problem is correct. The problem could be with the hardware & while you are trying to reinstall the Windows OS, the software checks on all hardwares before installing. The best solution would be to take your system to a nearest service provider & get the problem rectified. Once the problem is rectified by them, try to reinstall the OS along with them, so that if there is any other problem apart from the above they will be able to help you.
Posted on Feb 08, 2010
Testimonial: "Prompt and clear reply, highly recommended! Thanks! "
  • 212 Answers
SOURCE: My acer is saying that
From your explanation, it looks like the laptop is trying to boot from a network source. Restart your computer and press F2 or Del when booting to go into the system BIOS. In the BIOS, locate the boot order, or boot sequence. There should be Booting devices listed in a numerical order, so what you have to do is, read the instruction at the bottom of the page (still in the BIOS) to see what keys to press in order to change the booting order. (Usually its (- or +) or (Page up and Page down) or anything like that...
Make sure that when you change the boot order in the BIOS, your Hard disk should be the first one. This will tell the computer to boot from your Hard disk and not from the network source... try that, it should solve you out of that problem
Posted on Aug 09, 2011
lamont1900
  • 10 Answers
SOURCE: Intel UNDI, PXE-2.0 (build 082) Copyright (C) 1997-2000 Intel Corporation
It happened to me twice and the solution is very simple: have a Gateway T6524 with 2 Hard Drives and XP SP3 (HD0 has the system on C and D partition, and HD1 is for backup). The first time the error happened is after a windows update and the second time was after I installed the neat receipt software and I had to reboot because it was stuck. So basically, the solution that worked for me was to disconnect HD1 and reboot. Problem fixed! I reconnected HD1 later on (after shutdown of course), and making sure that the BIOS was properly setup in regard to boot sequence for Hard Drives.
Posted on Jan 02, 2013
Hello, My laptop shows the following message when I turn it on- Realtek PCIe FE Family controller Series v1.19(08/10/09) PXE-EGI-Media test failure,check cable PXE-MOF-Exiting PXE ROM Reboot an
It can't locate a working boot disc. Most likely lost communications with hard drive. Look in BIOS again to see it recognizes the drive. If not try re-seating / reconnecting drive.
Feb 16, 2013 | Dell Inspiron N5010 Black
I need help with something. My eMachines D520 laptop will not boot up. Here is what the message says:Intel UNDI, PXE-2.1 (build 082) Copyright (C) 1997-2000 Intel Corporation For Realtek RTL8111B/8111C...
Your machine is trying to boot off a network (PXE). Either you stole it from work, or the bios is not set up right and / or the hard disc is either no good or the cable is disconnected from it. The boot sequence in BIOS should tell it to not boot from the network first, unless it's on a corporate network. It should say boot from the hard drive first. If it's set to do that and it fails, then your hard drive is probably bad. Dropping a laptop on the ground will do that; did you loan it out, recently???
Sep 27, 2011 | Computers & Internet
When I turn on the PC the following message appears and my system goes turn off... For Realtek RTL8101E/8102E PCI-E Ethernet Controller v2.13 PXE-E61: Media test failure, check cable PXE-M0F: Exiting...
This error occurs when the BIOS finds no hard disk drive to boot from, and tries and fails at booting thru the network jack (PXE Boot is a network boot used in large corporations, usually to image a system.)
Reseat the hard disk drive in the system, then reset the bios defaults and see if the system will boot normally. You can also try running diagnostics (Fn + Power on a Dell)
Most likely scenario is that the hard disk drive has failed and you will need to replace it.
Jul 15, 2011 | Computers & Internet
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
WILL NOT LOAD OPERATING SYSTEM. ERROR AS FOLLOWS. For Realtek RTL8101E/8102E PC-E Ethernet Controller v1.08 (080408) PXE-61: MEDIA test failure, check cable PXE-MOF: Exiting PXE ROM. Operating System...
It sounds like it's trying to boot from a network. Did you change the boot start up in the BIOS? If not then it's trying to boot from the Ethernet port because your hard drive is not being detected or your software is corrupted.
Feb 10, 2011 | Dell Inspiron Mini 10 Notebook
Intel UNDI, PXE-2.0 (build 082) Copyright (C) 1997-2000 Intel Corporation For Realtek RTL8139(X)/8130/810X PCI Fast Ethernet Controller v2.13 (020326) PXE-E61: Media test failure, check...
You probably have the bios set to boot from a network, instead of the hard drive.
Find out how to get into your bios as the computer is booting (maybe F8, maybe ctrl-s?) then change the boot order to HD first, followed ny C D-ROM, followed by floppy, then network LAST.
FiOS-Dave
Aug 15, 2010 | Computers & Internet
I keep getting intel undi pxe-2.1(build 0892) copyright (c) 1997-2000 intel corporation for realtek rtl8100/8101e fast ethernet network adapter v1.02 (060510) pxe-e61 media test failure check cable...
Your laptop is trying to boot via LAN(network). Possible the HDD is not being detected by your system that is why it could not boot to windows. Try to boot up without the ethernet (your internet cable) connected to it and see if it works. If not, you may have a bad HDD.
Hope this helps.
Dec 19, 2009 | Toshiba Satellite A135-S2276 Notebook
My aspire 5315 laptop is stuck on this sceen, broadcom undi pxe 2.1 v10.0.9 copyright (c) 2000-2006 broadcom coporation copyright (c) 1997-2000 intel corporation all right reserved. pxe-e61: media test...
Hello higgstwiligh,
The above message is mainly informational and doesn't necessarily indicate a problem. The acronym 'PXE' stands for Preboot Execution Environment. It's an environment to bootstrap computers using a network interface card. Usually the reboot is done by a remote computer on a LAN (Local rea Network). The Realtek NIC (Network Interface Card) somehow expected a PXE boot to be taking place when the computer was restarting. One solution is to restart the computer and go to the boot menu (F2 on some systems) and choose to boot from the master drive.
*Here's a link to a good article explaining what PXE is: http://www.search.com/reference/Preboot_Execution_Environment
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Nov 01, 2009 | Acer Aspire 5315 Notebook
Realtek rtl8139 (X)/8130/810X PCI FAST ETHERNET CONTROLER V2.13 020326. PXE-E61 MEDIA TEST FAILED CK CABLE AND PXE-MOF EXITING FLASHING CANNOT DO A RESET WITH F9
Hello khulsey60,
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jul 30, 2009 | Acer Aspire 5100 Notebook
Upon booting I get this error. for realtek
PXE means Pre-Boot Execution Environment. You see this message when the laptop trying to boot from a remote server using the network card. If you didn’t see the PXE-E61 message before, it means that the network card was listed after the hard drive in the boot order (you can set the order in BIOS) and the laptop booted directly from the hard drive. Now, when the hard drive has failed, the laptop cannot detect it and tries to boot from the next available device – the network card. Your laptop is not configured to boot from a remote server using the network card, that’s why you are getting PXE-E61 Media test failure error.
You have to replace the hard drive and reinstall the operating system?
Jul 09, 2009 | Toshiba Satellite P205-S747 PC Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
666 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
