Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool Ultimate Care II LSQ9549L does not always spin
This does not happens all the time but from time to time it will not spin during the spin cycle. It sounds like it's draining but nothing more happens. If I open up the lid and close it when it's happening, it will start spinning. If I manually start the spin cycle it's spinning whithout any problems.
  • 2 more comments
  • susaninbama Nov 08, 2007
    I have the same problem, my Ultimate Care doesnt spin all of the time. We will try replacing the timer to see if that fixes the problem. Is changing out the timer something I can do or do I need to call a tech?
  • Anonymous Jan 04, 2008
    does not spin cycle
  • Grantzilla85 Jan 07, 2008
    How do I go out fxing the gears in the middle spinner. It sounds like they are ground down so it wont spin very well. Also where could i find these parts?
  • Anonymous Jun 17, 2008
    The washer works great until it gets to the spin cycle and then quits?
  • 248 Answers
This unit has a neutral drain transmission. When it first goes to spin it will drain without spinning to ease load on motor. It will then pause motor and when it restarts it then spins.
You probably have a bad timer that is not pausing the motor. Monitor washer from the start of spin cycle to end to see if it pauses then starts again. If not, replace timer.
Posted on Nov 08, 2007
    New Friend:
I will tray , thanks for it..
Posted on Dec 19, 2009
  • 3 Answers
Look at
http://applianceguru.com/forum2/5958.html#
the problem seems to be very different from a timer problem.  I have the same problem and the drive block is what I want to look at first
Posted on Jul 05, 2008
Is it hard to change the timer
Posted on Dec 31, 2007
3 Suggested Answers
SOURCE:
  • 530 Answers
SOURCE: Whirlpool Ultimate Care II LSQ9549L - leaking water
about $60.00 depending where you live
Posted on Jan 04, 2009
  • 311 Answers
SOURCE: Whirlpool Ultimate Care will not stop spinning
I work on these every day for the past 8 years and have never once seen this problem. If i had to guess i would assume its a stuck contact on the timer. The timer is the only thing that sends power down to the motor but its an expensive guess.
Hope this helps _MJ_
Posted on Jan 29, 2010
Doesn't always spin out at the end of the wash and rise cycles.
sounds like a touchy lid safety switch that works for a while and then quits,its under the top cover and is activated by the lid plunger tab
Jul 25, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Jan 29, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin cycle doesn't spin
you nead to check the door switch,nead to know the mod# to know what type of door switch you have.
Dec 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine rocks very hard during the spin
If the machine is not on a very stable surface...such as concrete....this can happen particularly if the machine is now on a timber floor. The floor literally vibrates in sympathy with the machine.
If however this is the same machine now showing this on the same surface then either something has come adrift inside or the stabilising in it has failed in some way or it has a bent main shaft in which case you will need a Techo service call.
Oct 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate care 2 (ABOUT 4 YEARS OLD)
Sounds like the clutch is slipping but sometime catching. Or maybe the transmission is almost gone. Is there a burning smell? If so, probably clutch.
Apr 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
555 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
