Question about Philips 20PT6441 20" TV
PHILIPS 319753 - Philips 20PT6441 20" TV
I have a philip tv the modle is 14HT3304/01 i can't get to my menu i was using 319753+mute the menu is not displaying so i need code to unlock it please help
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Jun 05, 2015 | Televison & Video
Phillips hotel mode 319753
replace the memory of ur unit, if not you should look for the power source of the memory and hang it off by removing the lead make sure that it does not contact the board.
Sep 22, 2013 | Philips 20PT6441 20" TV
How can i unlock Phillips 26" LCD TV 26HF5443/97
Using a universal remote with numeric keys, input this code->319753 and press mute. This has to be done quickly, and the channels will change, but ignore that.
Use navigation keys to change the settings.
If it's in High security mode, then you are pretty screwed, unless you can find the green Master remote which has a few more functions.
If in Standard mode, then a universal should be fine.
It took me DAYS to find all this out, since I just picked one up last week, and I had the same problem.
I had to use 2 remotes to do it though, since my universal is old and clunky, but I had an old Philips multi remote for a video player as well, which accepted the direction buttons ;)
Hope that helped. If it's been solved for you, it's ok, since there might be others out there with these model of ex-hospitality(hotel) TV's.
Cheers from New Zealand!
Aug 11, 2012 | Philips Televison & Video
Cant unlock tv because the code 319753 mute is no longer working
Hello
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Aug 01, 2011 | Philips 20PT6441 20" TV
I purchased a used Phillips TV 30PW8502/37. How do I disconnect the autolock feature when I do not know the Access Code?
the code for this tv is as follow press and hold stdby and mute at same time then key in 319753 then press mute this lets you into the menu. these tvs where set up for hotel use but can be set up for as other.
Nov 27, 2010 | Philips Televison & Video
How can i unlock philips hotel tv 21ht3302/41? -to play dvds
use av1, av2 , for tuning tv- use following sequence of commands on remote hand set
319753 mute
Jun 30, 2009 | Philips 20PT6441 20" TV
hey pls help me.. I have this Tv and igit buttons 3,1,9,7,5,3
and the mute button was worked.
but recently
above code doesn't work,as i remeber I put high security in menu.but What can i do now,please help me.
please...
raveendramax@gmail.com
Aug 14, 2008 | Philips 20PT6441 20" TV
Hotel TV remote
for phillips tvs that come out of a hotel try this code with RCA universal remote. the big remote not a small remote. 319753 followed immediately by the mute button. this will pull up the tv setup menu.
Jul 31, 2008 | Philips Magnavox REM-350 Remote Control
Philips 20PT6441 20" TV Logo
20 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
