Question about US Logic DVD800P Portable DVD Player
How do i clean the laser head - US Logic DVD800P Portable DVD Player
Printing blank pages
Hi, it might be the laser head is faulty or hvps is faulty. Try do an test print from the printer by press and hold the buttun for 5 sec or so. If it doesn't print. Try to clean the laser head which is able to be found under the printer with 3 screw. Do not power on the printer and look at the laser head this might cause blindness. After clean place back the laser head and test print. If same issue, try with a new sets of toner. If this still don't work you have to engage an technicians to either replace the laser head or hvps.
Oct 13, 2013 | Samsung CLP320 AllInOne Laser Printer
Whats a laser-head cleaning disc
this laser head cleaning disk, is for to clean the system Pickup Head from a CD +DVD. The eye from player is very critical , the laser Will not READ any information from the CD is there are dirty.They have another purpose for to adjust the audio system, speakers,etc.
SEE the photo.
Feb 09, 2013 | Televison & Video
My dvd cant read dvd but can read cd
Your laser head needs eighter cleaning or replacement.
Use a cleaning CD with solution to clean your Laser head.
if problem still exists you have to do a better cleaning by opening the DVD ram and use ear buttonetes with alcohol (a little alcohol dont flood the buttonete).
If still exist you have to replace the laser head, mostly is more expensive than buing a new DVD.
Jul 29, 2011 | Computers & Internet
I have a del studio 15 ....dvd writer is buil in..........when i insert any cd its reading as blank cd.........when i try to acces through MSDOS.....error pops as incorrect function
This is due to dusty or failed Laser head inside the drive. Try cleaning the Laser head with a soft cleaning cloth or with a cleaning kit. If it still does'nt work, that means, its failed. In that case, you may require an external CD/DVD writer, because, Laser head replacement cost would be more than external CD/DVD writer.
Good Luck.
Dec 19, 2010 | Dell Computers & Internet
When I go to play a dvd, a clicking noise is heard and the movie will stop playing. With some dvds I cannot play them all as the noise begins immediately. What can I do???
Sounds like the laser head that reads the disk is getting lost and trying to search for the track. This is often caused by a dirty laser head or dirty disks, try using a cleaner disk (available at Wal-Mart or just about anywhere) Follow the package instructions and clean the laser head see if that cures it.
Sep 15, 2009 | Emerson EWD2203 DVD Player/VCR
My ps3 will not read any games or movies what can i do
Hi, it seems like the DVD’s laser head may need cleaning. For this operation you will have to use a DVD head cleaning kit.
Regards
Muzzi_123
Jul 09, 2009 | Sony Playstation 3 (PS3) Console
How do I clean print heads re Epson Aculaser c900
you can clean print head unit
first remove opc and transfer belt ,then move front cover,then rmove
the Drum Unit Slide Cover,then
Remove the Laser Lens Cover.
now you can see printhead unit .Clean it and its ok.
Jun 07, 2009 | Epson AcuLaser C1900 Printer
Shows "Loading" but won't play
You can try cleaning the laser head and drive carriage. Clean the laser head with cotton swabs and small amount of isopropyl alcohol.Rub the swab back and forth across the head of the laser, do not apply to much pressure or you knock the laser out of alignment.Check the carriage, clean the the guide rails and check the belts and gears. All should be cleaned and checked to see if still in functional condition. if all this does not help you with your problem ,then the laser unit has probably weaken through age and can no longer function properly. Hope this helps you with your problem.
May 15, 2009 | Cyberhome CH-DVD 300 DVD Player
Won't read dvd's
hi try first to clean up your laser sense with a clean up CD, after if your problem is still there, you have to go to specialist cause your laser sense is defficient, and used and have to be replaced, maybe the best thing to do is to buy a new DVD player.
you have to know that a laser sense has a limited life and it's normal to change it after aproximatly 2000 hours.
I hope this helps
Please rate accordingly
Thank You
sserpentio
May 11, 2008 | Panasonic DMR-E80H DVD Recorder
US Logic DVD800P Portable DVD Player Logo
15 people viewed this question
Top US Logic Televison & Video Experts
jscuin6
Jesse Garza
Are you an US Logic Televison and Video Expert? Answer questions, earn points and help others
