Question about Magellan RoadMate 700 GPS Receiver
My Magellan 3511 gps does not get a satellite signal
SOURCE: Problem with Magellan GPS 315
I own Two Magellan 315. They both have failed in exactly the same way as yours, will not lock on too a satillite. I have concluded that this is their design life and that is the end. I did post one to the Magillan repair centre in France but that disappeared. I have replaced the two of them from EBay and will see how I get on with those
Posted on Jul 25, 2007
SOURCE: Unit will not acquire the satellite signs
FYI ....My Roadmate 760 would not aquire a signal, I went to diagnostic screen and found it was detecting/tracking 0/0 satellites. Held the plugged in unit out the window and within 10 seconds was tracking 7 satellites! Turned out my 1999 Olds Silhouette Van has a anti-glare filter inside the factory windshield that blocks GPS signals.My wifes 2001 Chevy Impala also has same type filter. Check your windshield, filter is visible inside glass to within about three inches of edges of glass. Worth a look.
Posted on Jan 30, 2008
SOURCE: magellan 760 no satellite signal
I got a Roadmate 760 from my employer to use. It won't pick up my current location and is not working right. Help!
Posted on Aug 18, 2008
  • 1111 Answers
SOURCE: Magellan Roadmate 2000.. No GPS signals
make sure the battery is charged up good, then take it outside and turn it on and leave it in clear view of the open sky for up to 30 minutes to acquire the satellites especially if its been reset.
if that fails, reset the unit...turn it on, then locate the reset button on the left side bottom of the gps and use a paper clip to depress the reset switch...it should restart on its own..take it back outside and let it in clear view of the open sky for up to 30 minutes.
if that fails..go HERE and get the update and follow the instructions..you will have to sign on to the Magellan site before you can download anything.
if you need more help, just post back
bill
Posted on Jul 18, 2010
  • 1111 Answers
SOURCE: The gps is a magellan RoadMate 2000. It does not
hi foxylady0415,
try and run the update and make sure its fully charged and try again...you can get the update HERE
download and follow the directions exactly, and make sure the batery is either fully charged or the gps is plugged in to a good charger.
let me know if you need further help
Bill
Standing Member of G.O.T.
Posted on Nov 16, 2010
No signal
Your GPS is defective. Contact Magellan for repair return instructions.
Nov 05, 2012 | Magellan Maestro 4700 Car GPS Receiver
Magellan Roadmate 1412 won't track satellites
It might mean that the signal is disrupted. Might be a software glitch. Try going outside, get a clear view of the sky. Then reboot/reset the unit. Hold the switch to the reset position or off position for 10 seconds, it will shut off. then switch it back on. It should reacquire a signal within 2-5 minutes, then it will fix on your position. If that doesn't work, try updating your software. Call Magellan Tech Support for instructions.
Dec 29, 2011 | Magellan RoadMate 1412 Car GPS Receiver
Magellan Roadmate 2036-mu will not find satellite signal at all. It straight out of the box. tried having it in clear view of the sky, and still nothing. Any suggestions?
Slide the power switch to turn it OFF and hold it in that position for about 20 secs or more. Release the switch and now restart the GPS by sliding the power switch again. The GPS should start up and start searching for satellites.
Feb 06, 2011 | Magellan 2036 GPS Receiver
With the GPS turned ON; slide the power switch to turn it OFF and continue to hold it for another 20+ secs. Release the switch and restart the GPS. It should try to locate the satellites, if it still is not able to find after reset then this could be a hardware problem with the GPS.
Feb 04, 2011 | Magellan 2036 GPS Receiver
Does not pick up satellite signals
The gps device is not receiving signal simply because the strength to receive signal is weak. What you have to do is to reset the gps device by holding the power button for about 15 seconds or there about, then you release it when the gps restarts. It will acquire signal after resetting the device.If it does not acquire satellite signal. You can also try to use the gps in an open space where the gps will be facing the sky, if it does not, then you replace the antenna of the gps device.
Hope this information helped.
Jan 01, 2011 | Magellan GPS 320 GPS Receiver
Magellan Maestro 3225 signal is no longer working. No satellite for navigation.
Look in the back. There is a small rubber cap on top of the external antenna hookup. Remove the rubber cap with a pin and hookup a long wire on the middle. That should amplify the signal.
Sep 13, 2009 | Magellan Maestro 3225 Car GPS Receiver
Magellan roadmap 760
The Magellan 760 has been around for a few years now, and unfortunately, isn't one of the fastest units around when it comes to synchronizing to a satellite. I find with mine that the time it takes to lock onto a signal depends on several factors:
1) Having the GPS mounted in a way that allows the antenna to have a clear view upward 2) Having my vehicle in the open, so that the signal isn't impaired by adjacent buildings, overhanging trees, etc. 3) Being stationary while the GPS attempts to get a lock. It has more problems locking while moving. 4) Ensuring that the GPS is used frequently, as it loses its memory of what satellites it's synchronized with if you happen to be in a different place when you turn it on than the place you were at when you last turned it off.
Those last two points have the most affect on my GPS's performance. I find that by turning on the GPS and just parking in my driveway or parking lot for a few minutes will allow the GPS to acquire a signal in a much shorter time than if I start to drive immediately. While this will waste a bit of time on the front end, it does help you get synchronized more quickly
May 27, 2009 | Magellan Roadmate 760 GPS Receiver
Magellan 760 no satellite signal
Jun 14, 2008 | Magellan Roadmate 760 GPS Receiver
All navigation units are GPS Receivers - that is - they receive satellite signals. So, no there is no difference.
Apr 19, 2008 | Magellan RoadMate 700 GPS Receiver
Dec 29, 2007 | Magellan Roadmate 760 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
