Question about Dryers
Whirlpool duet dryer
I put a load of clothes in dryer and they did not dry..The dryer works but does not dry clothes.
    Sergeant:
  • 206 Answers
Run the dryer for 2-5 minutes. Check to see if it has heat inside. If not, you have an internal problem.
If heat is generated, check your dryer lint trap. It must be clean before every dry cycle to dry properly and efficently. If the trap is clean and heat is generated, check the tubes behind the dryer for disposing of the lint.
Posted on Oct 15, 2013
  • 36 Answers
SOURCE: Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Posted on Dec 16, 2008
  • 14 Answers
SOURCE: my Whirlpool duet dryer is getting too hot
YOU NEED A NEW THRMO KIT
STEVE'S APPLIANCE
516-300-3249
Posted on Apr 06, 2009
  • 66 Answers
SOURCE: Whirlpool Duet dryer not drying like it used to
If your duet isn't heating properly and you have taken care of the lint problem then you could have one of two problems. Either you have a bad heating element or you have a bad fuse or temperature sensor.
If your dryer is not heating at all then it is most likely the fuse or temp sensor. If it is heating and just not enough it is probably a bad heating element.
Both problems would require a repairman to come and fix normally, however if you believe it is the heating element that can usually be replaced by the homeowner without too much trouble. Just make sure to ask where it is located from whatever place you but the new element from.
Posted on Dec 12, 2009
heatman101
  • 43501 Answers
SOURCE: whirlpool duet GEW9250PW1 electric dryer squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Apr 06, 2010
Testimonial: "Thanks, so now how do I get the extended warranty plan to pay for it. They will not send someone out for squeaks and squeals. "
  • 156 Answers
SOURCE: Whirlpool Duet Dryer, Dampness sensing only partially working.
inside dryer there is 2 metal strips clean tham off with a eraser if that dont cure it make sure vent clean going out of your home if both are done and still does it depends on dryer if its a sencer are control board
Posted on Jun 03, 2010
My whirlpool duet dryer works but it appears that the air is not evacuating from the baril. The heat and humidity built up and the clothes don't dry. Do I need to replace the fan and if so, how
YOU NEED TO CLEAN THE VENT ON YOUR HOUSE IF THE BLOWER WHEEL IS BAD ON THE DRYER YOU WOULD HERE THE NOISE AFTER THE DRY STOPS THE BLOWER WHEEL WILL STILL TURN AND MAKE A NOISE
Oct 29, 2012 | Whirlpool Duet Steam WFW9700V Front Load...
Whirl pool duet dryer not drying clothes
Inside the door under the filter housing is 2 strips that sense wetness. If they have dryer sheet goop on them they won't sense moisture. the dryer will therefore thank them clothes is dry. Clean them sensors with windex and party on!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Dryer front load leaks water underneath the dryer when drying heavy duty clothes
The clothes then are too wet for the heat to evaporate. Spin extra time to get rid of as much water as possible before putting them in dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Just dried a load of clothes and every thing worked fine. Put in another load to dry and says it is sensing. Nothing else happens
Here's a quick thing to try. Unplug the dryer, wait a minute and plug it back in. Try drying the clothes again. If this doesn't work, you will require troubleshooting from one of the category experts for dryers. Good luck.
May 16, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My Whirlpool duet dryer is getting too hot
STEVE'S APPLIANCE
516-300-3249
Mar 15, 2009 | Whirlpool LER5636P Electric Dryer
Dryer not drying
look at the vent outside and see if it closing or even has a cover this allows cold air inside the dryer and cause it to take longer to dry
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet dryer is taking 3 cycles to dry????
have you checked your lint trap to make sure that it is clean after every load? Also the lint vent to the outside may be clogged and will not let the dryer vent like it should. This is dangerous. So check and replace if needed.
Dec 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Order in clothes
Put a half a cup of vinegar into wash load, with soap. It removes the smells.
Jan 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
188 people viewed this question
Top Dryers Experts
