Question about RCA L32HD41 LCD TV
TV will no recognize or pick up digital channels
My tv only picks up ditial channels. how can I get the other channels
I don't understand your question, are you saying it only picks up the digital channels but nothing else? There is no analog channels anymore, so there is only digital to pick up!
Jan 01, 2018 | Televison & Video
I dont have a remote and im trying to set up a digital tv antenna but the only channels im getting is 3 and all the video inputs. How to i program channels
Usually channel 3 is picked up on a channel scan when there is an input device connected to the TV via a Coaxial Cable, thus using only channel 3 on the TV itself and using the Digital converter box to tune in the channels.
The TV will need to be Digital ready to connect only a Digital Antenna to it and programmed to receive the Digital Broadcasts over the air. If you are certain that this TV is Digital Ready (TV manufactured from 2009 to the present) you can use the menu button on the top, side, or front of the television, then use the channel / volume buttons to move around the menu, and the input button as the enter button.
You will want to select Antenna (ATSC) signal before starting the auto program so the TV will be able to recognize the Digital Channel Broadcasts.
Hope this helps!
Cheers,
Scott
Apr 12, 2015 | Televison & Video
Cant get channel 11 when i hook my converter box to this tv is there a way i can i get regular tv without it
No,if this tv is an analog tv mean tv have a big back cover and have a heavy CRT-(tv tube).Must have a good antena like a digital antena or move antena around to left or right to pick up channel 11,might lost some other channels than.This tv now can't pick up digital signal now without the tv converter box if u want to pick up free DTV air broadcasting tv signal,it all broadcasting in DTV free air in all digital now.
Apr 14, 2011 | Apex Digital AT2402 24" TV
My digital tv will only pick channel 10, abc and sbs, even though it used to pick all channels?
U trying to pick up all free AIR DTV tv stations wright?Yes.This problems u have a weak airial antena.Buy a better antena like a Digital antena or a roof antena for hook up.Tries again,will pick up all DTV free AIR tv stations.
Apr 03, 2011 | Televison & Video
I have a vizio flat screen digital tv but only get 2 channels that work well and 1 that isnt there half the time. it didnt even pick up most the channels when it scaned for them. Do i need a digital...
The digital signal must be strong in order for the set to lock onto it. From what you described it is weak, therefor it will not recognize it with auto program. If your on cable, call your provider. If your using an outside antenna, check position and possibly need a larger one.
Apr 22, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
TRutech 15" LCD does not pick up all channels
Check your TV settings and make sure your tuning is set for cable (may say "cable" or "CATV"). Right now you'll probably find it set for "air". If the TV is set to tune off-the-air, cable channels 2 through 13 work normally, but above that they aren't detected. Once you set the tuning mode to cable, rescan channels and you should have them all.
Apr 01, 2009 | TruTech PLV1615T 15 in. LCD Television
Digital TV not picking up all channels
TV is searching for over the air channels. Select in the main menu to go from over the air to cable channels and you should be fine.
Nov 19, 2008 | Televison & Video
Not picking up digital channels on my Dynex TV
My Dynex tv isn't picking up my digital cabel any suggestions for me Please!!! I am lost without my TV!!!!
Aug 14, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
RCA L32HD41 LCD TV Logo
27 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
