Question about Pyramid (PS36KX) 600-Watt Power Supply
Pyramid ps-36 kx model the buzzer will not go out
3 Suggested Answers
  • 1584 Answers
SOURCE: pyramid ps-26k protection light and buzzer
Might want to read this
http://www.eham.net/reviews/detail/3442
Posted on Mar 16, 2010
SOURCE: Re: Pyramid PS-36kx power supply buzzer sounded,red light came on
Hi! I saw your question, and maybe this will help. I also have a Texas Star 100w amp, and this same power supply. Even though the nominal draw for your equipment is way below the rated amp flow of the power supply, when you key up, and the output on the amp is at max, you are drawing the limit of your power supply! Try running this setup at a lower linear output. You don't need the full 100 watts to get out! 60-80 watts is aplenty! You should start at a low output, and slowly increase the output(while keyed up), untill the power supply starts to complain.(buzzer/light). This is what your limit will be. The only other cure, is a MUCH bigger power supply. Unfortunately, I cannot afford a 60-90 amp supply, so this is what I am forced to do to use the one we have. Also,keep your cb's output very low when using the linear amp. These amps are supposed to get a low signal from your radio, or the linear amp is overdriven. (noisy and unstable. Hope this helps you! 73's to you! jimsjinx
Posted on Dec 03, 2011
Is there a schematic for takedown and repair of daisy bb gun model 36
This is the closest manual I found.
https://www.daisy.com/_manuals/25_manual_english_spanish.pdf
1938 model
http://www.pyramydair.com/blog/2009/06/bb-gun-disassembly/
There are a lot of manuals here, but not a Model 36
http://www.pyramydair.com/manuals
so I would contact Daisy or Pyramid Air direct.
I did find a picture of one!
daisy model 36 schematic Bing images
Apr 28, 2016 | Toys
I have a Pyramid PS-52kx. I need to know the value of R13 on the controller board, and cross-reference for TYN416
I HAVE A PYRAMID PS-52KX I NEED TO KNOW THE R13 RESISTOR OHMS AN TOLARENCE AND WATT.
Mar 07, 2011 | Pyramid PS52K Amplifier
Apr 30, 2009 | Pyramid (PS36KX) 600-Watt Power Supply
Ps 52 kx power supply will not hold load
thank you for your help . I have already fixed the power supply I double checked the transisters and found three bad so I replaced all the power transisters and it is fine . thanks again bob
Nov 17, 2008 | Pyramid - PS21KX 20 Amp Power Supply Car...
Pyramid ps-21k power supply
you need to get the voltage regulator circuit checked in your ps-21k
Jun 13, 2008 | Pyramid 10 AMP 13.8V POWER SUPPLY Car...
Pyramid 35 amp regulated power supply
Use specified power supply by the computer.
Feb 05, 2008 | Computers & Internet
Pyramid - PS21KX 20 Amp Powersupply overload
The problem I have had with a PS-20 is a blown capacitor. Hooked to a radio, would allow radio to receive fine, but when trying to transmit, amperage would bottom out. Behind the transformer is a large circuit board. UNPLUG POWER SUPPLY, remove cover, Undo the two nuts, flip board over, and gently rock the 4700uf capacitors side to side. If they move more than 1/16th of an inch, chances are they are blown. Remove/replace and should be good to go...
Jan 10, 2008 | Pyramid - PS21KX 20 Amp Power Supply Car...
Pyramid (PS36KX) 600-Watt Power Supply Logo
47 people viewed this question
Top Pyramid Computers & Internet Experts
BJ Russell
Jason Morris
Are you a Pyramid Computer and Internet Expert? Answer questions, earn points and help others
