Question about Intel SE7320EP2 (SE7320EP2DG) Motherboard
Error 51A2: System cover has probably been opened
On my SE7320EP2, everytime I boot up it greets me with the "Error (51A2): System cover has probably been opened". The chassis intrusion switch has been totally removed and we have tried to put a jumper on the connection but we still get the error. We have cleared the event logs in the BIOS and it still comes up. Any suggestions besides changing out the motherboard?
  • Mike
    Mike Sep 28, 2007
    Turns out that one of the pins that needed to be jumpered had actually come out and didn't connect correctly, but the firmware update did fix the event log situation and helped overall. Thanks!
    Novelist:
    Scholar:
  • 167 Answers
I hope there an option in the BIOS that could disable chassis intrution detection. Please check the BIOS settings....
Posted on Sep 27, 2007
    Scholar:
  • 72 Answers
I would say you probably need to update the firmware. That should clear any issues you have with the event log
Posted on Sep 28, 2007
I have a dell and it said that i had a chassis intrusion I dont know what it means nor what to do help
That just means the case of the desktop was opened by someone.
http://phubner.eng.ua.edu/Files/Optiplex%20GX620/advfeat0.htm#wp1124663
Security Chassis Intrusion Detection note.gif NOTE: When the administrator password is enabled, you must know the administrator password before you can reset the Chassis Intrusion setting. This feature, if installed and enabled, detects that the chassis was opened and alerts the user. To change the Chassis Intrusion setting:
  1. Enter system setup.
  2. Press the down-arrow keys to move to the System Security option.
  3. Press <Enter> to access the System Security option's pop-up menu.
  4. Press the down-arrow key to move to the Chassis Intrusion setting.
  5. Press <Enter> to select an option setting.
  6. Press <Enter> again after you update the option setting.
  7. Exit and save system setup.
Option Settings
  • On - If the computer cover is opened, the setting changes to Detected, and the following alert message displays during the boot routine at the next computer start-up:
Alert! Cover was previously removed.
To reset the Detected setting, enter system setup. In the Chassis Intrusion option, press the left- or right-arrow key to select Reset, and then choose On, On-Silent, or Off.
  • On-Silent (default setting) - If the computer cover is opened, the setting changes to Detected. No alert message appears during the boot sequence at the next computer start-up.
  • Off - No intrusion monitoring occurs and no messages appear.
May 27, 2012 | Dell OptiPlex GX620n PC Desktop
When switched on my pc it will display error messaga . That is "error 912 the machine cover has been removed since last system is start up"
This error is displayed if chassis intrusion protection is enabled and the cover is removed.
But as I remember you can bypass this message and start the computer. I don't remember the key, but try Escape or Enter key. (I think the button to skip this error is displayed below the message).
You can also go to BIOS and disabled Chassis intrusion detection.
Sep 05, 2011 | HP Compaq Presario SR2011WM PC Desktop
The problem of my computer is when i open my computer its not boot to windows it shows chassis intruded fatal error-system halted! what can i do to solve that problem? my board is asus p5sd2-vm.
chasis intrusion is an option in the bios, when U start the pc, press dell to go into the bios, walk trhough the settings ( I think it will be in a section advanced or security) where U can switch off intrusion.
Did U open the case recently?
Jun 16, 2011 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
I am getting the fatal error chasis intruded error on every boot...motherboard model is p5sd2vm...rahul
Chassis intrusion can be disabled one of two ways.
First, Check your bios settings. There should be a security or PC health section where you can clear that error and disable the intrusion warning.
Second, there is likely a small switch near the chassis side when the side panel is removed. This is the chassis intrusion switch. It will likely lead to a 2 or 3-pin connection on the motherboard. this can be disconected without any ill effects.
Aug 13, 2010 | Computers & Internet
ERROR 51A2 SYSTEM COVER HAS PROBABLY BEEN OPENED - I NEED TO RESET THIS ERROR CONDITION
Go into the BIOS and disable the error message unless you are not the owner of the computer or you care when someone has opened the case.
Jul 14, 2009 | Intel SE7320VP2 Motherboard
Chassis intrusion
You need to check the chassis intrusion pin setting located on the motherboard. See page 1-30 (Number 11) in your manual.
You need to add a jumper as shown.
The system should no longer halt.
Cheers!
Mike
May 04, 2009 | ASUS P5V800-MX Motherboard
51A2 System Cover has probably been opened.
The chassis intrusion detsctor has been set off. You'll need to look at your owners manual for the steps to reset it. Good luck and hope this helps.
May 04, 2009 | Intel SE7320EP2 (SE7320EP2DG) Motherboard
Error(51A2): System Cover has probably been opened
It is probably a raid error. One of the drives may have failed.
May 04, 2009 | Acer Altos G530 Server
Pc halted
very simple shut down computer put side panel back on and restart go into bios and under the settings somewhere you will see enable chassis intrusion. Just disable that. If you put cover back on then proceeded by turning power on and you still get this error than it is time to clear CMOS and then you must go into the bios and hit setup default and then go into any timings and voltage settings for CPU Memory and such. and also disable the chassis intrusion. You can enable it at anytime. just as long it is not powered up when removing side panel. I hope this is helpful.
Feb 22, 2009 | ASUS P4P800-E DELUXE ULTRA ATA133...
I have a Acer m420 4850B new I put in a PCI
Try going to the horses mouth (Acer) next time. From their on-line support:
Product
Veriton M420
Issue
Chassis Opened Warning Error
Solution
To disable the Chassis Intrusion Alert, please follow the steps below.
  1. With the system powered off; press and release the power button.
    Immediately afer releasing the power button, begin tapping on the Delete key.
    This will enter the system BIOS.
    In the BIOS, use the arrow keys to navigate the menus.
  2. Navigate to Integrated Peripherals and press Enter.
  3. On the Integrated Peripherals screen, there is an option labeled OnBoard IO Setup. Select OnBoard IO Setup and press Enter.
  4. Look for the option, Chassis Opened Warning.
    Select Chassis Opened Warning and press Enter.
  5. Change the currect selection from Enabled to Disabled and press Enter.
  6. Press F10 and then press Enter to Save the Settings and reboot.
The computer should boot without the intrusion alert message.
Feb 20, 2009 | Acer POWER APS290-UC4201P MT CELERON M 420...
Intel SE7320EP2 (SE7320EP2DG) Motherboard Logo
1,240 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
