Question about Northstar Pressure Washer 3000 PSI
North Star pressure washer 1578203g Manual - Northstar Pressure Washer 3000 PSI
  • 174 Answers
SOURCE: northstar pressure washer randomly gives pressure
Hi:
You need to find the bypass (unloader) valve and grease it with a good waterproof grease. Sorry, I cannot find a pic for you
Posted on Sep 03, 2009
  • 174 Answers
SOURCE: oil leak at top of pump
The oil in the pump is probably leaking because a seal is blown and water is getting into the piston housing. Take a look inside at the oil. It should be brown and translucent. If it is gray, white or milky, you have a blown oil seal. This reservoir should only be 1/3 full of non-detergent oil to begin with. Hope this helps
Posted on Sep 10, 2009
  • 53 Answers
SOURCE: my washer vibrates and has low pressure, whats wrong
add some oil to the hydrailic pump it may be low.
Posted on Nov 15, 2009
  • 68 Answers
SOURCE: Water does not come out of the lance when I squeeze the trigger
HI it sounds like you may just have a blocked jet on the end of your lance. Please remove and clean.
Posted on Jun 10, 2010
woobie dog
  • 1273 Answers
SOURCE: what kind of oil does the pump on the nortth star
Hi, W/D here.
Usually, they use universal tractor transmission fluid. Here's a link that will take you to available models and manuals:
http://www.northerntool.com/shop/tools/product_200347874_200347874
Best regards, --W/D--
Please feel free to rate our solutions so that we may continue to help others. Thanks.
Posted on Feb 22, 2011
I have a north star pressure washer model 2SFX20ES3 and the pump is not working. The engine is working good. I pull the trigger and no pressure.
Hi
Sometimes you may have to allow a little time for the pump to prime itself and remove the air trapped inside. With the pressure washer at idle and the pressure hose fully extended, squeeze the trigger and see if you get pressure in a couple of minutes.
If you get no joy from that, your pump has likely checked out on you.
Hope this helps.
-Steve
Jun 05, 2015 | Garden
Just purchased ar142 blue clean electric pressure washer....how do I adjust the spay?
pressure washer nozzle article may help:
http://repairshed.blogspot.com/2013/09/pressure-washer-lance-nozzles-what-you.html
Sep 07, 2013 | Blue Clean AR North America AR142 1600Psi...
I have a North Star pressure washer GC160. What oil do I use in pump and what is recomended for the Honda engine? Can you also tell me where I can download a manual? Bob
As far as the pump gose just use a 30 weight oil they call it pump oil but realy its a 30 weight oil if you want the # its AW-4085-0016 or equivlant . The engine oil is a 10 -30 in most tempatures they say use a 30 wight above 40 degrees but i use mobil one extend proformance 10 -30 all year long in all of my mechines and have never had any problems and there all honda engines . Just change the oil every year some of mind are 35 years oil and run perfictly
May 09, 2011 | Northstar Pressure Washer 2800 PSI
May 31, 2010 | Northstar Professional Series Pressure...
Oil grade and level in pump reservoir? Motor is shutting down, all else seems fine, assume is oil level. North Star with Honda GX340 - pressure washer.
15-40 there will be a fill mark that is easy to see when you remove the cap or it will have a dip stick
Second your oil pressure switch may be bad or have a bad connection
Mar 06, 2010 | Hardware & Accessories
I have a M157305J North Star pressure washer. The
The thermostat in the control is sticking... by turning it a bit you get it to release and kick back on...
You need to replace the control...
Heatman101
Mar 03, 2010 | Garden
I want to remove the 4gpm pump on my pressure washer.
HI, It sounds like it is just stuck on the keyway as these can be very tight. You need to force the pump of evenly on either side and should come of if patient.
Feb 05, 2010 | Honda Maxus Prosumer MX5223 Pressure...
No pressure on hose
i have a karcher pressure washer i had to change the fuse box and pressure coils hope this helps .tom
Aug 19, 2009 | North Star Garden
Engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
May 28, 2009 | Karcher 2500 PSI Pressure Washer
North star petrol pressure washer. working fine, then no high pressure, checked water feed, water filter , pressure relief valve and gun nosall well work sometimes and keep working, when you release the...
Sounds like the regulator is sticking or is airbound. loosen the water connection and then tighten it back. Could also be that the trigger gun is faulty or needs adjustment. Hope this helped
Mar 12, 2009 | Karcher 2500 PSI Pressure Washer
Northstar Pressure Washer 3000 PSI Logo
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
