LG DVD player displays ''NO DISK'' and fails to read ANY DVD's. having removed cover and watching the carrige that houses the laser it moves back and forwards aprox 3mm as it tries to read then after maybe 60 seconds it stops and displays no disk.
    Genius:
  • 1,550 Answers
Try this,with your finger stop the motor spindle if you can.
If you are capable to stop the motor,they are on bad conditions and need to be replaced because they loose the velocity required for a good functioning
Posted on Apr 24, 2009
READ CD BUT NOT DVD NO DISK Disply
you need to replace the laser assembly in the drawer laser is going out
Jan 20, 2013 | LG LHT250SC Theater System
LG RH265 does not read DVDs
Purchase a DVD cleaning kit and follow the instructions, this will remove any dirt from the laser pickup lens, and hopefully get it up and running. If this fails, the only other option is have the whole laser assembly replaced, "expensive" or replace the entire unit.
Mar 06, 2012 | LG RH1999H DVD Recorder/HDD Recorder
My LG plays some cds and dvds but to others it fails. to other dvds it reads them but the screen flickers so i can not watch well. WHAT COULD BE THE PROBLEM?
Good day..
That is the common problem of DVD..In that case it usually happen when the lens is not function well or cannot read the CD clearly so you have to do is..
  • First,remove the cover of the DVD by loosening all screw from the side and back that holds the top cover.
  • Secondly,if your DVD having a top cover to the disc assembly or the disc tray,remove it..If none you need to remove the whole disc assembly from the unit to reveal the cd lens
  • Thirdly,after the lens will reveal..Try to clean the lens using cotton buds and don't put any chemical such as alcohol or contact cleaner even water..
  • And finally assemble it to test the DVD if it is OK..
  • Thank you and good luck.
Apr 11, 2011 | LG DVD 5183 DVD Player
Dvd player won't read dvds. The player mechanically operates ok in that the disk tray goes in and out. And, the read head moves back and forth when trying to read the disk. I can't see a red light from the...
There can be various reasons.1 is the region code correct?
There a selection of dvd`s which you can`t play,this is in the front of your manual.
Unfinalised discs won`t play etc
Oct 19, 2009 | Televison & Video
Wrong disk
I looked at everybody's ideas, and none of the ideas seemed to fit my situation. My DVD player has been working fine for one month. I got a new DVD today in the mail. It froze, and then began to display the WRONG DISK message. Then, nothing would play on the player, All of the DVDs that had worked fine before, now would not play. They all said WRONG DISK. I tried reaching under and trying to clean the laser lens, but that did not fix the problem. I am not saying that this will fix your problem, but this is what fixed mine.
1. Place the DVD player on a table
2. Plug in the DVD player.
3.Push the OPEN button so that the DVD platter extends outside of the player (It now looks like it does when it is ready for you to put a DVD in it to play it.)
4. Unplug the DVD player. (Now the power is off, and the platter is still extended.
5. Remove the cover of the DVD player being careful not to damage the extended platter.
NOTE: With the platter extended, looking slightly from the rear, under where the DVD is spun, you will be able to see the Laser lens. It will be covered by the mechanism that spins the DVD. The lens will be connected to a mechanism that that has two rails on either side.
6. Grasp the plastic surrounding of the laser lens area and pull the entire mechanism toward the rear of the DVD player.
CAREFUL: DO NOT YANK THE MECHANISM BACKWARDS as this will break off the laser unit. This mechanism is being moved with the resistance of many gears. PULL SLOWLY AND FIRMLY, and the entire mechanism will move on the rails until the laser unit is clearly visible to you and completely from under the spinning mechanism.
7. Since the lens was clearly visible now, and easily accessable, I carefully and lightly cleaned the lens with a Qtip and alcohol.
8. Replace the cover on the DVD player
9. Place a DVD on the platter.
10. Plug in the DVD player
You will find that you no longer get the WRONG DISK message and your DVDs will now play properly. As I said, just reaching under and cleaning the laser lens did not seem to fix the problem. It was only when I moved the entire laser unit from under the spinning mechanism, and forced the DVD player to realign itself when it powered on, did the DVDs begin to play again.
May 23, 2009 | Sungale DVD-2026 DVD Player
Cannot read discs
this dvd sucks. I just bought it around 5 months back and it as working fine till now. Now no matter what kind of disks i try to play on it, it has a common answer. " the disk vant be played".
i guess the problem is with laser reading lens. u may try to the following guide but i am going to dump this machine to samsung service stations as it is still covered by warranty.
it sucks wont buy this brand again.
Step1 Make sure the laser pickup lens is actually the problem. There are a wide variety of reasons that a DVD player might not read a disc efficiently. The disc could be scratched or dirty, for example. Test the DVD player with a disc that you know works before trying to clean the lens. Step2 Purchase or borrow a lens cleaner disc and try it first. You can find these things really cheap at any large department store. They usually get the job done well. However, you may need to clean the lens manually if the store-bought cleaner fails. Step3 Remove the outer casing of the DVD player. Remove the screws that mount the top casing onto the bottom of the DVD player and slide the top casing off. This will expose the DVD deck, which houses the laser pickup lens. Step4 Find the lens. The lens will be glass and under the DVD clamp. The lens will probably have a blue tint to it. If you are having trouble finding the lens, you could shine a light on the components and watch for the reflection. Step5 Use a cotton swab and some isopropyl alcohol to gently wipe the lens. Just a quick scrub will do. Dry the laser pickup lens with the other end of the swab. Step6 Give the lens a few seconds to dry and replace the covering of the DVD player. Test the efficiency of the player. If necessary, repeat the process. jQuery('.Article .Steps .Image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Nov 29, 2008 | Televison & Video
When it tried to read a disk I get an error code ho3. the model is panasonic dvd-ls82
Fixing code H03 is very simple but needs some courrage and small philips screw driver.
The problem arrise from the laser lamb which moves up and down the disk through a mechanical shaft. I do believe when we press the back space for long time it will take the laser lamb beyond its limit and get stuck at the end of the rotating shaft so the servo motor gets difficulty and resistance to get it back to tract.
All you have to do is open the back of the DVD player " 12 small screws"
When you remove the back cover be carful not to damage the cables .
You will find the servo motor and laser lamb on one metal structure hanged to the body by three rubber suspensions.
Remove the whole structre and turn it upside down slowly .
Move the small black rotating joints up or down you will notice the the mechanical shaft will start rotating and the laser lamb will start to move away from the servo motor relasing it from where it get stuck.
And it will work perfect after that. Return the back cover and screw the 12 screws and you are done. Good Luck.
Apr 08, 2008 | Televison & Video
DVP642/ 37 DVD player says "NO DISK" with any disk.
Usually if there is a NO DISC error, and the lens is verified clean, there is either dust in the laser assembly (use a can of compressed air to clean it out) or a loose laser assembly cable. Also check to make sure the lens can bob (wiggle around), and that it can slide back and forth.
The emergency eject is underneath, its a small slot. Insert a toothpick at one end and slide to the other end to open the tray.
Oct 28, 2007 | Philips DVP642 DVD Player
Check disc
Change your DVD player
May 23, 2007 | LG DE9523P DVD Player
Portable dvd player will play music cds but not video dvds
Chances are, your DVD player uses one laser to read CDs, and a different laser to read DVDs (since Cds and DVDs are read at different wavelenghts of light). If the DVDs you're trying to watch work properly in other DVD players, it probably means that the DVD laser is dirty, damaged, or burned out. Though you can try cleaning the laser (use Google for suggestions on how to do this, or check the Audiovox website), you will most likely have to get the DVD player repaired, or buy a replacement. Many of the newer CD/DVD players sold today use a single combination laser, which reads both CDs and DVDs, which means that when the laser fails, it will not work at all. Wish I had better news for you, but I guess that the only consolation you have is that your Audivox player still works with CDs...
Apr 01, 2007 | Audiovox D1812 Portable DVD Player
Televison & Video Logo
113 people viewed this question
Top Televison & Video Experts
Electro Med Services...
