CANT TUNE THE LG LV88O VCR TO THE VIDEO CHANNEL ON THE TV THROUGH THE AREIAL TO TUNE IN ALL THE CHANNELS AND WATCH MY VIDEOS
  • ronkirkbunga Apr 28, 2009
    could i have a more detailed solution the serial number off the back off the video is 901INQU425452
  • 10,594 Answers
Please connect RCA video cable (yellow-red-white) in Video Out terminals in your LG VCR and put that cable in TV AV Input. Now put tape in VCR, press Play button and select AV input in TV by TV remote, now you will get VCR playback picture and sound in TV.
Press Stop button on VCR, put Ariel in RF IN pin at back of VCR and tune available TV channels in VCR. You will see all available TV channels picture in TV.
Now set up is complete and you can record any desired program in VCR tape by pressing Record button on VCR or Timer Recording function.
Hit "add a comment" button for further query / info. Let me know exact model of your LG VCR written at back of VCR for more detailed reply.
Thanks.
Posted on Apr 24, 2009
  • Shahid Electronics
    Shahid Electronics Apr 28, 2009
    You need to connect SCART CABLE between TV and VCR as shown in below image..
    After Scart Cable connected, Play VCR and select AV Input in TV with its remote and make sure VCR playback picture and sound comes.
    Now press Stop button on VCR and put Antenna pin at Back of VCR as shown in above image..
    Click HERE to download Instruction Manual copy of LG LV880 VCR for details about Tuning TV channels in VCR. Please provide VCR model number " LV880 " in search box to get instruction manual free copy.
    Thanks.
I own a older model citizen tv vcr combo. it is the box style and i cant watch any channels on it. the only channel it allows me to view is ch 2. i can watch a movie aswell. also if there is not a movie...
You need to autoprogram your channels with the Remote that came with the VCR combo. The Tape issue is common with many older TV VCR combo units. Put a tape in that is rewound and hit stop and then tune in your channels.
Jan 19, 2011 | Televison & Video
We have been trying to set the channels in our old picture tube tv. it scans through the channels and once complete, you can only watch the last channel found and once you go to change channels, it...
Be sure your tv is programing with a correct signal. Air or cable channels, and that you do have a line going into the RF connector [antenna signal]. If you have a satellite or cable box your tv will only tune to channel 3. Also, if you are logged into a dvd player or vcr...you will only have one channel memory. Remove any of the external players [games,dvd,vcr etc.] And retune with auto program!
Jan 09, 2010 | Televison & Video
I inherited an old Sony Trinatron TV it's working fine & have just bought and LG VCR to replace a VCR that broke which also works fine. The problem is in tuning the VCR into TV. I automatically tuned...
Depending on where you live you might have to go buy an HD antenna and scan for channels and hope you can get a PBS station or something to get you off of zero and then go into the menu and manually program a channel you can use to tune your VCR maybe that might do the trick
Jun 22, 2017 | Televison & Video
LG VCR GC480W can't tune in to tv
Any vcr I know of usually is tuned through channels 3 or 4 unless they are hooked up directly by RCA patchcord. 3 pronged- 2 audio and 1 video. With the patchcord you'll be tuning through an auxilary input in the tv.
Jan 27, 2009 | LG XBR446 DVD Recorder/VCR
How to tune to tv channels
There is a switch [tv-vcr] somewere in the front.When pressed to tv, you can change the channels FROM the vcr.You will need an "air wave" ANTENNA signal because the cable box individual channels cannot be seen when you place the switch to tv.Now if you have a cable box connected properly and turn that tv-vcr switch to vcr the individual CABLE BOX CHANNELS will show through the vcr.
p.s. There is a small switch (someware in the back of the vcr & the back of the cable box,dish box, etc., etc.) ch.3 or ch.4 and the VCR have to be on the same INPUT channel as the box.
Dec 09, 2008 | Televison & Video
Akai VSG285 video - I can't tune any TV stations thru to the VCR?
This sounds like a hookup or programming problem.
The typical hookup is cable/satellite box output to VCR antenna/RF input, then VCR antenna/RF output to television input. Since you are able to watch pre-recorded tapes, the latter is already correct. There are other ways to connect, using the audio/video outputs of VCR to audio/video inputs of the TV. Older or low end TV sets may not have these connections.
If by chance you are using an outdoor antenna (not cable or satellite) then the antenna connects to VCR antenna/RF input and VCR output as above. You will also need to program the VCR into the stations- most late VCRs will scan for active channels, and program themselves to those channels.
I'm not sure of the capabilities of newer cable & sat boxes, but generally, you had to tune that box to the channel you wanted to record. The VCR is set to channel 3 or 4 depending on the output of the cable box.
Lastly, most VCRs of the last 10+ years require the remote to setup advanced functions, such as timed record, date & channel setup functions. The buttons on the VCR itself only do very basic functions, Stop/Play/Rewind/F-forward/Eject etc.
If you don't have the orig. remote, some universal remotes may be able to do advanced programming functions.
Apr 09, 2008 | Televison & Video
Vcr
You will have to tune the TV to the VCR output channel, which it sounds like you are already doing if you can watch videos. Then you need to set the VCR tunert to the correct input channel, probably something like line 1 or Aux or something like that. Probably the easiest way to find it will be to turn everything on and then just scroll through the channels on the VCR until you see what you are looking for.
Mar 24, 2008 | Mitsubishi HS-U775 S-VHS VCR
How to connect my (old) vcr to my sony tv
if you connect via SCART lead, then you will need to select your AV channel or channels on your tv.
If its via arial, you will have to tune your tv to find it.
Mar 04, 2008 | Akai VS-X800EGN VCR
Switching vcr channels
look behind your vcr there switch there [test signal]on and off turn to off the black and white bar will lost.
Oct 31, 2007 | Panasonic PV-7661 VCR
VCR tuner cannot tune in my cable channels
It is working as designed. The purpose of your cable box is to take in a wire containing all of the possible channels you might watch, and then extract *one* channel, and force it to appear as channel 3. If you connect the cable directly to the VCR, then the VCR's "tuner" (ie, channel selector) has an opportunity to extract any channel it wants. But... as you point out, your VCR won't be able to "see" any of the digital channels. So... if your goal is to be able to watch any of the digital channels, the signal must pass through your cable box, which will put the selected channel on channel 3. There is no value in going from the VCR to the cable box, since the VCR's tuner will have already filtered out all but one channel. It would be helpful to make a list of what your useage goals really are, since there are so many different ways to hook these things up. Are you interested in: - watching digital channels? - recording digital channels? - watching one channel while recording another? - using higher quality video signals (composite, s-video, component, etc) rather than RF (ie, channel 3) And so on. Keep in mind that you have *three* tuners: Your cable box, your VCR, and your TV. It sounds like only your cable box can tune in the digital channels. If your cable box puts out any non-RF signal, then the best choice would be to go: Coaxial Wire -> Cable Box -> Video Connection -> VCR -> Video Connection -> TV, with the VCR and the TV both set to "video". Then you would only use the cable box as a tuner, the VCR would only see the tuned channel (via video in), and the TV would see the same channel (or whatever tape you are playing) on its video input.
Mar 29, 2007 | Zenith VCS442 VHS VCR
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
