Question about Dishwashers
Hja 8640 dishwasher s light
The salt light stays on at all times even it has salt in it, also does not clean dishes properly.
  • 1462 Answers
SOURCE: the salt light keeps burning
the salt light is done by a reed switch operated by a float in the salty water. float may be stuck - give softener (where you put in the salt) a tap and also stir the water inside the softener. i assume you have put in enough salt. its not a serious fault
Posted on Mar 30, 2007
  • 236 Answers
SOURCE: problems with my bosch dishwasher
there should be no salt getting into the wash cavity. if you are sure that it is leaving salty water on the items then either the salt cap is loose/damaged or the regeration system is faulty-this is an expensive fix.
Posted on Jun 16, 2007
SOURCE: Salt Indicator Light Flashes Permanently On Indesit IDE 750 dishwasher
I've had the same problem on my Indesit (IDL-730, IDL730) and after pouring in salt until full for ages, without the light going out, I finally decided to do the reverse.
I left it to run down the salt over a couple of months, until well empty (not ideal, but I was getting desperate!), and then finally refilled it.
Problem solved - salt error light was no longer on
All I can figure is that a blockage had set in and casued the issue. Leaving it to clear over time sorted it.
Hope this helps in your situation.
Posted on Nov 18, 2007
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
rylee_smith
  • 8619 Answers
SOURCE: dishwasher does not clean the dishes properly
Hi
First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks
Low water fills are a very common trouble maker with today's dishwasher.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jul 10, 2009
The door leaks on my Diplomat HJA 8640 DISHWASHER. I have changed the door seals with no luck
Malcolm,
Good for you replacing those seals. Not trivial, I suspect.
Does your DW have a positive latch closure or does it just close without a latch?
If the opening of your unit has become distorted due to gradual settling, even a new seal won't work properly. Look carefully and make sure the unit is "square" in the enclosure. If not, use the leg adjusters to correct the situation.
Also, when you replaced the seal, you no doubt cleaned the door thoroughly, since debris can accumulate (especially along the bottom of the door) and interfere with closure.
Use a flashlight for a thorough visual inspection!
Oct 24, 2016 | Dishwashers
Dishwasher salt light wont go out after filling it with salt and everything is coming out white
well,if you fill it with salt and the salt light wont go out,and your dishes came out white,PLEASE STAY AWAY FROM THE DISHWASHER! the salt light is a warning light ,not to fill it but to delime it! wow,
Apr 23, 2015 | Dishwashers
Salt water error message when I have a water softener already
I feed Danby dishwasher salt whenever he asks (buy it by the case online). Still produces marginally clean dishes.
Apr 02, 2014 | Danby DDW1899WP Portable Dishwasher
My salt indicator stays on even though it is full & dishes have greasy texture after wash. What do I do?
Clean all the filters and spray arms YUCK!
Then check if there is a "reset" to the salt level. check solenoid to salt mixer is working. Check heater is working too.
HEY! you got a dishwasher question in the oven section AND I answered it ... cool... B-)
Oct 14, 2013 | Ovens
My dishwasher won't clean the dishes properly - very poor cleaning results with residue left on the dishes.
Check The Salt-Level ? Dishwashers rely, On salt and cleaning Fluids/Rinse Aids et,c. Also check for Any Blockages or Obstructions/Kinks/Bends et,c. in The External Outlet/Waste pipe.
Mike.
Jun 02, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher does not clean properly, leaves white stains on dishes
check the can of salt inside the unit if empty refill that one,but not ordinary salt,buy onit the salt for dishwasher,or check the filter inside the unit is some foreign object,remove it to clean the water.and use only the dishwasher soap the solid one is good compare to liquid.
Jan 01, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
User manual for lamona dishwasher HJA 8630
Hi my salt level indecator light stays on even when I have filled it with salt! please help anyone
Thanks Rose
Dec 24, 2010 | Dishwashers
WONT WASH CLEAN ALWAYS RESIDUE LIKE SAND ON GLASSES ETC. THAT IS ALMOST IMPOSSIBLE TO EVEN REMOVE BY HAND WASH ENOUGH SALT AND RINCE AID ALSO CLEAN FILTER EACH TIME NO OBSTRUCTION IN PUMP FILTER...
use CLR to remove any build up and then use LEMI-SHINE (walmart in dishsoap aisle) for the cleaning of your dishes. Works great for me as i have the worst well water on the planet.
Aug 11, 2010 | Dishwashers
Dishes are cloudy and covered with a film when done
Refill your SALT container with 1kg of dishwasher salt.
Salt reduces hardness in water -and increases cleaning efficiency. If you have a little furr build up in your kettle - you need salt in your dishwasher to work properly.
If you do use salt, it may be the salt reservoir is blocked with caked salt.
Oct 02, 2009 | GE 24 in. GSD4000J Built-in Dishwasher
Dishwasher not cleaning properly
If I got the issue correct your dishwasher has stopped cleaning properly.
As advised by an Frigidaire engineer that there is not enough salt in the dishwasher & that is what causes the sand like residue on dishes. sometimes even when you use an all in 1 dishwasher tablet this may still not contain enough salt for the hardness of the water in your area. Using salt regular helps keep the dishwasher clean.
I am sure this would help you:
God Bless.
Jul 09, 2009 | Frigidaire Dishwashers
Dishwashers Logo
20 people viewed this question
Top Dishwashers Experts
