Question about Applied Microphone Technology Toys
What are the disadvantages of a pillar drill?
I have electric gates and my question is regarding the pillar that the arms are attached to.
Use Hydraulic Cement, rather than regular concrete. Regular concrete mix, sand mix, etc doesn't bond well to existing concrete. As soon as you put some torque on it, the bond breaks. When you dig or chip out the area to be replaced, make it larger at the back than the front. When you fill it with hydraulic cement, the slight expansion of the hydraulic cement will force a tight bond. The brand that I used for years is Rockite by Hartline Products, but there are probably ten others. Most people don't realize that when normal Portland cement cures, it shrinks slightly, which is one of the reasons it doesn't bond well to other concrete... it pulls away. If you look at where railings have been drilled into existing concrete steps, you'll see smooth gray material has been poured in. That is usually hydraulic cement. For a sideways application, you will need to make a form to hold the cement it... it is very liquid when you pour it. I would advise putting your bracket and supports in first, and pouring them in place. Put nuts and washers on the bolts, so the cement has something to grab. Be aware, you have to work fast. From mixing to initial cure is only a minute or two.
Jan 04, 2016 | Cars & Trucks
HOW GOOD IS THE NEW HOLZMAN BENCH DRILL PRESS
The other practical alternative of Drill Woodworking is for drilling holes into wood, which is on occasion additionally stated a pedestal drill, pillar drill, or bench drill.
more details Best Drill Press 2018
Aug 02, 2013 | Drills
Door henge bent
As I understand it the was open at the time and was forced further open towards the front of the car? I think your door pillar was twisted around. In a new car the body shop might cut out the door pillar and weld in another, but I think that is mot the way here.
What you want is for the door to shut evenly in the body all round. There is a small amount of adjustment available in the door hinge attachment bolts, body side and door side, and in the lock striker plate. See here p23
http://www.turboninjas.com/camry/bo.pdf
It may be that a little adjustment in all these would be enough to fix the problem. Try that first.
If not, take the offending door off and look carefully at the A pillar. It does not take much distortion to prevent the door from closing properly. Compare it with the good side, using a long ruler to see where it should line up with the surrounding body. This will give you a target for straightening it.
Then you need a metal bar like this U channel, 2-3 ft long by about 3 in wide.
http://i00.i.aliimg.com/photo/v0/483095456/U_channel_steel.jpg
Hardware shops sell them. Drill holes in one end to match the door hinge bolt holes, and bolt it on to the door pillar, first one hinge then the other. Use it to carefully twist the door pillar back the other way, not too much, using the long ruler as a guide.
This should bring the door pillar back to where the manufacturer's adjustment takes care of the rest.
Dec 19, 2012 | 1999 Toyota Camry
Electrolux EI26SS55GSO power failure alarm; how to disable
Hi Randy - The power failure alarm can't be complete disable, but you can try resetting it by pressing the ALARM OFF icon. Other modes may be turned off until the alarm is acknowledged. The power fail alert is turned off and the refrigerator should resume normal operation. However, if the alarm continues to go off after you have unplugged or flipped the household circuit breaker for 30 seconds contact a professional to have the main control board diagnosed.
Sep 20, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Step by step on how to change a drill bit in a pillar drill ? I need to do this for homework and the internet is **** for help. :(
Most drill chucks have a key to tighten them up and to loosen them, some are turned by hand, some have a drift key that gets tapped into a slot to knock out the drill bit that is held in by taper friction. So, which type do you have?
Feb 22, 2010 | Drills
My yukon rear ac i think! got my rear rear carpet all wet im thinking ac drain plug but dont really know how it works any ideas thanks ronn
The A Pillar is filling up with water and running out the hole where the front kick panel attaches. I took me 6 months to find this and a snake camera from Harbor Freight. The water runs down under the sill and soaks the front and back carpets. Seal the door hinges and the door grommet where the wires go from the pillar to the door with silicone black. Pull out the grommet and seal around it well. I also drilled a drain hole into that cavity just under that pillar but behind the front of the door bottom corner so it cant be seen with the door closed. No more problems!!!
Jan 17, 2010 | 1999 GMC Yukon
Replace belt
Sourced the part no and stock number on the Draper site, then sourced the Manual on the Draper site too
Nov 17, 2009 | Drills
I HAVE A 98 GRAND CHEROKEE LAREDO AND MY DOOR HINGE JUST SEPERATE
Guess they should have re-enforced those...too many are coming off. Not an easy fix but you need to remove the door and have the inside of the pillar re-enforced and welded in place with a heavier gauge insert. I've only seen one person do this in a way that impressed me. He cut a slot in the pillar and slid the insert inside, supported it with a screw placed into a pre -drilled hole (used as a handle), then welded it into the opening. the weld was then ground flat and the hinge was tack welded on top, while still on the door, then door was removed again and weld was completed. A lighter gauge piece was welded over the opening (slot) and then the pillar was re-painted. (looks like factory, wasn't cheap but was very strong.)
Aug 08, 2009 | 1995 Jeep Cherokee
Toys Logo
381 people viewed this question
Top Applied Microphone Technology Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Applied Microphone Technology Toy Expert? Answer questions, earn points and help others
