Recoton Rx tv receiver broken - Audio Players & Recorders
Connecting to samsung smart tv
For digital connections on your TV ( unknown model) read on page 7
[PDF] RX-6000VBK / RX-6008VBK INSTRUCTIONS AUDIO/VIDEO - JVC
Sep 30, 2012 | JVC RX-6008V Receiver
Advent tv displays green
If you are saying no red: The model indicated here Recoton Advent Advent Q1435A TV is a 14 inch set.
first it may be cheaper to replace than repair--That said if no red look to the small circuit board at end of picture tube (it plugs onto the tube).
It will have either individual output transistors or a single IC.
What (if only one color missing) I would look at is the bottom side which faces to the rear---a circle of solder connections--possible one is broken--there will be one for each red, green, and blue--not always easy to see but if any of the solder connections look cracked or even broken loose-----
Mar 28, 2012 | Recoton Advent Advent Q1435A TV
How do I connect my Yamaha RX-V463 surround sound system to an analog tv? The tv only has the three RCA jacks for audio and video. the RX-V463 has many jacks, and the manual is no help. the manual does...
Actually, the Quick Start Guide on page 6 of the manual shows the TV connection.
Consider that the TV is simply a visual element in your entertainment system and the rest will sound easy.
Run a single RCA cable from the receiver to the TV's Video IN so you can use its menus and view whatever video comes into the receiver.
Manage whatever audio you want to hear in HI-FI directly from its source to the receiver and NOT washed through the inferior audio electronics and speakers of the TV.
Jul 18, 2010 | Yamaha RX-V463 Receiver
Best way to hook up TV with one HDMI to blue ray DVD and RX-V465 receiver with Direct tv
Has Direct tv STB HDMI output?
Best is to connect all your sources (BD, DVD, STB, PS3) to yamaha receiver and connect yamaha hdmi-out to TV's HDMI-in.
Dec 29, 2009 | Yamaha RX-V463 Receiver
I have HDMI cable from TV to RX-V365. HDMI from DVD player to RX-V365. HDMI from DirectTV receiver to RX-V365. Speakers attached. I can watch the TV and the DVD player... but the sound is still coming...
the RX-V365 cannot process the audio from the HDMI input. You will also need to connect a seperate audio input (either coaxial or optical) into the relevant input in the rear of the RX-V365
Dec 12, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
How to use sap with a rx-v463?
the trick is, it has NOTHING to do with your receiver, and EVERYTHING to do with your TV, you need to choose SAP on the TV not the stereo. That will send the SAP sound to the stereo you are playing the sound through.
Oct 10, 2009 | Yamaha RX-V463 Receiver
Broken screen
trash it.. cost of a broken screen is typically close to the cost of a new set.
Jul 21, 2009 | Recoton Advent Advent Q1435A TV
29 people viewed this question
 Grubhead
Grubhead
