Question about Pioneer VSX-515 Receiver
After a power outage my receiver won't turn on
Why won't it work after a power outage?
there could be a blown fuse in there.i would take it to a technition if you dont see a fuse(s)
May 25, 2015 | Audio Players & Recorders
Reset after power outage
some of these had resets others reset after you unplug it for about 20 minutes and replug it in. some older models you had to hold in the power button for 5 to 10 seconds.
Apr 23, 2014 | Pioneer VSX-11 Receiver
Acer aspire x1430 won't turn on
CHECK LAPTOP POWER SECTION
Mar 08, 2013 | Computers & Internet
Sansui tv won't turn on
Check its main power supply regulator section circuit for defects. Check and replace damaged component/s.
Jan 10, 2013 | Sansui 32" TV
Sceptre tv won't turn on after power outage
You may have to open it to see if the line fuse that the power cord goes to is good or bad.
Dec 23, 2012 | Sceptre Televison & Video
Honeywell thermostat won't turn the furnace on after power outage.
probably tripped a limit switch or a low voltage fuse would kill your display on the tstat, you should have battery power on your stat though.unless you have knowlege of electrical you better call a technician
Dec 09, 2012 | Honeywell Programmable Thermostat Heater
After a power outage, everything worked except the A/V Receiver did not come on unless we manually turned it on. The Help feature did not correct the problem.
Since the Harmony remote has no way of being affected by a power outage, I would say that this is more an issue with your receiver itself. There was probably a power surge, and the IR receiver may have been damaged. I would try the original remote, or call the manufacturer to see if there is any way to reset the receiver.
Jul 22, 2011 | Logitech Harmony 1000 Advanced Universal...
WE HAD A POWER OUTAGE.NOW MY KEURIG WONT TURN ON. CAN YOU TELL ME WHAT THE PROBLEM IS. THANK YOU.
Hi,first you need to check if fuse has not been blown out.Because when POWER comes back after an outage there is a surge voltage flowing through electrical lines.It is advisable that when their is a POWER outage you have to turn off your FUSE box or SAFETY box to make sure that it won'tdamage appliances when POWER comes back>Technically when POWER SOURCE or SUPPLY has been shut off for a period of time.When POWER is back, expectantly there is an abnormal flow of current/line; current will not be as stable until a period of time..AC current behaves like a wave,values changes from time to time especially when POWER SOURCE has just been TURNED ON..So better turn off FUSE BOX when experiencing POWER OUTAGE so that when power comes back SURGE VOLTAGE wont flow within the circuit>Hope this helps..
Jun 22, 2011 | Keurig Elite B40 Coffee Maker
Won't turn on after power outage, is there a reset button?
Was it a simple outage or a surge? You may have something as simple as a blown fuse. However, before opening the set, make certain it is unplugged. Better safe than sorry.
Jun 12, 2010 | Aiwa AV-D57 Receiver
Pioneer VSX-515 Receiver Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
