Question about KitchenAid Pasta Roller / Cutter Set
Kitchen aid pasta roller won't move when I put into the machine
2 Suggested Answers
SOURCE: we need to find a
Here's my solution. I purchased an 8mm zinc-plated brass hex standoff from http://www.mcmaster.com (part number 92080A053). It is 25mm in length and has internal threads for an M4 screw. It fit perfectly into the nylon gear plug without modification. I had a colleague from work bore out a hole with his drill press (removing the internal threads) and turn down the exterior with a lathe to create a weak spot (mechanical fuse). See the attached image for the finished product. It doesn't match the original dimensions exactly but it is close and will suffice. You don't necessarily have to do the extra machining work if you don't have access to that equipment, but as jeffrey_w325 states in his post, this part is supposed to be the weak link and fail first. If you don't machine the part down, just be extra careful when using the pasta attachment. Good luck!4_3_2012_1_04_19_am.jpg
Posted on Apr 03, 2012
How can I fix pasta machine?
Take the end caps off. The shaft in the centre of the roller has come out of its bearing.
Jan 03, 2018 | The Kitchen Appliances - Others
Broken input shaft
KitchenAid doesn't sell any internal parts for the KitchenAid pasta attachments, the only thing to do is buy a replacement, if it is just the pasta roller you can purchase the KPSA, if not the others are just sold in the KPRA pack
Mar 07, 2014 | KitchenAid Kitchen Aid KPRA Pasta Sheet...
The knob on my kitchen aid pasta roller keeps getting stuck and i cant change the setting i need to be at
It needs either oil or the gear has slipped. A machine repair person, such as a sewing machine repair might be able to help you out for a small fee. Good Luck!
Oct 27, 2013 | KitchenAid Kitchen Aid Ravioli Pasta...
Kitchen aid pasta roller is locking up
You will need to follow your nose and carefully dismantle it to see where the fault is. As far as I am aware Kitchen Aid supply no parts for this accessory, it comes as a complete unit only.
Mar 24, 2013 | KitchenAid Pasta Roller Attachment
Hi, you may have a broken shear shaft. Here is a link to replace it.
http://www.ebay.com/itm/KitchenAid-Pasta-Roller-Attachment-KPSA-Repair-DIY-Hex-Shear-Shaft-Replacement-/281539451678
It also comes with instruction on how to replace it.
Feb 12, 2013 | KitchenAid Pasta Roller / Cutter Set
TABLE CLAMP BROKE
These clamps can be bought 2 ways, look for pasta machine clamp or craft clay roller clamp on eBay. The clay roller entire machine set is much cheaper than the pasta machine, but they have the same clamp.
Dec 03, 2012 | Marcato Atlas Pasta Queen hand-crank pasta...
Pasta Machine turning pasta sheets out with lots of holes? What are we doing wrong?
Start with the rollers farthest apart and when you first start rolling the dough will be uneven and have a few hole. But as you roll the dough over and over, it will be smooth with no holes in nice flat sheets. Rollthe dough twice on each setting, starting with the biggest number and rolling down to the smallest number for very thin sheets of pasta. Good luck. I have a recipe and videos on my website at http://noodlemakermachine,com.
Jan 16, 2011 | KitchenAid Kitchen Aid Pasta Maker...
Can the Kitchen aid accessories fit the Wolfgang puck stand mixer
If you happen to have a friendly toolmaker with a small metal lathe it should not be too difficult to modify KITCHEN AID accessories that fit on to the front powwer outlet. However Puck Stand Mixer accessories are occasionaly offered on the Web. Meat grinders are very common and original Puck pasta maker have also been seen. Get searchin'!
Dec 01, 2008 | Wolfgang Puck Stand Mixer
KitchenAid Pasta Roller / Cutter Set Logo
52 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
