Question about Dell E193FP 19" Flat Panel LCD Monitor
I have a 5 year old 1702FP. Recently it started going dark all of a sudden with the on/off button blinking. If you look carefully, at the same rate as it blinks you see a faint light flashing for a fraction of a second then it goes dark again. If I let it rest for an hour or so the problem goes away and it works fine. However it is not hear related because sometimes it happens first thing in the morning.
  • 1 more comment
  • victormonty Apr 24, 2009
    I've tried on on my MAC laptop with similar results. It might happen less often but still does happen.
  • victormonty Apr 25, 2009
    I will try the capacitor (first the 10uf) change next. This may take me a few days. I will get back to you when I'm done.
    Thanks for your help.
    After removing the stand and cover it looks like I have a different model than the one described in this article. I thought it was a 1702FP but below the cover it says E172FPb. The problem is that I cannot remove the plastic back cover. There is only one screwdriver-shaped opening at the bottom and the picture of a lock next to it so I'm sure there must be a way to open from there but everything I  tried did not work.  Any ideas?
    President:
  • 2,923 Answers
Hello Victor Monty,
Check the video connector to make sure it is clean and tight. Look closely for broken or bent pins by GENTLY rubbing your finger across the pins.
Otherwise, there's definitely a broken relay inside that needs to be changed.
If it's under warranty, contact the manufacturer of your LCD for repair.
Have a great day!
Best Regards,
Firesnake09
Posted on Apr 26, 2009
    Genius:
  • 1,847 Answers
The first thing you should check the video data cable. loose connection, bad port may cause such issues. Second run the monitor self test.
Let me know
Kindly rate the answer
Thanks
K
Posted on Apr 25, 2009
    President:
  • 1,223 Answers
Have u tried different pc on the same monitor or may be this monitor on vga out of notebook
Posted on Apr 24, 2009
  • 1 more comment
  • Shoaib Rais
    Shoaib Rais Apr 24, 2009
    it might be this
    http://www.instructables.com/id/FREE-17%...
    u can try it if u really want to
  • Shoaib Rais
    pls check all th epins of vga cable are they straight not bent if they are try to make them straight with pointed object
    have u tried the capacitor thing which i have provided u a link kindly look at it and tell me , i think ur problem is same as stated in the link
  • Shoaib Rais
    Shoaib Rais Apr 25, 2009
    in the mean time please see these resources as well
    Perform these trouble shooting steps first direct from Dell
    http://support.dell.com/support/edocs/mo...
    for the capacitor more help here
    http://chrismeyer.org/projects/lcdtroubl...
    if u get help please update ur rating ! to Fixya if it helped
Logitech m 705 mouse pointer flickering
Click the Windows "Start" button or press the "Windows" key. The "Start" menu opens.
Type "Cursor blink" in the "Search programs and file" text box.
A list opens.
Click "Change Cursor Blink Rate." The "Keyboard Properties" window opens.
Click the "Speed" tab. A list of options appears.
The "Cursor Blink Rate" section shows a "Cursor Blink Rate" slider displaying a range from "None" to "Fast."
Click and drag the slider button to the "None" area in the far left portion of the "Cursor Blink Rate" scale.
Click "Apply."
Click "OK." The cursor stops flickering on the screen.
hope this helps
Sep 12, 2012 | Logitech M705 Wireless Marathon Mouse,...
My DLink 5300 G internet camera suddenly says "No Signal."
  1. Remove the Java update and roll it back to the previous state.
  2. If it does not resolve the issue, reset the camera.
  3. Lightly insert a paper clip or a similar sized object into the reset hole on the back of the camera, press lightly and then release the button.
  4. The LED on the front of the camera will begin blinking red and green.
  5. When the LED stops the blinking, the reset has complete.
  6. If the issue is still present, restore the camera to factory settings.
  7. Insert the paperclip or other tool and press on the button continuously.
  8. Wait for the LED on the front of the camera to blink red and green and hold the button through two cycles of blinking (about 5-7 seconds.)
  9. Withdraw the tool after the second cycle of the LED blinking and factory restore has been completed.
  10. Run the installation wizard. If you don't have the installation CD, go to the manufacturer's website and download the software.
Nov 10, 2009 | D-Link DCS-5300 Network Camera
Screen blinking after 10-15 minutes
tell me dear which christmas it is. christmas is there in every year.
and now, if your system is new i.e not got its warranty over then please take it to the dealer. or if its a real old thing then these type of silly issues are most common my dear. the simple solution about to be tried is re installing your operating system. ( genuine windows xp or vista recommended.) if still the problem persists... get me back @ deepuunni1985@gmail.com
Aug 22, 2009 | Compaq Presario Notebook
Dell 1702FP gets off automatically or lose power by itself!
i think the power cord to your monitor is not fixed tightly. check the connections. or else the power On / Off button could have got damaged. replace it with the new one. if still the problem exists, servicing of the monitor will be the solution to it.
please rate my solution.
have a nice day.
Jul 05, 2009 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Cut tv off now it won't come back on its a sony hdtv wega
ok. the error codes for your model only go up to 10 blinks. Carefully count the blinks as there should be a slight pause then blink again.
Jun 22, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
My top loading washing machine suddenly will not start.
LET ME SEE: YOU HAVE A PROBLEM WITH THE WASHER NOT STARTING, RIGHT? SOUNDS LIKE THE MOTOR HAS GONE BAD ON IT. BUT CHECK THE TIMER FIRST. IT COULD BE YOUR TIMER. IF IT AIN'T THAT, CHECK THE MOTOR AND CALL YOUR REPAIRMAN IMEDIATELY FOR SERVICE. WHAT BRAND AND YEAR IS YOUR WASHER?
RODNEY
May 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Viper Remote Start, Jeep Grande Cherokee, Going crazy!
no - unfortunately "any mechanic" does not have the training to troubleshoot an alarm system, and a dealership does not work on anything aftermarket.
Your best bet is to visit DEI (Directed Electronics Inc.) website and find an authorized dealer near you... most likely a car audio shop.
Best Buy usually hires newbies as installers and they dont have much experience... Look for an independant shop.
CLICK HERE to go to the Viper Site. (Find a Store is at the top of the page)
The brain module cannot be repaired - the ignition and starter relays are integrated on the controller board. Since it is 2 years old - there may not be a replacement part available.
Good Luck!!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 06, 2009 | Viper Security and Remote Start System...
Kenmore dishwasher blinking lights
Dear friend,
ngfam at you service! happy to assist!
The blinking lights are called codes and this is warning you that there is a technical problem. Probably an electronic failure some where. This can only be diagnosed by a trained service tech!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 29, 2008 | Dishwashers
Dell 1702FP 'tearing' after warmup
It might be a failing electrlytic or a heat-related issue with a transistor in the power supply, or it may be a problem in the video board. Sounds like will need good old-fashioned component-level troubleshooting.
Jan 02, 2007 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Dell E193FP 19" Flat Panel LCD Monitor Logo
106 people viewed this question
Alun Cox
