Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
650 refrigerator temp is set at 38 but now gets no lower than 44. Should it get cooler?
  • lwb9 Apr 24, 2009
    Service man checked the system and diagnosed the problem as low freon probably due to tiny leaks in the evaporator. Sub Zero will replace the compressor, evaporator and another part for no charge for parts, labor, or service call. This will be done by CW Service, Dallas, TX. The freezer is fine and generally does not have this problem.. My warranty will expire in 1 month, so this is good fortune.
    Guru:
  • 1,524 Answers
Check the condenser to make sure it is dust free. I have also seen pieces of paper get sucked into it.
Posted on Apr 24, 2009
  • Robert Moller
    Robert Moller Apr 24, 2009
    This is typical of Sub Zero's. There is a complete seperate system for the freezer
GE monogram refrigerator too cold
There is a balance between the freezer and fridge. Reduce the freezer temp and see what the fridge temp does. By reduce I
mean make the freezer warmer. If it is set too cold the fridge gets colder.
Nov 25, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Just bought a Dometic DM2862 fridge. Freezer on goes down to 12 deg. and lower unit down to 38 deg., but during day the temps are: freezer - 22 deg. and lower - 44 deg. Is this normal? Can I fix this?
While there is some fluctuations in temperature in Dometics from night and day, but it is usally the reverse of what you state. Warmer in the day time when the unit is opened more. I would check the temperature settings and if they are correct then check the thermostat.
Aug 31, 2011 | Dometic RM2652 Refrigerator
How to set fridge temp
    1. The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food. Place your magnetic thermometer in the refrigerator.
    2. Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
    3. After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
    4. If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
    5. Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
    Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
Dec 19, 2010 | Freezers
True cooler frezzing kegs of beer
If I am not mistaken, the True line-up of coolers have a temp control on them that is labeled 0-9.
This particular type of temp control is a coil temp control. I measures the temperature of the coil rather than air temperature.
Always set the control to the warmest setting and move it colder by one number at a time until your product reaches and holds designed temp. Do not go by cooler air temperature as there will be a great swing in temp especially if the doors are used frequently. Always temp the product. In the case of beer, your ideal holding temp is between 35-38°.
If you set the temp control to the warmest setting and the cooler is still freezing product, you will need to have the cooler serviced be a refrigeration tech. It will most likely be a bad control but there may be underlying problems.
Jan 08, 2010 | True TBB-2 Beverage Cooler
We have our Sub Zero model 650 frig set to 35 degrees, our usual temp, but suddenly it won't get lower than 50. Freezer seems fine.
Check for a fan motor in between the freezer and the fridge. Or you have a block of frost in there shutting off air flow.
Jun 28, 2009 | Sub-Zero 650 / O Bottom Freezer...
I have a danby kegerator that is spitting foam new keg settled for 3 hourd temp 38 3/16 line psi 9.5 help
Turn off the co2 for now. Turn it on when you need it, but start at a much lower pressure like 2-4 psi. Adjust pressure as needed.
Mar 22, 2009 | Danby DKC646BLS Full Size / Pony Beer Keg...
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
Beer box tempature control not getting cold enough to temp. specs
check the vendilation condition/temprature out of the freezer
Nov 17, 2007 | True TD-95-38-LT Beverage Cooler
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
212 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
