Question about RTO Atwood Water Heater - 6 Gal LP
Wont Stay Lit
Replaced Igniter will ignite will not stay lit
  • Anonymous Apr 28, 2009
    No thermo couple. T-Stat if bypassed it will stay going , one of those pre-set disk type, I will locate one and see if this solves it.(did meter it kind of ifish) Thanks willet you guys know of it worked
  • 74 Answers
I would suggest that you replace the thermo-couple. It is a long, slender copper "wire" that runs from the control unit to inside of the unit. THe thermo couple's job is to regulate the pilot light and the lit flame as well.
They generally cost about $10 and take 10 minutes to replace. Some of them are reversed threaded (rights loosen, lefty tighty) and some of them are regular threaded (righty tighty, lefty loosen). TUrn off the gas supply at the meter or an external valve and remove the thermo couple by unthreading it at the control unit. Bring that with you to the hardware store (lowes or Homedepot) to make finding the correct one a simple task.
I hope this helps.
Posted on Apr 25, 2009
Will not light. how do i know igniter in correct position
If its in its sheet metal holder and facing up it should be ok
Are you switching the red knob to pilot and holding it down keep it down while lighting and for 60 sec then let it up slowly and turn to on.. then it should stay lit and main burner should lite
Hope this helps Mike
Jan 19, 2016 | Water Heaters
My water heater will not stay lit.
Make sure that you used the correct thermocouple. If so then you probably have a bad gas control valve. Also make sure that there is a drip leg in the gas line.
Good luck,
Marty
Dec 06, 2012 | Whirlpool Water Heaters
Pilot wont stay lit on waterheater. I replaced Thermocouple and that did not fix it. It will stay lit on vacation setting.
Most gas water heater problems can be fixed with yearly service that cleans burner and burner parts, checks gas pressure and bleeds air out of gas line, cleans air intake, and checks for venting and air intake problems.
Open following links for resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Jul 27, 2011 | Water Heaters
Richmond power vent will not stay lit, the bunrer will lit than after about 5-10 min. it goes and tries to relite and than goes into lock down. after it about 5 min. you can reset it and it will do the...
Richmond-Ruud-Rheem
It sounds like you've read the manual.
And cleaned the burner parts according to manual.
You replaced thermal reset, but system is still tripping, so either the gas valve and tubing are bad, the thermocouple is bad, or there is a problem with gas pressure, or gas line.
Post question on pro water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Apr 08, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Just installed a 425 hn, the igniter clicks and the pilotflame goes on and off at the same rate as the igniter clicking. The main burners will not kick on. Checked all the electrical connections, checked...
I am not aquainted with the Bosch..... But it is a heater. I am going from past experience with gas furnaces and how the process works..... You said that you can get the pilot to stay on if you unhook the Main Gas Valve wire. Do you have 24 Volt power on that wire to Common? Does this have a Flame Sensor? Maybe it got damaged. Does it have a good ground from the burner to the ignition control module? Does that wire to the electro valve go into a plug that plugs into the ignition control.... Maybe that pin is not making contact to the board. Hope this helps If no one else answer right away repost Or call and see if you can get Tech support from Bosch..... I know how frustrating it is you buy something brand new and it doesn't work
Feb 01, 2011 | Bosch 425HN NG Tankless Water Heater
My pilot wont stay lit i cganged the thermocouple it worked for a couple of day now the pilot wont stay lit again
Make sure ALL covers are in place. Watch the pilot flame. It should not move around. If it does, there's a draft blowing it out.
Oct 23, 2009 | Water Heaters
Pilot wont stay lit
Check the thermocouple,Its is a flame senser.It will not stay lit if it is bad.
Oct 04, 2009 | Water Heaters
Pilot light will not stay lit
your thermocouple needs to be replaced. they are available at any hardware store.
Sep 16, 2009 | Water Heaters
RTO Atwood Water Heater - 6 Gal LP Logo
280 people viewed this question
Top RTO Water Heaters Experts
Donni Steen
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
