Question about KitchenAid Dishwashers
Kitchenaid diswasher model kudw03ctbl2 leaking from pump
  • 25 Answers
The diverter valve at the bottom of the machine is a valve that diverts water to the spray arms. It's a notorious part for going bad and causing water to leak out of the bottom of the unit.
Mine was corroded badly at the switch and leaked at the seal. I purchased a new diverter and removed the unit from the cabinet. Once out I laid down a blanket and tipped the unit over. You can remove the diverter with two screws. Be careful that the electricity is properly off. I did not unhook mine but made sure the switch was off on the wall.
The factory connectors were OK on one side but corroded beyond recognition on the other side. I ended up cutting off the connector and soldering the wires to the small PCB that had the switch on it. The seal is in the bottom of the unit and is a rubber spring type seal. If you just install the new part it will still leak. You need to carefully pry the seal out and clean it up. They install the thing with the spring seal facing the wash water. It gunks up and clogs and the unit eventually leaks. The leaking corrodes the switch and the diverter then fails to properly move.
Carefully inspect and clean the seal. I re-used mine by first using SuperLube PTFE food grade grease on the shaft and seal face. I installed the seal with the spring side TOWARD the diverter. They install it upside down from the factory. Use plenty of lube. The rick is to push the seal all the way down on to the new diverter. The shaft for the diverter has a groove and the combination of the lube, the proper orientation of the seal and that groove keeps the water out.
Once installed on the bottom the seal will be forced back into it's bore on the bottom. Installing the seal into the bottom first does not work. It will leak. Use the above method and it will only push the seal in enough to get good engagement with the seal as well as go in just far enough into the bore to keep it from leaking.
Works like a charm now.
Posted on Nov 18, 2014
2 Suggested Answers
  • 3247 Answers
SOURCE: Kitchenaid dishwasher model KUDW03CTBL2 arms
There is a blockage in the wash pump area which is preventing the water from reaching the wash arms.
The problem could be the chopper unit (item 6) in this diagram. You will have to open the assembly according to the diagram and locate the blockage.
Hope this helps.
Posted on Jun 01, 2011
Kitchenaid kud124se diswasher manual
The owners manual can be found at http://www.manualslib.com/manual/722766/Kitchenaid-Kud124se.html#manual. If you remove the bottom panel there is a service diagram tucked in a plastic sleeve that is affixed to the back of the panel (the L shaped panel, not the flat one).
Oct 03, 2012 | Dishwashers
Kitchenaid dishwasher model KUDW03CTBL2 arms do not turn
Hope this helps.
Jun 01, 2011 | KitchenAid Dishwashers
My kitchenaid diswasher will fill and drain with water but when the wash cycle starts there is a buzzing sound and nothing happens. Model 310253306 about 13 years old. The was cycle not working was not a...
The buzzing sound would be the motor trying to start and it not being able to turn...
either something is stuck in the pump and holding it from not starting or the motor its self has gone bad and will not start.
heatman101
Apr 23, 2011 | KitchenAid Dishwashers
I have a Kitchenaid washer model # KAWS750L, leaking at bottom
The most common leak in a KitchenAid washer is from the water pump. The easiest way to see is slightly tilt it up with a small load. If there are many clothes and water in the tub it will be to heavy. Get a light, and tilt the washer up a few inches. Prop it up with something even. Now, lay on the floor and as the washer is running watch for the water leak. The pump is at the front of the washer, directly in the middle. so it's only about 1-2 inches behind the front of the cabinet. I would be very surprised if it was anything but the pump.
The pump you will need is one of two. I've looked up your model number. After the KAWS750L there is either a Q or a T followed by a number. That letter and number make the difference. This pump can be bought for as low as $40 up to $70. It depends on the pump, and where you buy it from :)
May 28, 2010 | KitchenAid KAWS750L Top Load Washer
Stainless Steel- LitchenAid diswasher will not star
This doe seem that the anti flood system has triggered. This device puts the machiene in pump out mode and shuts off the input water supply.
The device is a safety device that triggers once it detects a water leak (pipe / clamp) and consists of a polystireene float and micro switch at the floor of the washer. First check to see if the float has activated the micro switch and then dry the machiene floor and check for leaks.
Jan 25, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid Diswasher Model kudpo1iilbl1
i am assuming you mean model # KUDP01ILBL1
no they are not prone to breakage unless thumped or subjected to really hard acidic water..
part comes with electronic control
8194200 - Heater Kit
$75-80
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | KitchenAid Dishwashers
Water is not coming out of the top water jets for dishwasher
What is the model of this KitchenAid diswasher and approximatly how old is it? On some newer, energy saving models water is alternated from lower to upper spray arms. But ...
Remove filter that is in the sump area beneath the lower dish rack. Screws will need to be removed to open the area up. Look for blockages and clean filter.
Reassemble and test. If problems remain, it is probably a failing pump motor and will require a service call.
Mar 30, 2009 | KitchenAid Dishwashers
Kenmore diswasher was runing fine till i found leak in disposal
Took plug out of new garbage disosal.Reading installation pages afer installation can be costly?Thanx
Jan 10, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Diswasher now leaks noisy kichenaid
If you could be more specific about the problem which you are encountering then i may be able to help, it sounds like its not to serious.
Jul 10, 2007 | KitchenAid KCMS145J Microwave Oven
Dishwashers Logo
106 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
