Question about Ridgid Gas Portable Air Compressor: 8-Gal.-Powered Orange GP80145SW
Replacing throttle - Ridgid Gas Portable Air Compressor: 8-Gal.-Powered Orange GP80145SW
2005 ford five hundred replaced battery went into engine failsafe mode n will only idle no throttle response I replaced throttle body assembly just sits and idles
try using the scan tool to reset the ECM program
code p 2104 refers to throttle actuator control(TAC) system---forced idle mode ===causes ---wiring--TAC motor ---APP ensor--ECM
code p 2112 refers to throttle control actuatorTAC system---actuator stuck closed ===causes ---throttle body, throttle valve tight/ sticking
or TAC system--circuit malfunction===causes wiring short to positive ---short to ground ---throttle position sensor--- ECM
Feb 21, 2016 | Ford Cars & Trucks
L300 Saturn 2003 trying to replace my throtter sensor. Can't figure out where to start from. Have no idea where's it located.
Your vehicle has electronic throttle control an the Throttle position sensor's are internal to the throttle body assembly ! Your vehicle has two throttle position sensors .
Throttle Body Assembly
The throttle assembly contains the following components:
?€¢ The throttle blade ?€¢ The throttle actuator motor ?€¢ The throttle position (TP) sensor 1 and 2 You have to replace the Throttle Body Assembly !
Disconnect the negative battery cable. Remove the inlet hose assembly from the throttle body. Disconnect the throttle body electrical connection. Disconnect the hose clamps from the plenum-to-runner connector using theJ 43914 .
Remove the intake plenum bolts. Remove the EGR passage bolt. Rotate the plenum up and remove the throttle body coolant hoses, EVAP hose, and vacuum line from the throttle body.
Remove the throttle body nuts. Remove the throttle body.
Aug 05, 2015 | Saturn Cars & Trucks
Throttle body sensor location 2005 uplander
the sensor is part of the throttle body and not replaceable here is the throttle body replacement instructions as you will have to replace the entire throttle body it is a very common issue with these
THROTTLE BODY ASSEMBLY REPLACEMENT
REMOVAL PROCEDURE
  1. Remove the air cleaner intake duct.
120434113
  1. Disconnect the electronic throttle control (ETC) electrical connector (1) from the throttle body (2).
113356645
  1. Remove the heater pipe nut at the throttle body.
  2. Remove only the heater inlet pipe.
113356646
  1. Remove the nuts and the bolts from the throttle body.
  2. Remove the throttle body assembly.
  3. Remove the throttle body gasket.
  4. Clean and inspect the throttle body gasket mating surfaces.
NOTE: Do not use solvent of any type when cleaning the gasket surfaces on the intake manifold and the throttle body assembly, as damage to the gasket surfaces and throttle body assembly may result.
Use care in cleaning the gasket surfaces on the intake manifold and the throttle body assembly, as sharp tools may damage the gasket surfaces.
INSTALLATION PROCEDURE
113356646
  1. Install a new gasket, if necessary.
  2. Install the throttle body assembly.
  3. Install the throttle body nuts and the bolts.
NOTE: Refer to Fastener Notice in Service Precautions.
Tighten the nuts and the bolts to 10 N.m (89 lb in) .
113356645
  1. Install the heater inlet pipe.
  2. Install the heater pipe nut to the throttle body.
Tighten the nut to 25 N.m (18 lb ft) .
120434113
  1. Connect the ETC electrical connector (1) to the throttle body (2).
  2. Install the air cleaner intake duct.
Feb 03, 2014 | 2005 Chevrolet Uplander
Replaced head gasket now vehicle revs to full throttle when started
check your throttle postioning sensor or just see if when you replaced the gasket if you moved the throttle cable out of position
Feb 15, 2013 | 1999 Jeep Cherokee
1990 lincoln continental throttle stuck wide open
make sure nothing is caught holding the plate open,disconnect the throttle cable from the throttle valve at the intake.if the throttle closes then i would say you have a problem with the cable itself and will need to be replaced.make sure there is nothing caught at the gas pedal that is holding open.if the throttle stays open then you may have a problem with the throttle shaft(dirt build up),bent shaft,damaged throttle plate,loose plate(has screws holding plate in position)on the shaft.it could also be a bad tps sensor(throttle position sensor)that is damaged internally and needs replacing,as it is fasten to the opposite of the throttle shaft from the cable.if you remove the screws(note position of sensor and screws on sensor)and remove the tps and the throttle is not stuck then this is probably the problem and needs replacing.
Jul 07, 2011 | Lincoln Continental Cars & Trucks
I need too change right side grip on my 2005 heritage softtail any diagram thax,s
I'm sorry but I can't send a diagram via this site. I have no idea where I can get a diagram either.
But, to replace the throttle grip on your Softail, you'll see the not only are you replacing but you're replacing the throttle sleeve as well. This actually makes it easier.
To replace the grip, first loosen the throttle and idle cables as loose as you can at the adjusters close to the throttle grip. Then remove the screws that hold the two halves of the throttle switch housings together. Carefully seperate the housing halves as much as the wires will allow.
You'll see the cables coming up and connecting to the throttle sleeve. Each cable will have a ball and a ferrell on it. Work both cables loose and slide the throttle sleeve off the handlebar.
Now, lubricate the inside of the new throttle sleeve, the cable area of the throttle sleeve and the handlebar with fresh white lithium grease. Slide the throttle sleeve up on the handlebar and work the cables back into the throttle sleeve. Be careful not to lose the ferrells. They must be in there for the throttle to work properly.
Once you get the cables installed into the sleeve, put the switch housings together and install the bolts. Before tighten the bolts slide the throttle up onto the handlebar until it stops. Then back if off about 1/8 to 1/4" or so. Tighten the bolts. Readjust the cables leaving just a bit of slack in the throttle cable.
With the engine off, twist the throttle to wide open throttle and let go of the throttle grip. The throttle should snap shut. If not, loosen the cables a bit or back the throttle grip a bit further off the handlebars. The throttle grip must work correctly or serious injury or death may result. This job must be done correctly. It's not difficult just make sure it's right.
Good luck
Steve
Aug 04, 2010 | Harley Davidson FLSTC Heritage Softail...
Throttle sticks open
Replace the throttle. The throttle in these scooter are very cheap and wear out quick. You can find a throttle replacement at:
electricscooterparts.com
Aug 02, 2010 | Razor E100 Electric Scooter
How do i install the inner throttle cable on a 1973 flh and get the length right?
If you're talking about the old style throttle cable that is internal of the handlebar, it's pretty straight forward. Remove the throttle grip, the rollers and pin for the plunger. Pull the plunger out bringing the old throttle cable with it or at least out far enough to loosen the small set screws that lock the cable in. Now, run the new cable through the outer housing. put the end of new cable into the plunger and tighten the set screws. Replace plunger into the handlebar, replace pin and rollers, replace throttle grip. Now, set the throttle to full closed posititon. Move carb throttle lever to full closed position. With throttle cable through clamp tighten screw securing cable. Check for proper operation of throttle mechanism.
Aug 08, 2009 | Harley Davidson FLHT - FLHTI Electra Glide...
Ridgid Gas Portable Air Compressor: 8-Gal.-Powered Orange GP80145SW Logo
15 people viewed this question
Top Ridgid Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Ridgid Air Tool and Compressor Expert? Answer questions, earn points and help others
