Question about Samsung DVD-V8600 DVD Player/VCR
The unit will not load - Samsung DVD-V8600 DVD Player/VCR
1995 Honda accord ex v6 automatic transmission of code p1298
Electric Load Detector Circuit High Voltage
Possible causes - Faulty Electronic Load Detector Unit - Faulty Engine Control Module (ECM) - Electronic Load Detector Unit harness is open or shorted - Electronic Load Detector Unit circuit poor electrical connection
Possible symptoms - Engine Light ON (or Service Engine Soon Warning Light)
P1298 Honda Description The Electric Load Detector (ELD) measures the main current flow and sends that signal to the Engine Control Module (ECM) to command the alternator charging system to get fuel efficiency and decrease the drag of the engine when starting.
Aug 09, 2016 | Honda Cars & Trucks
Unit suddenly will not load disc...possible reasons?
EASY AS PIE.......REPLACE THE OPTICAL LENS OF THE PLAYER IT MUST BE THE EXACT PART N TYPE NUMBER AND PLAYER WILL PLAY AS NEW
Oct 08, 2015 | Televison & Video
Www humanservices gov au
The 1298 code can mean any of the following-
Read more: http://helpforcars.net/obd_codes/p1298_honda.html#ixzz33k3627nT
Jun 05, 2014 | Cell Phones
What is 1999 honda accord 1298 code
Hope this helps the 1298 code can be -
Jun 02, 2014 | 1999 Honda Accord
Washer Spin Cycle doesn't work - sometimes
Hello T Wright - Based on the symptoms you are describing, it sounds like more than likely the unit is sensing an out of balance load, which could be too light or to heavy of a load, and the unit will not advance to high speed spin. However, often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Apr 13, 2013 | Frigidaire GLTF2940ES Front Load Washer
Wiring diagram for a MCG shower comsumer unit ref no SU6340 or how to wire up this shower comsumer unit from load to supply
Aug 23, 2011 | Watts Washing Machines
The drum doesnt appear to be level
If the unit is a front load: many front load washers have an angled tub towards the back. If however, it has changed from recently; you will want to look at the shocks underneath the unit to see if one is broken.
If the unit is a top load and has the tub off to the side a bit, then a off balence load may be the cause.
Aug 29, 2010 | Washing Machines
Ps3 will not load cd's dvd's or games. loading icon comes on but disc's dont load. when i take disc out loading icon stops but does not go away. it had the newest update.
Could be drive unit, Try unplugging unit and see if unit resets itself. Estimate cost to fix $39.99 3-4day sending unit to us with 1yr warranty
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
It will not run 2 110 units at once, with full power. It has only been started twice, to exerise it. Is there a way to to get full power that I'm not doing?
. we found in approximately 2006 389 of this unit has improper wiring behind the control panel. have your unit check out fri-st. buy applying and load and over load test buy a pro. also after running for a shot time what we call a brake in time rune's out of sink. needs to be recalibrated. We have set them to 3645 to 3698 rpms to achieve 60 hz 125 vol /250 vol no load in order to maintain 120\240 full load. we use a gen set test station calibration unit to set all units. the unit is set at factory 3600 rpm 60hz 125 to 130\250 no load. good luck
Oct 10, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Problem with tom tom 730
suggest reload tom tom software on to memory card but format card before doing so
Aug 20, 2009 | Tomtom GO 910
Samsung DVD-V8600 DVD Player/VCR Logo
24 people viewed this question
Henry  Thomas
Henry Thomas
