My CanonImage Class MF4690 Laser Multifunction has an error message that says Toner is not set Insert Toner. I have taken it out and put it back multiple times. I even bought a new toner cartridge and it didn't help, what do I do.??
  • 483 Answers
its the paper tray ! Take out all the paper, re-insert ..
let me know if this worked.
Thanks
Fame !
Posted on Apr 24, 2009
Imageclass mf4690 has streaks in copies
Several possibilities: if copying using the ADF - clean the glass under the ADF feed. If a print is the same as a copy - check the toner cartridge. This type of cartridge collects heaps of junk in the waste chamber which interferes with the print when nearly empty. If neither of those - dust on the imaging scanner = refer to service dude.
Jul 28, 2014 | Canon imageCLASS MF4690 Multifunction...
How do you set the toner cartridge on a Canon Image class D1150
Try printing a test page first. 2) Shut down printer then re-start. 3) Printer on, re boot the PC. If nothing works, take cartridge out and start over when the printer is off. No help! Then you need real help because your memory is not working properly or an electrical glitch in the mother board or cord.
Aug 09, 2012 | Canon Image Class D1170 Laser...
Canon MF4690 offline
double click on printer print queue opens make sure all print job is cancled
the click file and set printer online cabel must beconnected.Left click on printer and make sure you select the corect printer port or above will not work
Mar 13, 2012 | Canon imageCLASS MF4690 Multifunction...
Mf4690 service manual
Free download of Canon imageCLASS MF4690 User Manual. Troubleshooting help from ... We hope you like our service. Recommend it to your ... Copying. • Basic Copying Method. • Scan Settings. • Image Quality. • Density. • Zoom Ratio ... www.retrevo.com/support/Canon-MF4690-Multifunction-Printers-manual/id/1304dj683/t/2/ www.retrevo.com/support/Canon-MF4690-Multifunction-Printers-manual/id/1304dj683/t/2/Hope this will help you
Jan 30, 2012 | Canon imageCLASS MF4690 Copier
Canon image class MF 4150: it is flashing, message says toner is not set insert toner. Toner has been inserted, it was working this morning, I printed documents fine, now this message. I have taken the...
spacer.gif If you removed and reinstalled toner correctly several times and this error code is flashing, you need to try another new toner cartridge, even though the other one may seem still good to you. If this doesn't remedy problem the Troubleshooting section of the Canonusa.com website says to call 1-800-OK-CANON.
Jul 16, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
The error code says "Toner is not set". Removing and reinstalling the toner cassette does not resolve the problem. Any ideas?
To clear this message: remove toner cartridge, look into the cavity and locate the contact that matches the contacts on the FX-9 toner cartridge.
It is on the left side of the machine.
This contact is probably caught in the down position or stuck behind the plastic.
You can wiggle it out by flexing the spring just below it.
This should allow it to spring back into place.
Now replace the cartridge and all should be fine.
hope it works for u
all the best !!!!
Apr 07, 2010 | Canon imageCLASS®­ MF4690 All-In-One Laser...
Canon MF4690 keeps displaying 'toner is not, set insert toner...'
Hello
I think it is firmware problem.I only found firmware update tool for MF 4150.I am not sure this is also for 4690 but i think i do this before for this machine and it works.So you can try it.It can also be a problem with cartridge contacts so yuu can try to check it.
Here is the link - in drivers software tab :
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=14444#DownloadDetailAct
Jul 29, 2009 | Canon i-SENSYS MF4140 All-In-One Laser...
Toner is not set Insert toner. Toner is set.
toner is like the catridge.. i think yu ve an laser printr.. yur toner is removed or else loose.. yu shd fix tat problm... by checkin yur toner.
Jul 06, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Jammed paper
u have remove toner form the printer then u can remove by hand
Jan 16, 2009 | Canon imageCLASS MF4690 Multifunction...
Toner replacement
When this happens it is usually because the paper has misfeed remove paper from cassette tray replace it then reseat toner.
Jan 03, 2008 | Canon imageCLASS® MF4150 All-In-One Laser...
jasbo
jasbo
