Colour tv Videocon model 5437RU, horizontal line is coming but vertical line is not coming
5 Suggested Answers
SOURCE: LG vertical failiure vertical line at the bottom of the crt
replace the vertical driver ic and the proccesor ic
Posted on Nov 25, 2008
mie999s
  • 105 Answers
SOURCE: My videocon 29
this we call vertical problem need to resolder vertical ic or to check on vertical side is there 24vdc supply is coming to ic
Posted on Jun 07, 2009
  • 56 Answers
SOURCE: 29"Colour TV ,Sound Normal ,No Picture a vertical line Appears
Fault in HZ Deflection Stage check yoke also
Posted on Aug 16, 2009
gopakumarg43
  • 75581 Answers
SOURCE: horizontal line comes with no picture when I switch on my tv (Videocon Bazoomba). What may be the problem?
The vertical sweep output section circuit to your TV is faulty. Check and replace all the electrolytic capacitors; 5 or 6 of them; at the vertical output section. Check for any loose solder terminals. Resolder the suspected solder terminals, by applying a little more fresh solder, without making any solder bridge short in between adjecent solder terminals.
Posted on Jun 01, 2012
What is the cause of my 14inch videocon crt tv appears only a single vertical line in the middle
The image on a CRT TV is produced by a beam of electrons which is controlled by a magnetic field to move the beam top to bottom and left to right. A single line suggests that the vertical deflection is working but not the horizontal deflection (left to right). There are a number of components associated with this and requires a competent TV repair engineer to fix. Better to to buy a new TV!
Jul 13, 2016 | Televison & Video
Why I have a thin line across the screen in my TV model Panasonic TC 21. After replacing the vertical IC the horizontal line across the screen reduced to few inches and not as it was earlier. vertica
First, You should to replace by original part, then you should check the voltages on power supply, and check the voltage for vertical IC based on datasheet, also check the voltages on vertical section including yoke and last you should check the ESR capacitors on vertical section.
Oct 13, 2014 | Panasonic TC-21PM10RQ 21" TV
Videocon bazoomba tv circuit diagram
If it shows picture at first, and after some time displays a vertical line at the center of the screen, check the connector that goes to deflection yoke for loose connection at its bard end socket, and check all the solder terminals of capacitors at horizontal output section. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 14, 2013 | Televison & Video
Model no.5437RU vertical line is not appearing, horizontal line is comming
That means you need to replace the vertical output transistor.
Oct 14, 2013 | Televison & Video
Horizontal line comes with no picture when I switch on my tv (Videocon Bazoomba). What may be the problem?
May 31, 2012 | Vizio Televison & Video
My videocon 29'' showing a bright horizontal line in center of screen after 2-3 min of start up, & full picture will not come
Jun 07, 2009 | Televison & Video
Nov 12, 2008 | Televison & Video
LG colour TV RI32CZ10RX problem with picture
My LG tv has suddenly got a problem with the picture. Whilst watching the tv with no problems at all, the picture was suddenly reduced to a thin vertical line down the centre of the screen and an awful smell seemed to come from the tv There is a short ckt in your tv in horl. section. 1 isolate power from horizontal section. 2 check for normal output from power supply. 3 check parts in horl output section a hor.output transistor b diode & cap in h/output trnsformerckt. c check for print. d if all are ok check for eht transformer. e if every thing becomes then reconnect hor output section supply. f put on the set.
Sep 23, 2007 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
