Question about Frigidaire Kitchen Ranges
Hi i have a frigidaire gas cooker model number fg50t11x i need to replace two thermocouplers but i am having trouble locating these i have tried spares companies and also frigidaire direct please can you help
SOURCE: I would like to know
were can i get spare part from for lofra cooker
Posted on Aug 31, 2008
SOURCE: How to replace maintop (cooktop) frigidaire oven FGFG79GBA
To remove the main top first remove the grates,
burner caps and burners. Using a ¼” socket
wrench or nut driver remove the mounting
screws at each burner orifice assembly.
Insert a putty knife or similar tool between the
main top and manifold panel near the outside
of the front corner. Push the putty knife toward
the rear to release the maintop mounting clip.
Repeat for both sides.
When the mounting clips are released the front
edge of the cooktop can be lifted. Make sure
that the orifice assembly does not bind in the
cooktop when raising the top to remove it from
the range.
Lift the front of the cooktop and pull forward to
disengage the back edge from the rear hinge
bracket. The cooktop can now be replaced by
reversing the previous steps.
See Manual at http://www.electroluxtopservicelatam.com/image/Manuals/Services%20Manuals/Preparation/Cooking/30%20Inch%20Freestanding%20Gas%20Ranges%20(5995440277).pdf
Posted on Jan 23, 2009
johnrodgers1
  • 80 Answers
SOURCE: How to replace a thermocouple in a New World
not at all hard to replace just have a few small wrenchs on hand 10mm 7/16 maybe 1/2 in and screw driver. how do you know its a thermocouple problem, theremocouple are on commercial ovens and basic ranges usually a domestic range has a glow coil operating oven and not a thoemocouple
Posted on Feb 05, 2010
SOURCE: hi i have astoves gas cooker, model 600gdoa and i
Stoves 600GDOa - when the glass lid is lifted to start cooking it turns on (anticlockwise direction) the switch, which turns on the gas - unlit. I wouldn't believe it unless it happened to me. At the moment the switch is taped shut but I would like some ideas.
Posted on Jan 17, 2011
SOURCE: I have a frigidaire gas stove model #FGF337AWJ.
I have a Frigidaire lp gas stove model #FGF337AWJ. Igniter glows bright but burners never light. Gas smell not overbearing but noticeable. Oven will heat up but very slow. The problem is intermittent. Any help is appreciated greatly.
Posted on May 17, 2011
I have a kitchenaid model kgrs505xss double oven. The flame in the bottom oven comes on and burns for a very short time, then turns off before the oven comes up to temperatures. What is wrong?
Any gas cooker has a thermocouple that keeps the gas valve open; if the thermocouple no longer generates current (which feeds the coil of an electromagnet) then the gas valve closes and the flame will go out. So check thermocouple. In normal conditions the voltage generate by the thermocouple is low but the current is high.
Nov 14, 2017 | KitchenAid Ovens
G.E. Slower Cooker/Crockpot
Hi Krista, your model number should be located somewhere on the appliance, then try googling G.E. Slow cooker/crockpot model number XXXXXX parts manual pdf. You will need to install Adobe reader for free if you don't have it to read the pdf format. Good luck and have a nice day.
Sep 25, 2015 | Crock Pots & Slow Cookers
Flavel victoriana 50 gas cooker
Standard appliance parts in Sacramento
Jul 02, 2013 | Heating & Cooling
I have an older lennox furnace in my home and it wont turn on. my pilot light has gone out. it is a duracurve from the 60's and the part number is p-3-1011-3. where can i get a owners manual to trouble...
take off the door, locate the gas valve, two tubes are coming off it. small thin tube is the thermocouple. try tighting the thermocouple at thje gas vale and try agian.
Sep 17, 2011 | Heating & Cooling
Rer 55as n type of flame switch that hold gas to
Is this the pilot light you are talking about on a natural gas rice cooker?
On older rinnai rice cooker 5yrs or older. you should replace the Thermocouple part no. 62341
Jan 24, 2010 | Rinnai RER-55AS 55-Cup Rice Cooker
Where is the model # located on my Comfort Glow propane heater?
Just went down in the basement and checked on mine. Looking at it from the front there is a lable on the left side near the bottom. Mine has the model right on the top of the label. CBN18C is my model number, your should be similar to that, only it may have a LP instead of the N mine is natural gas....
Heatman101
Jan 08, 2010 | Desa International CBN30T Central Heating...
I went through that once and believe it or not it was the ignitor. Instead of a thermocouple these new ovens use the amount of current going through the ignitor to prove the flame. Seems like after it gets ot a certain temperature the amps drop off enough to cut out the flame and then it will try to recycle. If it is not that it would be the thermostat but they very seldom go bad. I would reolace the ignitor first I think it will solve your problem.
Nov 14, 2009 | Frigidaire FGF337BC Gas Kitchen Range
Belling G755 Cooker oven wont stay lit
I'll give this a go! With a cooker like this, you depress and then turn the control knob, press the ignition button and continue to depress the control knob for a few seconds. This is because a device called a thermocouple is heated by the flame and you have to continue to depress the control knob so that sufficient gas flows to heat up the thermocouple. If the thermocouple does not get hot or stay hot then the gas valve is automatically closed - stopping the gas. The thermocouple is a 'flame failure' safety device. If the gas gets cut off then the flame goes out and the thermocouple goes cold switching off the gas valve automatically. However, you are having to try and manually keep the gas going for a good five minutes. I would think that there is either a problem with the thermocouple or the gas control valve! Tony www.birminghamelectricsltd.com
Jun 18, 2009 | Belling Solitaire G755 Gas Kitchen Range
Glo-Warm Wall Gas Wall-heater parts...
We had a problem keeping the pilot light to stay on, and this site recommended that it could possibly be the thermocoupler that was causing our problems also. We ordered the thermocouple, put it on,hooked it back up and it worked great! Thank you so much.
ordered thermocouple from www.masterparts.net
Nov 19, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Kitchen Ranges Logo
26 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
