Question about Spectra Trimble GL422 Single Slope Grade Laser with HL700 Digital Readout R
Error code 0081 - Spectra Trimble GL422 Single Slope Grade Laser with HL700 Digital Readout R
Whats south africa zip code
POSTAL CODES FOR SOUTH AFRICA
Place Name Street Code Province FAERIE GLEN EXT 71 0081 Gauteng FAERIE GLEN UIT 2 0081 Gauteng FAERIE GLEN UIT 24 0081 Gauteng FAERIE GLEN UIT 3 0081 Gauteng 245 more rows, 2 more columns
postal codes for south africa - South African Postal Codes in South ...
www.blaauwberg.net/postalcodes_results.php?value=f zip codes in South Africa Google Search
Oct 29, 2016 | Miscellaneous
It boot up to the last point and send an error message or code E000020-0081 then ask you to shutdown and start again please I really need help
that is an error code for a Canon printer not for the computer
it means you Canon Printer needs a drum unit, or a senor
Jun 25, 2015 | Computers & Internet
Error code e000020 0081
google "Error code e0000200081"
lots of answers - mostly it needs a cleaning
Oct 18, 2013 | Canon ImageRunner Advance C5045 Color...
Error code E00002-0081 in Canon IR3170C
you have fixing trouble, to be specific E002 Insufficient temperature rise of the fixing unit.
The non-contact thermistor fails to
reach standby temperature (normally
190 deg C) within 180 sec after reaching
180 deg C.
Try to clear the error by entering service mode:
press *
Press the 2 and 8 keys of the keypad at the same time.
press *
navigate trough service mode : COPIER>FUNCTION>CLEAR >ERR
If these doesnt helps, replace entire fixing assy, its most reliable way to get rid of complications.
Hope that helps!
Aug 19, 2010 | Canon imageRUNNER C3170U Color Copier
Error 000020-0081
The patch sensor is dirty, take out the drum unit. under the itb belt , top left you will see two semi flat blaack plastic pieces. Carefull with your hand you can cram a lint free rag up next to the black shinney belt and the sensors and wipe them off. Use a CLEAN soft cloth to clean these senors off.
When the drum is very old it can cause this error, first thing to do is to clean these senors off. Most of the time it must fix it up.
Jun 01, 2010 | Canon imageRUNNER C3170U Color Copier
Error code E000020 - 0081 in ir C3170 PCL5c
Apr 28, 2010 | Office Equipment & Supplies
E code E000-00-0081
hi, check once again if it's E000-00-0081 code. i just looked in the service manual for that machine and there's no E000-00-0081 code. the only one pointing to E000 is this: insufficent temperature rise of the fixing unit at power-on.
the one pointing to 0081 is:
p-sens-p when value of this position is lower than 255 it will indicate an error code: E020-0081. you can check it in service mode which you can enter by pressing combination: *28*(star-28-star) try specifing some more detailes, e.g. when it occurs
Jul 24, 2009 | Canon imageRUNNER C3170I Color Copier
Canon ir 3100 cn error code e000020-0081
HP Photosmart C 310series-driver Vindows Vista
Aug 09, 2008 | Canon imageRUNNER C3200 Copier
Canon IRC3100 colour copier machine error code
Canon iRC-3100 Color Copier is giving Error code E-000021-0001. can anybody help me?
Aug 01, 2008 | Office Equipment & Supplies
Spectra Trimble  GL422 Single Slope Grade Laser with HL700 Digital Readout R Logo
26 people viewed this question
Top Spectra Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Spectra Measuring Tool and Sensor Expert? Answer questions, earn points and help others
