Question about Troy Bilt 22HP Hydrostatic 46" Riding Mower
Need diagram of belt pattern of the belt that drives the blades
Snow blade assembly-diagram
The H should match up to front and center of tractor.
Dec 18, 2014 | Garden
Belt pattern for blade drive belt on Dixon ZTR6022
Try googling for the owners manual to view that
Oct 04, 2014 | Garden
Need diagram of deck for 2006 super bronco model 6605
I DON'T HAVE IT ON HAND, BUT YOU CAN TYPE IN ON GOOGLE SEARCH "YOUR MODEL # DECK BELT DIAGRAM" TO FIND IT, BUT TO DO IT YOURSELF, JUST REMEMBER THAT BLADES MUST TURN COUNTERCLOCKWISE AND THAT GROOVED PULLEYS MUST FACE THE INSIDE OF BELT AND FLAT PULLEYS THE OUTSIDE OF FACE OF BELT, ALSO REMEMBER THAT SOME MODELS HAVE JUST ONE BELT (DRIVE AND DECK BELT) OR TWO BELTS (DRIVE BELT AND DECK BELT)
Jul 08, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
I need diagram to thread blade drive belt.
Route the deck drive belt between the two inner, forward pulleys and then out and around the outer blade pulleys.
Jul 30, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blade is turning wrong way
The blade drive belt on your MTD edger makes a half twist in its pattern. When the belt was installed, it was twisted the wrong direction. Remove the belt from the blade pulley and reinstall with it twisted the other direction. Before you start the edger again, visually inspect the belt and make sure it is not touching anything other than the pulleys.
Dec 21, 2010 | Yard Machines Red Edger
Belt diagram for a Craftsman 42" riding lawn mower
there are as many belt diagrams as there are mowers. You will need your model number to get the correct diagram. You should find this under the seat or on the very back of the unit. sorry can't help more at this time, when you get this, you can get online and go to sears and you will find it there.
Sep 23, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
I need to replace two belts on mtd mower i have no manual
im guessing your question is about the diagram for the direction of belts and which pullys they go on?
i would google it.
google the qeustion but in qeustion somwhere state that you need the belt diagram 1)engine drive belt
2) mower deck drive belt
Jun 24, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Need drive belt diagram for LGT2654 Huskee
Here is a link to the manual on pages 7, 8, and 40,
Please take time to rate this a fixya
May 10, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Troy Bilt 22HP Hydrostatic 46" Riding Mower Logo
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
