Polaroid webcam hpc 2011
No video, audio works fine
2 Suggested Answers
  • 2992 Answers
SOURCE: Pc webcam ywb-1016, video works, but audio(built-in mic) doesnt
You may have to tell your computer what mic you wish to use ( make it default )
Typical audio set up
Laptop/mic x webcam/mic x Vista x Yahoo Messenger
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Calling and Audio
Set mic and speakers to show Default equipment
Run call up assistant to test audio equipment > Apply > OK
Posted on Jan 19, 2010
what is your question...
Jul 04, 2014 | Computers & Internet
Device not recognized with computer
Seems like Polaroid's drivers are having problems with a lot of people. The fixya link below from 2011 recommends just using an audio cable and the Audacity program to transfer the sound from the device.
http://www.fixya.com/support/t9339639-when_connect_device_laptop_just
Jan 18, 2014 | Polaroid Pdr300blk Voice Recorder
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
My 19 inch Polaroid FLM-1911 900t shows a white screen
your t-con board has failed check shop jimmy/com see uf they have a replacement
polaroids are hard to find parts
Sep 20, 2009 | Polaroid FLM-2011 Television
No sound on webcam video call ONLY
You will probably need to reconfigure whatever software you are using for the video call to pull audio from the Onboard Mic from the Cam. If it is not configured to pull the audio from that Mic on the Cam, it may be looking for audio somewhere else. This is sadly an issue with a lot of Video Chat software applications.
Jun 19, 2009 | Microsoft LifeCam VX-6000 Webcam
Skype - Used to have video but no longer
yeah i understand that and sir have patience and what u can do is that uninstall and reinstall the webcam driver and the software from the computer and alaso disconnect the webcam and then restart ur computer and then instlal the webcam drivers and it should work fine..or dod the system restore back to an earlier time when the computer was working fine...
Jan 25, 2009 | Computers & Internet
POLAROID FLM-2011 REMOTE CODES
My cox remote guide lists for the Polaroid TVs the following codes:
LCD TVs: 1276 and 1316
TVs: 0765, 0865, 1276, 1314, 1316, 1326, 1327, 1328, 1991, and 1992
I hope one of them works.
Sep 10, 2007 | Polaroid FLM-2011 Television
Polaroid LCD only shows green verticle lines?
your picture tube is not blown you are having problem in the color circuit there is an ic that controls that circuit,the tv is also having a vertical problem an ic also controls that circuit you will have to call a tech to repair your tv good luck
Apr 27, 2007 | Polaroid FLM-2011 Television
Computers & Internet Logo
207 people viewed this question
David Payne
David Payne
