Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
F9 fault code - Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
  • Fisher and P... Master
  • 3,247 Answers
This is a controller fault and depending on the conditions of when it occured, may need replacement of controller itself or some sensor which feeds signal to the controller. Usually if fault keeps repeating or is permanently on and turning mains power off and on makes no difference, then you will need a technician to look at it.
Posted on Apr 13, 2014
How do I clear the fault codes ?
How To Fix Maytag Washer Error Code F9 E1 ...
www.appliancerepairlesson.com/2013/.../maytag-washer-error-code-f9-e...
Dec 10, 2013 - The error code F9 E1 will be displayed on most newer Maytag washers and ..... My whirlpool duet wfw94heaw0 gives the error code F09 E01.
KitchenAid f09 error code Dishwashers Questions ... - Fixya
Nov 29, 2015 | Dishwashers
Error Code F9.Q (Touch Communication).
KitchenAid Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Kitchen-Aid-Appliance-Fault-Codes.aspx
Fault codes for a number of KitchenAid appliances, including two and four digit codesfor ... F9 - Oven Door Lock Failure - Check door lock switches and wiring.
Jul 27, 2015 | KitchenAid KHMS2050SSS Microwave Oven
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Jenn-Air Expressions AR141 Electric...
Maytag range fault code F92
There should be some number after the F 9 Error code. And, it would look like this
F9-1 Latch lock upper
F9-2 Latch unlock upper
F9-3 Latch lock lower
F9-5 Latch unlock lower
F9-6 Latch both lower
This is just to give you an idea. But one thing you can try is UNPLUG THE UNIT AND LEAVE IT LIKE THAT FOR AN HOUR OR TWO, AND THEN PLUG IT BACK IN.
Jan 08, 2010 | Maytag MER6772 Gemini Electric Kitchen...
F9-6 fault code on maytag gemini double oven range
I waited until the next morning and hit the cancel button. It cleared the error
Apr 09, 2009 | Kitchen Ranges
Getting F9 Code & beeping
Hi. this fault code represents a door latch fault. You will need to inspect the door latch components. Once this issue is fixed, it will start to work normally. Its nothing serious like a control board or power supply board. Its juts that the door latch components are malfunctioning.
please rate and god bless..
Mar 24, 2009 | Maytag MGS5770 Gas Kitchen Range
I get failure code F9-3
What a scam by service personnel.
-Simply press "Stop/Clear", then gently push the door handle until "Lock" appears on the screen. Press "Stop/Clear" again and the door unlocks itself!
J. Kalicak
Jan 22, 2009 | Jenn-Air JES9800A Electric Kitchen Range
I am getting a F9 on front of my oven
We solved this by holding in the door/light switch, hitting "clean", then pressing stop/clear for about 3 seconds.
Nov 27, 2008 | Jenn-Air SVE47100 Slide-In Electric...
F9 Code
Since I have not heard back from you on this in a week, I will asuume my suggestions have helped resolve your issue. Please contact us back again if you have any further troubles.
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
D3350 - Code F9
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Check: Drain pump, hoses, installation of drain
hose, control unit and wiring.
Jan 19, 2008 | Asko 24 in. D3350 Dishwasher
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
327 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
