Question about Electrolux EOB5610 Ultrafan Electric Single Oven
My Electrolux EOD6335K Oven will not heat up using the fan oven mode It works ok on the normal oven The main oven element has been replced but its still not heating up
  • 1462 Answers
SOURCE: main oven not heating up
fan oven element has gone. it is a circular element and is located behind the back panel of the oven. some elements can be removed with the oven in place but for many you have to take the oven out and take off the rear casing. whichever, it is not a difficult job. element cost about £30
Posted on Mar 29, 2007
SOURCE: Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Posted on Dec 25, 2007
SOURCE: Main bottom oven not working
i solved the problem by replacing element . new one cost 23 euro from electrolux spare parts dealer .1 undo 4 screws of plate inside the bottom oven . [ plate has holes in a circle patern in the middle of it ] . 2 gentle remove plate and expose the element .3 element has 3 srews .undo these and gentle take away from ovens backwall wall this will expose 2 wires that are connected to the element .3 very gentle unclip the wires from element . {grip the clips not the wires } connect new element and replace all screws and outer plate . this worked for me ....... remember to turn off the power to the oven before you go at it .
Posted on Apr 17, 2008
  • 212 Answers
SOURCE: Main oven doesnt heat up. But temp light is on.
replace heating element
Posted on Jun 22, 2009
SOURCE: replacing electrolux eob944 fan oven grill element
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
Posted on Jul 08, 2009
Why does the fan mode on the bottom oven on my zanussi Zou575 not working?
Because in Main Oven Cavity (large) around the convection fan is very powerful ring heating element 2500W (not visible) who works in the Fan mode. Therefore, it is not necessary that all heaters work because it will overheat the oven.
Dado
Aug 25, 2014 | Zanussi Ovens
My electrolux eod33002 bottom oven does not heat up but light and fan work. The top oven works OK
If youhave a ELECTROLUX electric Cooker or Fan Ovenwhich is not heating it could be one of the following problems.
1, If the fan motor in theback of the oven is going round and the temperature light is on (normallylittle red light), but there is no heat then you will probably need a new ovenelement, these are generally very easy to fit and readily available from our websitethese can be tested with a electric meter.
To gain access to the ELECTROLUX element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if you look closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is opencircuit i.e. broken inside the element casing, either way it will needreplacing. Some elements will are fixed from inside the oven and some are heldin place by nuts from the rear of the machine.
2, If your ELECTROLUXfan oven is getting warm but takes a very long time to cook or is burning thefood more on one side than the other, then you need to check if your oven fan motor isworking you will see the blade turning fast if it is ok. if the element isheating but the fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
3. If you have the opposite problem i.e. your ovenis over heating and burning everything then you will need to replace your ELECTROLUXoven thermostat
4, A quite common and easily overlooked answer isif your ELECTROLUX oven is not working at all i.e. noheat and no fan then the chances are that someone has put the oven timer into AUTOmode, simply put oven back to MANUAL mode and all should be working again.
Mar 04, 2010 | Electrolux Ovens
I have a creda collection C362E everything seems to work except the main oven, any ideas?
For all Free appliance repair videos visit our VIDEO TUTORIALS
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 14, 2010 | Ovens
THE FAN IS WORKING ON THE MAIN OVEN BUT NO HEAT
Jan 14, 2010 | Zanussi ZDF490 Electric Double Oven
MAIN OVEN DOES NOT TURN ON HIGH
this could be the thermostat or the main oven element this sheet might help. For all Free appliance repair videos visit our VIDEO TUTORIALS
Jan 14, 2010 | Smeg Ovens
Neff circotherm doudle oven main oven fan working
It is more than likely that the oven element has failed.
You will it located at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Jan 09, 2010 | Neff B1641 Single circotherm super...
It would appear that the main oven element is not working. I had a power cut whilst using the oven recently and have only just realised that the oven will not heat up. Everything else is working ok. If it...
If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
To replace: Turn off power!!
-Remove side racks from oven, then remove rear panel.
-You should now see fan blade and fan element.
-You need to remove oven from cavity, then remove rear outer panel.
-You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
Aug 10, 2009 | Smeg Ovens
Oven not heating up! Fan works. Grill works OK. Don't know what model it is? It's stainless with black hideaway buttons. It's a built-in Neff single oven. We had just roasted a duck, everything was...
Hi, The main problem I find with this fault is the fan element has blown. This usually cannot be seen without taking the fan cover off inside the oven. Thanks.
Jun 15, 2009 | Neff B1641 Single circotherm super...
Sep 20, 2007 | Electrolux EOU6330 Electric Double Oven
Main oven not heating up
Mar 29, 2007 | Electrolux EOU5330X Ultrafan Electric...
Electrolux EOB5610 Ultrafan Electric Single Oven Logo
46 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
