Question about Kenmore Dishwashers
Electronic panel not displaying on Kenmore elite Model 630.1395
    Sergeant:
  • 199 Answers
It might be that the panel itself is bad or there are no power going to the board. Try disconnecting the power by either unplugging the cord or turn the breaker off for phew minutes then tuned back on. Good Luck!
Posted on Oct 15, 2013
2 Suggested Answers
SOURCE: Kenmore Elite: Model 66576962K601.
I had exact same issue. I've called Sears Maintenance. They had to change 2 pieces in UI: Timer KUDS02SRB10 and CONSOLE Assy. Cost 360$ pieces  130$ Job Charge 60$ taxes.
Now It works perfectly, but I bought 1100$ 3 years ago... Really expensive to keep it running.
Posted on Sep 01, 2010
Kenmore microwave hood combination
If you have tried to reset the microwave oven by turning the mains power off and on without success then it is likely the display is faulty.
The only way to repair is replace the control panel board. This can cost a lot of money.
See this site to give you some idea. Best to contact a repair technician and get an idea of costs.
KENMORE ELITE Microwave Range Hood Controller Parts Model 72180839500
Aug 03, 2014 | Kenmore 1.4 cu. ft. Speedcook Microwave...
Kenmore Elite Electric Dryer -- Diagnostic for electronic control "Start" touchpad is 09. What does it mean?
i donot know what 9is but i think its the moter switch or moter try switch first
Jul 19, 2013 | Kenmore Dryers
I have a Kenmore Elite King Size Capacity Washer and it displays an F code. It will not go through a full cycle. What could be the problem? Thanks.
in the back panel you will find a tec sheet with f codes . like f1 f2 f3 f4 f5 and so on but just a F ??? hope this will help mm
Nov 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite speedcook oven Model 63799. F2
f2 error means : -------
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked
------------- if this happens you should check: -----------
1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check and replace oven temperature sensor if necessary
keep updated,please do accept and rate the solution.thanks.
Sep 30, 2009 | Kenmore 63792 Microwave Oven
Kenmore elite trio 24.8 model #596.76603600
may be is the board or or refrigerator door is (ajar)
Mar 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Clothes washer won't drain - digital display shows LD
looking at the tech sheet for this, it appears to be a standard whirlpool top load but with electronic controls, correct? normalling with this type a lid switch is the issue but the electronics would have a different code for this, LD is Long Drain for this model. suspect a transmission but this should help you troubleshoot. go to www.servicematters.com and click technical reference - tech library - tech sheets, enter model minus 110.prefix. this will show tech sheet with diagnostics. this book can also be found inside your console.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
KENMORE ELITE DISHWATER panel went blank but there
Check the continuity of the thermal fuse. It's clipped onto the electronic control inside the console.
Let me know if you need more help.
Mar 12, 2009 | Kenmore Dishwashers
Kenmore Elite drying doesn't work sometimes..
Touch pad is failing.Try not to get any moisture around this touch pad.Biggest mistake for all appliances is the touch pad and water dont mix well.
May 21, 2008 | Kenmore Dryers
Problem with a different range...
Tom, generally a f1 code implies a control problem. The tech sheet gives 3 possible causes. 1. A shorted keypad, solution to replace electronic control. 2. Controls internal checksum has become corrupt, solution is to unplug for 30 seconds, if the code comes back, replace the electronic control. 3. Control has sensed a overheating condition, relay on the board may have shorted out. Each one recommends replacing the control board. The part I have for this model number is 316127903. Says it's grey. Catriver..post back.
Oct 24, 2006 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Dishwashers Logo
64 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
