Question about Brother MFC 6490CW InkJet Printer
UNABLE TO PRINT 44 - BROTHER MFC-J6510DW - Brother MFC 6490CW InkJet Printer
  • 26 Answers
User guide http://download.brother.com/welcome/doc002835/cv_mfc6710dw_use_busr_lx7144001_b.pdf says either a mechanical problem or could be foreign object like paper clip or torn paper inside the machine. Open the scanner cover to check for that.
Posted on Oct 15, 2013
    Problem Solver:
  • 18 Answers
The temperature of the print head driver has risen abnormally.
The head driver chip temperature sensor in the COF detect abnormally high temperature.
that was the error code means. solution Printer head Replace
Posted on May 09, 2015
My printer stopped printing and print only marks unable me urges me 44 I can do or that this problem is due .
Posted on May 06, 2015
pineworks
  • 4041 Answers
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
SOURCE: brother mfc-215c unable to clean?
I have the same problem my printer (a MFC-215C) is unable to clean and when I press Menu/set I do not have "Black print"? So what do I do now?????? HELP... Thanks Nathalie
Posted on Apr 30, 2010
Semi-Driver
  • 434 Answers
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Posted on Jan 21, 2010
  • 583 Answers
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
try this step by step.without missing any thing. thanks
Posted on Jul 13, 2009
scrodamoon
  • 659 Answers
SOURCE: Have a brother MFC 215
this is not a 100% fix but might lead to a fix.
Posted on Aug 02, 2008
Brother print head won't move "mfc j6510dw"
the problem of your printer is sensor found on purge unit.
Jul 31, 2016 | Brother MFC-J6510DW Multifunction Inkjet...
How to remove print head on MFC 1220 printer
You cannot do it yourself. Requires special knowledge and training. Take it to an authorized service center
Apr 20, 2014 | Brother Lc1240 / Lc1220 Set Of 4 Compat...
I have a Brother printer MFC -J625DW. Error "Unable to Print44". Can anyone help me?.. Thank you
Machine error 44, indicates abnormal temp at Printhead, either the main PCB or print head is faulty.
Dec 27, 2013 | Brother MFC-J625DW Wireless All-in-One...
No station id
Its just to input your info to send it over when you transmit fax. otherwyse you dont need it
Oct 09, 2013 | Brother MFC-J6510DW Multifunction Printer...
Brother mfc-j6510dw will not scan
This may help others with scanning issues:
I just bought this and was nearly driven cracked trying to get the scanner to work as it was not talking to the PC, even though as a printer it was working fine. Realised eventually that it was just the Brother Control Centre 4 it wasn't talking to. After hours of re-installing software and updates, etc, nothing worked.
The solution: I went into Control Panel on my PC (I use Windows XP), to the Scanners and Cameras section, and in there the Brother Scanner was visible and could be used from there, Click on it to open the Windows Scanner and Camera Wizard and use that. Further, by right-clicking on it and going to properties I choose the software to start when it talks to the PC. I abandoned the Brother CC4 and set it up to start the Scanner and Camera Wizard if I choose 'Scan to Image' on the scanner control panel, and to open Photoshop if I 'Scan to File' on the scanner. Works fine either way, just make sure you choose the right dpi setting to suit your needs.
Hope this helps somebody else as frustrated as I was.
Aug 09, 2012 | Brother MFC J6510DW - Multifunction fax /...
The black ink won't work even though its new
check if the noozles are on the catridges or on the independent print head. if the print head is seperate from catridges, them try print head cleaning. if you it cant work. then dip the print head in hot water for 5 to 10 seconds. dont dry it just put it back into the printer and try again immedeately. let me know if your problem is fixed
Jun 24, 2012 | Brother MFC J6510DW - Multifunction fax /...
Brother MFC 6490CW InkJet Printer Logo
2,114 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
