Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
190cc 3in1 briggs and stratton mower wont start... new plug and good spark..any ideas..
  • 5 more comments
  • winnette227 Apr 24, 2009
    yes getting fuel to carb
    trying to fire and sometimes back fires..
  • winnette227 Apr 25, 2009
    no plug not carboned up...
    new plug fitted....
    keeps flooding..
  • Dennis Yachimec May 11, 2010
    Need you to pull the spark plug and see if it is carboned up.
    How long has it sat without running? It could be flooded.
    Are you getting fuel to the carburator?
  • Anonymous Mar 12, 2014
    Which engine is built for power trough thick grass. mulches better and has long life
    Sniper:
  • 79 Answers
Take the carburator apart and clean it. Also, clean needle and seat. Please let me know if this helps.
Posted on Apr 25, 2009
  • Dennis Yachimec Apr 27, 2009
    Did you get the lawnmower running?
How to fix lawnmower
what wrong with it if it wont start check for spark at plug if works try squrting starter flood into carb if tries to start rebuild carberator tecuseh engines are bad about clogged up carb with dirt
Aug 16, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
Brand new Briggs & Stratton lawn mower Model 90000 E series won't start.
trry a shot of starting fliud see if it wont start then make sure your getting a spark to
Jun 13, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
190cc 675 sears push LM. Irene put it under water. Drained carb and crank. removed and cleaned filter. New gas. Won't start. Got a little pop with starter spray. No pop at all?
Did you drain fuel tank before refilling with fresh fuel? Drained carburator bowl good, drained crankcase and refilled with fresh oil good,removed air cleaner and dried out good. One question for you , did you remove spark plug and drain any water that may have gotten into your cylinder through an open valve? There could be water sloshing around in the cylinder, gas and water will not fire, and water on spark plug wont allow plug to spark. If you need any more help please get back to me , I believe this is the first under water problem I've encountered. GOOD LUCK.
Sep 07, 2011 | Briggs & Stratton 190cc 875 Series OHV...
I have a Craftsman, 6.75hp, SP, model #917.377580 lawn mower. Was running good but, won't start any more. Don't know if or where the fuel filter would be. Thinking it might be the solid state...
If you know that you have a good plug, and you don't have spark at the plug, then it is a bad Ignition Coil (Module). If you need further help, let me know.
Good Luck!
Jim
Aug 16, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
No spark-magnets ok on flywheel-new coil-good spark plug
unhook the wire that comes from coil to shut off switch and see if spark then
May 16, 2011 | Briggs & Stratton 190cc 875 Series OHV...
It wont start. Fuels good. Gets a spark, although plug looks oily. Air filter was dirty, have new one. Still wont start with filter off. Tried starter fluid. Manual says maybe excess oil in engine. If so,...
If you have no sign of life with starter fluid, there's no spark in the cylinder.
If the plug is oily, it may spark in free air, but not under compression. Try a new plug first.
Excess oil won't prevent the engine from starting, but it will spew oil everywhere if it's overfilled. Just check the level with the dipstick (on level ground), and pour any excess out of the filler tube.
Aug 07, 2010 | Briggs & Stratton 190cc 875 Series OHV...
Craftsman briggs and stratton 6.50 190cc lawn mower- wont start unless i pump the bulb. I have a new gas, new air filter, new oil, and new spark plug.any other suggestions?
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
May 25, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Gap setting for briggs-stratton 6.5 lawn mower
I believe it is 0.040 on a regular spark plug gapper
Nov 07, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
1,927 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
