Question about Ricoh Office Equipment & Supplies
Ricoh mp 1100 error 542 - Ricoh Office Equipment & Supplies
boyrevel
  • 71 Answers
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
Bubbabear64
  • 2794 Answers
SOURCE: ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Posted on Jul 12, 2008
  • 86 Answers
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
jonniewalker
  • 1031 Answers
SOURCE: copier ricoh aficio 450 error code SC 542-00 ?
  • SC542: Fusing temperature warming-up error
  • check the fusing unit -
    The fusing temperature does not reach the fusing standby temperature within
    125 seconds after the main power switch is turned on.
    - Possible causes -·
    Fusing thermistor defective or out of position
    · Fusing lamp open
    · Fusing thermofuse open
    · BICU defective
    · Power supply board defective
    · Poor fusing unit connection
    troubleshooting
  • to reset the error enter the sp mode c 107 ca then use the sp np 5-801 then pres ok
Posted on Mar 18, 2009
ricohmaster
  • 10 Answers
press clear (yellow) and press 1,0,7 and press and HOLD the stop button 5 secs. (red) press 1 when u see the copy sp mode and press 7 (datalog) and press ok, look for the sc/ jam counter reset. press the execute 2x. turn of the machine in the main switch (orange switch on the lower front side) the shortcut mode is by pressing 7807 na press execute
Posted on Sep 19, 2009
WHY RICOH AFICIO MP 171 SPF IS SHOWING SERVICE CALL SC 542.
Reseting SC 543 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Oct 18, 2016 | Ricoh Office Equipment & Supplies
Ricoh aficio mp 2045 sc 542
Description Fusing temperature warm-up error
The fusing temperature does not reach the fusing standby temperature of 45C (113F) within 9 seconds [for the B003/B006 (35 cpm)]/14 seconds [for the B004/B007 (45 cpm)] after switching on the main power or closing the front cover, or 40 seconds after reaching 50C the fusing roller does not reach warm-up temperature. Causes • Fusing lamp defective • Poor fusing unit connector • Thermistor warped or broken • Thermostat has tripped • BICU defective • Power supply board defective
Jan 04, 2015 | Ricoh Office Equipment & Supplies
How to fix SC555 error ?
Same way you reset 542 enter service mode and cycle power
May 21, 2014 | Ricoh Aficio Office Equipment & Supplies
Error code sc542
Fusing Temperature Warming-up Error
• Fusing thermistor defective or out of position
• Fusing lamp open
• Fusing thermofuse open
• BCU defective
• AC drive board defective
• Poor fusing unit connection
Jan 20, 2014 | Ricoh Aficio MP 161 Black and White Copier
Jan 17, 2009 | Ricoh Office Equipment & Supplies
35 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
