Question about Roper RT21AKXKQ Top Freezer Refrigerator
Top freezer not freezing - Roper RT21AKXKQ Top Freezer Refrigerator
    Sergeant:
  • 199 Answers
Unplug your fridge and let it sit for about 5 minutes. Also you may turn the temperature dial to "0", then turned back on. The problem may also lay on the actual fan located in the center column that joints the top freezer with the lower part of the fridge. If the fan is not turning you may need to replaced that. Good Luck!
Posted on Oct 15, 2013
Top of freezer not freezing
your cooling matchine get damaged,there having a cooling matchine.
Mar 25, 2013 | Daewoo FRSU20IA Freezer
Daewoo FRN-U20IA top of freezer compartment won't freeze
It was the fan at the top of the freezer that had stopped working after 3 years, therefore the freezing air wasn't getting to the top of the freezer. From the inside, unscrew light unit and unclip, pop out two circular discs at top and unscrew one screw. Unscrew 2 more screws and prise the back panel off. (Arrows mark the clips). Pull off fan, take out motor, replace (keeping rubber bits) and push back fan with a bit of nail varnish on spindle. Put everything back together. Turn on, depress door light switch and after 30 seconds fan should rotate. You can buy a fan on eBay or from www.4daewoo.co.uk for about 40 pounds.
Feb 27, 2013 | Daewoo FRSU20IA Freezer
The top of the freezer is not freezing.
Normal 0 If the bottom of the freezer is freezing (but only just), but the top is just above freezing, then your problem may be either your defrost timer or the defrost heating element. You'll need a thermometer to determine how cold (or not cold) your freezer is getting. Usually a freezer is happiest when it's full, so being too full is likely NOT the problem (there is room for air to circulate, right?).
If you're handy, you can troubleshoot the problem yourself by following the suggestions found here, as that may at least identify the problem. Replacing components inside your refrigerator isn't incredibly complicated, but if you're uncomfortable with taking things apart, you may be better off seeking the help of a properly trained professional.
Hope this information helps!
Aug 24, 2009 | Freezers
Freezer not Freezing
the air flow is blocked betwen fridge and frezer or even the small fan is burnt out
Jun 22, 2009 | Magic Chef CTF2125 Top Freezer...
Items in the back of the refrigerator freeze.
is this something that has just started happening? Most kenmore top freezers have a vent that allows cold air from the freezer into the refrig through a vent located on the back wall in the center of the refrig section. if packages are pushed up under this vent they can freeze.
If you have widespread freezing in the refrig setion then a temperature control could be the fault. thanks for using fixya. Peyton..
Feb 17, 2009 | Kenmore 72992 / 72994 / 72999 Top Freezer...
Freezer not freezing like it should
Yes that is hte panel in which "skeeter 140 " was refering
Jan 14, 2009 | Frigidaire FRT18FS6C Top Freezer...
Top half not freezing
If this is not a frost free unit , it probably has a freon leak. This is usually not worth fixing in a deep freeze. If it is a frost free unit the fan could be bad. This is an easy repair.
Mar 26, 2008 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Roper RT21AKXKQ Top Freezer Refrigerator Logo
73 people viewed this question
Top Roper Refrigerators Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Sal DeAngelo
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
