Question about Ovens
Ow to install the safari electrical submeter properly?
What is the power requirement for installing a Simpson 2001 66-647 thermaflow freestanding oven?
For Electric Range - 220 - 240 volt, 60 hertz, properly grounded circuit with 40 amp breaker or fuse protection with #8 gauge wire. With a 50 amp breaker, # 6 gauge wire is required.
The owner's manual below mentions the wattage. (download the document, hit CTRL-F on your keyboard, type in wattage.) You might contact the manufacturer or for that matter the electric company servicing you.
https://john.daltons.info/appliances/Simpson_2001_models_68-642_and_68-646.pdf
Jun 11, 2017 | Ovens
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
The timer/control module on my jennair electric oven keeps blowing up. I installed a rebuilt unit it worked fine for 2-3 minutes then blew up
There's a short somewhere in the oven. You need to find this. The timer issue was the result of the other issue.
sometimes the issue is easy to locate as there will be marks on the item indicating a problem. Sometimes it's a component that need to be replaced that's not so obvious and needs to be tested for the proper intake and output voltages.
Jun 27, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
Oven wont' work regardless of proper installation
Hi Have you set the clock The way to do this is in the manual if you dont have a manual you can get one here http://www.manualsmania.com/download.php?link=65af94c83ee1528c47d230faaa77ad4c9697 Regards Geoff Stove Recyclers
May 28, 2011 | AEG D2100-4 Electric Double Oven
My electrolux EOD5330 fan oven tripped a fuse. ow it won't heat. The fan still works
Most likely problem is the the oven element short circuited which caused the fuse to blow. When power is restored everything generally works except for the element. If you check the element you may find a blow hole in it.
Feb 10, 2011 | Electrolux EOD5330 Ultrafan Electric...
Older Ge F4 error Code
Your oven temperature sensor is bad and must be replaced.
Feb 28, 2009 | GE JTP85 Electric Double Oven
Installing ge profile double oven not convection in new build trying to find out electrical requirements ( size breaker 50,60amp ?)
You must use a three-wire, single-phase A.C.
208Y/120 Volt or 240/120 Volt, 60 hertz
electrical system. If you connect to aluminum
wiring, properly installed connectors approved
for use with aluminum wiring must be used.
That means that you ned a double 40 amp breaker.
Good Luck
Jan 18, 2009 | GE Profile JT952 Electric Double Oven
Belling fan assisted ovens
no you can't connect a double oven to a 13a socket!!
needs a proper cooker outlet wired back to the consumer unit
Sep 29, 2008 | Belling XOU592 / XOU593 Electric Double...
Installing Amana RV oven (propane)
it should have one in the owners guide under instalation instructions if not i can get you one e mail me at b4829@yahoo.com
Jan 27, 2008 | Ovens
Electric oven
was there a lightening storm (that may have zapped the micro-controller chip) prior to the problem?
May 06, 2007 | Maytag MEW5530D Electric Single Oven
Ovens Logo
174 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
