Question about Vacuums
Hoover Rush Pets TCR4233 how to put back together filter and dust collector
5 Suggested Answers
  • 833 Answers
SOURCE: freespace pets cylinder hoover 2000w tfc6207
It is possible that the belt is broken.
Posted on Jan 02, 2008
SOURCE: filter keeps clogging
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=719779
Generic problem for all Vacuums
Filter keeps clogging
Posted by ozandcaza on Jun 29, 2008
Report abuse
Dust etc collects in the filter above the dust container. The dust container remains empty. Hoover then over heats and cuts out. Collect in replaced new filters in Hoover but problem still remains.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. My question is how old is the Hoover vacuum? If it less than a year you should really see an Authorized Hoover vacuum cleaner dealer that the problem might be covered under a factory warranty. This should not be happening and it sound to me like there is a clog somewhere in the vacuum fill area that is causing it to do this to you and the vacuum. You are lucky that you have a thermal switch that does shut it off. If not and it is over the one year factory warranty then you should see a local vacuum cleaner dealer in your area or contact Hoover Cust Serv @ the website and or phone 3 listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 03, 2008
  • 694 Answers
SOURCE: I have a new Hoover
First, complete detach the hose from the machine. Drop a small coin through the hose to ensure that's where the clog is. If the coin doesn't go through, connect wrong end of hose to the intake and turn vacuum on. This should loosen the clog and possibly clear it completely. If not use an air hose or shop vacuum exhaust to blow the clog out. Borrow one if necessary.
Check inside intake for a clog between hole and filter. If it's clear, check the tube in the power head. Because of the bend there, it's a good (bad?) spot for clogs. This can usually be cleared by using the hose with a nozzle to vacuum it out. Or try needle nose pliers to grasp and pull out.
Posted on Dec 03, 2010
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: Just purchased Dyson DC33. There
    I can confirm that the air you've noticed blowing out of the cleaner is simply the HEPA-filtered exhaust air being expelled back into the room. It's a feature of the cleaner's design, and is nothing to be concerned about.
    If you have any further questions about using or maintaining your Dyson cleaner, please get in touch with us directly - you can call us free on 08002980298 (UK), or 1866MYDYSON (US). Alternatively, for step-by-step maintenance and troubleshooting guides, visit www.dyson.com, and click on 'Support'.
    Kind regards,
    Jack
    Dyson Online Customer Support
    Posted on Sep 13, 2011
    Top filter keeps clogging up??
    Just make sure the rubber gasket is secure at the bottom of the dirt cup if it rides up the dirt will go straight up to the filters
    here is the hepa that should be change when it is dirty
    Hepa Filter Hoover U5780 WindTunnel Bagless 93002360
    Dec 07, 2015 | Hoover U5780900 Bagless Upright Cyclonic...
    I took the filter out of my Windtnnel Pro Pet to clean it (not with water) I put it back in and now the vacuum wont turn on.
    I'm going to guess that when you put it back together it didn't quite go back in correctly. There could be a switch that prevents it from turning on if the filter is not installed. Make sure that it is seated correctly. I hope thats all it is.
    Dec 27, 2014 | Tti Hoover 4010100Y 3-Pack Type Y...
    Hoover nano cyclonic shut off while in use/no suction when turned back on
    That is more than likely the problem, NEVER put wet or even damp filters back into your vac
    Oct 23, 2014 | Hoover Nano Cyclonic Compact Bagless...
    I have a hoover bagless windtunnel tseries paws. I recently cleaned all the filters & put back together & when I did I thought the red would turn to green like it was reset so wouldnt be showing...
    The dirty finder light is a microphone, located in the elbow (where hose secures to machine). The problem is either the contacts on the microphone need to be cleaned (use wire brush) or the switch is full of dust (remove small circuit board from the front (where the light is), with a razor blade carefully pop the cover off the switch box and remove the dust.
    Sep 01, 2011 | Hoover U6630-900 WindTunnel Bagless...
    My dyson ball has no suction ... i turn it on and sounds normal for a few seconds then it sounds like it clogs then no suction but i checked the tubes theres nothing there...
    Take off the dust collector , put the machine somehwere out in the open air and switch it on if the motor runs up to speed then the probelm is inside the dust collector and it is probably a blocked hepa filter
    If the motor does not run clean with the dust collector removed then you need to remove the base plate and check for blockages there
    Jan 25, 2010 | Dyson Ball HEPA Upright Bagless Vacuum -...
    Hoover Freemotion Pets 200W has lost most of it's suction!
    if you take out the dirt cup at the top there should be a half moon orange that releases. inside of this half moon is a washable filter. rinse with warm water and let it dry completly before putting back into the machine. this should restore your suction. hope this helps.
    Jul 31, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
    Freespace pets cylinder hoover 2000w tfc6207
    Dec 31, 2007 | Vacuums
    Upper Filter gets clogged quickly
    You may have to replace the filters, air maybe restricted going thru them. The main filter is part #73494, and the foam #74038. Also make sure the SLINGER/CYCLONE ASSY part #74068 isn't clogged up.
    Jun 10, 2007 | Eureka 5892AVZ Bagless Upright Cyclonic...
    Vacuums Logo
    23 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
