Question about Electrical Supplies
Cooper 7728W-Box seeking instruction manual
2 Suggested Answers
SOURCE: Seeking the CWL1420P wiring and assembly instruction sheet
The sell sheet for this product shows this is a NEMA-14 Twist lock plug rated for 120V - 240V wiring.
To wire the plug:
G is for ground W is for Neutral
The hot wires connect to X and Y
This is simple for 240V ... your red and black wires connect to X and Y, the ground to G, and the white neutral to W
For 120V circuit, the G ground and W white neutral remain the same. I think the black hot wire is X.
A simple tester in the receptacle can confirm this before plugging in the twist-lock
Posted on Oct 09, 2010
Seeking an instruction manual for rca model VR513 VCR
Check with RCA website they might have a free PDF.
Feb 07, 2013 | Televison & Video
I have a cooper comb devces how do i wire i want switch to control the plug
The Cooper combo device requires neutral wire to energize the outlet.
To control outlet with switch, the Hot side of device must have break-away fin.
Remove break-away fin.
Connect jumper wire from switch load side to outlet Hot side.
Open following link for instructions with illustration:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#combo
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electrical wiring or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 20, 2011 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
I just purchased a Cooper Wiring Device 277W-box w/pilot light. The current switch in my home is next to another light switch which operates my hallway light. The other switch (the one I want to install...
Open following link for wiring diagram with written instructions.
Some of your wiring does not sound up to code.
1) Two differences between regular switch and cooper 277
-Different color screws: Regular switch has two brass screws, and either wire can connect to either screw. Cooper 277 has dark, brass, silver screws, and hot wire connects to dark screw, and wire to light connects to brass screw.
-Cooper needs neutral wire connected to silver screw, to power the indicator light.
2) Some of the wiring in your box does not sound up to code.
Bare ground wire should not be connected to black and white wires.
Electrician should check this out.
Probably the ground wire is being used as a Neutral. Bare ground wires and white neutral wires both connect to neutral busbar at main breaker box.
Aug 22, 2011 | Hardware & Accessories
Need a diagram for cooper #277w
I made following diagram based on Cooper pilot light instruction sheet:
Neutral wires are usually the white wires that are twisted together in back of box and covered with wire nut.
If your box does not have neutrals, you can also connect bare ground wire to silver screw until you have time to run neutral wire to box >> ground to anything but ground screw is not code and not recommended.
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on circuit or any do-it-yourself project.
Feb 18, 2011 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
I need the wiring diagram for a Cooper 277W single pole switch with pilot light. The light is to be on when the switch is on. Thanks!
I have 120Volt cooper 277 pilot light switch here in my office.
Dang instruction sheet shows wiring for all kinds of cooper devices.
EXCEPT pilot light switch.
So I tested with multimeter and came up with following:
Key to any wiring device is color of screws.
Hot from breaker box always goes to dark-colored screws.
Neutral always goes to silver-colored screws.
Brass screws are for Hot wires from breaker or Hot going to Load
Green screw - ground
Dec 03, 2010 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
To wire the plug:
Jul 08, 2010 | Cooper Wiring Devices ACE6001V-K "ACE"...
Installing cooper 30A 250V female receptacle.
Correct, assuming red and black are connected to the breakers in the breaker panel, and white is connected to the neutral/ground buss bar in the breaker panel.
Dec 17, 2009 | Cooper Wiring Devices ACE6001V-K "ACE"...
Need owner manual
Depending on the revision date of your scrubber, here are the manual(s) you seek located on this page: http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=5457 Good Luck
Jun 17, 2007 | Dirt Devil SE2800 Spot Scrubber Handheld...
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
