Question about Garden
Karcher kb3030 Karcher 3030 has a faulty on off switch can this be fixed?gordon,stirling
4 Suggested Answers
  • 92 Answers
SOURCE: Karcher KB3030 Pressure Washer
Dear doc doz,
Most probably you have the spill valve stuck in a position that keeps the machine off. This could happen for various reasons. It could get stuck by using plenty detergents or chemicals, without rinsing the machine afterwards. It could happen by leaving the machine under pressure for a long time. Most probably (with all respect) you used to store the machine when not in use, with the pressure still in the system. To fix this problem the machine has to be opened. When you come to the spill valve, you can bypass the micro switch and if the machine works, then it is the spill valve. Most probably it is the spill valve and you have not much expencies to fix the machine. If you do not know how to fix it yourself, I suggest that you take it to an expirienced technician.
Regards,
MG.
Posted on Nov 05, 2008
  • 11 Answers
SOURCE: karcher k2 power washer inlet-outlet manifold cracked along weld
well depends did u use it in cold tempatures if so no it was u. if not then most likely or could have been just a crazzy thought here that there was a electrical discharge when it was pluged in and cracked the block on it but honestly thats 1/10000000000000 chance of happening. or it overheated and cracked it but relistically if its new then just take it back and play dumb or if its still under warrenty play dumb and get it fixed. aslo u can search for a new part on craigslist or ebay. last but not least if its not uner warrenty or new to take back or u cant find a part either thru the ones i listed or by calling the man. ur last resort is to just throw it away.
Posted on Apr 03, 2009
bigomoe
  • 12 Answers
SOURCE: LOST KARCHER INSTRUCTION BOOK, ARE INSTRUCTIONS ON LINE
Here is the offical link to manuals and warranty cards for the residential models of Karcher Pressure Washers
http://www.karcherresidential.com/us/Service/usermanuals.htm
Posted on Mar 04, 2012
Karcher wv50 spare on off switch
If you contact one of the Karcher Centers ( details are on Karcher.co.uk website) they may be able to help.
regards Gary
Aug 02, 2014 | Karcher WV50 Window Vacuum
Water coming out of detergent pipe from top for karcher 3030 B jet wash.When i start using the jet wash there is not enough pressure and water starts coming out of detergent pipe.How can i stop water...
remove deterfent pipe,unscrew detergentnozzle carefully, inside is spring and ball bearing, clean and re-fit, replace if missing. spring on upstream (soap) side
Apr 03, 2014 | Karcher Garden
Water coming out of detergent pipe from top for karcher 3030 b jet wash
DISCONNECT HYDRO OR WITH ENGINE NOT RUNNING DISCONNECT SPARK PLUG THEN RE-LEAVE WATER PRESSURE BEFORE SERVICING the detergent pipe plugs into a pipe on the pump, under which is a spring and ball bearing (stuck open, debris) WEAR YOUR SAFETY GLASSES
Apr 01, 2014 | Karcher Garden
No water pressure on a k 2.99
Faulty pressure switch. Karcher use terrible switches you will need a new one..
Mar 06, 2014 | Karcher Garden
How do you reset a karcher pressure washer
The Knob is broken off of the Plastic Shaft..to the switch assembly.
A new switch assembly is available direct from Karcher.
May 24, 2010 | Karcher K2.26 Electric Power Washer
Electric modelm620 karcher does not start
The bypass valve is most likley jammed. Remove the cover from the machine, then remove the chemical tank. Unscrew the micro switch cover and manually operate the micro switch. If the motor runs the bypass valve is faulty. Replace the valve along with the stem seals on the valve.
Mar 04, 2009 | Karcher Garden
Jan 22, 2009 | Karcher K2.26 Electric Power Washer
Dear doc doz,
Regards,
MG.
Oct 22, 2008 | Garden
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
