White knight 77aw tumble drier won't start
I have a white knight 77AW tumble drier. I recently moved house and think I forgot to empty water drawer. well now the water drawer light stays on and it wont start. I tried removing the back panel looking for a reset switch or drainage plug but can't find one! Don't know what else to do so any help would be much appreciated thanks
  • 116 Answers
SOURCE: Flashing Active Light and not taking fabric conditioner
1: The flashing wash light usually indicates a problem with the door latch while a flashing rinse/spin light usually indicates a problem with your inlet valve. 2: The cold water inlet has 2 independant outlets. The issue that you are describing indicates that one part of the cold water inlet is not opening to allow water to flow to the proper dispenser port.
Posted on Mar 11, 2007
  • 1462 Answers
SOURCE: washing machine problem
at the back of the conditioner compartment there is a syphon. check the tube of the syphon is clear. put on rinse and at the point the conditioner should be taken, open the drawer and check that there is a jet of water into the conditioner area. if not, there are some holes in the roof of the top of the box. these may be blocked. clear with a hairpin or similiar
Posted on Apr 22, 2007
  • 236 Answers
SOURCE: Err20 No drainage
remove the hose from the outlet and lay it as flat as poss into a bowl. fill the machine up and see how much water starts to run out. if there is a lot then there may be a blocked outlet instead. the way to attempt to clear a waste hose out without removing it is to buy a flexi unblocker (like a bendywound wire) from a handyman shop and ram it up the hose. tone.
Posted on Jun 11, 2007
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
SOURCE: drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Posted on Nov 22, 2008
I have a tumble dryer white knight 77aw and it makes a loud noise like a engine could u help
Hard to tell but from what you're describing sounds like bearings for the barrel.
Mar 17, 2015 | Dryers
White knight 77aw trips out after about 5 mins, smells quite hot
I have never seen one of these dryers but I would imagine the control thermostat is probably not working and the safety limit is tripping OR the vent is blocked causing excessive heat and tripping the safety. The filter might be blocked with lint. It supposed to be cleaned after every load.
Dec 05, 2012 | Dryers
I need a user manual for my White Knight Washer Drier
Try this PDF this seems to be for the 77AW by White Knight!
Jun 24, 2012 | Washing Machines
Our white knight 77aw tumble dryer is very noisy.....is there anything we can do to reduce it?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 26, 2011 | Dryers
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
Have just bought a new heater element for a CL432AV White Knight Duel Heat Tumble Drier it will not heat think I have wired it up wrong do not have a wiring diagram can you help.
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Feb 12, 2010 | Dryers
Yesterday the trip switch for the downstairs mains sockets tripped. When i reset it and plugged switched on my White Knight 44AW drier it span as usual but now there is no heat.
Jan 19, 2010 | Abbaka White Knight 44AW Electric Dryer
WHITE kNIGHT tUMBLE DRIER THAT STILL TUMBLES WITH NO HEAT
there is an overheat resettable stat on the back under a small red cover. try for a start pressing the centre of the red cover and you should hear a click and dryer will then heat. this is the most common fault - get back to me if somethinbg different
Sep 05, 2008 | Dryers
White knight 767 tumble drier
If the rug was very heavy you could have burnt up the motor. If it will restart after it cools off, replace the motor and clean out the vent system.
Good luck.
Dec 08, 2007 | Dryers
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
