Question about Stanton C-504 Dual Cd Player CD Player
Cd skiping when i am playing cd/cd-r the cd suddenly jumps back to the number 1 track what is th eproblem?
  • Bud Tugly Feb 10, 2009
    i have the same problem. In the middle of a song the player skips to song 1 and starts playing it. Only happens every once in a while.
  • 93 Answers
If the disc is clean, that could be some dirt on the laser head lenses.
Posted on Oct 04, 2007
SOURCE:
Pt cruiser cd player
hi.
go to this link and it should help you out.
cd player jumping and skipping tracks Google Search
Nov 02, 2017 | Cars & Trucks
Denon 2910 CD player malfunctions
is this happening with all the cds??
the case may be with the cd sometime..where the tracks wouldnt have been properly completed...
Jul 13, 2008 | Denon DVD-2900 DVD Player
Tascam cd-rw750 - while recording from another CD player (using digital coax connection), machine records for some time and then just "jumps out of record mode" and goes back to the beginning like nothing...
1. First problem: "like nothing is recorded". IS something recorded or has it been left in Pause Mode so long (instead of Recording) that it just got impatient and time out?
2. Get yourself a couple of CD-RW Digital Audio discs to play with until you're past this learning curve/problem scenario. That way you can always erase them and start over without having to discard the disc.
3. Dropouts on playback. Are they repeatable - always at the same place, even on different CD players? If so, the data is bad on the disc. If not, the data is probably marginal.
4. If you have a DVD player, try to play the failed recordings in it. Some DVD players can play back unfinalized CDR's. You may be able to recover the data by copying it back to the CD Recorder from the DVD player. Just be advised that an unfinalized CD-RW may not have 'silence' following the last recorded track due to old data remaining from a previous session, so be ready to pause or stop the recorder when the last track finishes.
5. "Scratches near the outside of the CD". Were these NOT present prior to entering the CD Recorder? Do they seem to coincide with about where the recording may have failed?
6. 20 vs 19 tracks: Is this a constant problem or only when there is a failure during CD creation? If the latter, it would make sense as the last track in isn't technically completed.
Apr 09, 2010 | Tascam CD-RW750 CD Recorder
Used 200 cd player keeps skipping
I just fixed this using Scarthhouse's solution of removing the sensor assembly, cog, and squeezing the rack (of the rack and pinion) together (I squeezed the metal bar upwards). I'm not even electronically-inclined, so I'm ecstatic that this fixed the used 300 Sony disk player I just purchased.
Dec 30, 2009 | Sony CDP-CX250 CD Player
My tracks don't play in the recorded order, list I made them.....
If song tracks jump or skip then it is problem of cd player like optical laser is dirty / clogged,
and if track doesn't jump or restarts in middle of playing back then cd player is just fine,
Please check cd creator software settings.
Dec 18, 2008 | Sony CDX-MP40 CD Player
My AKAI has tracking problems
check the connectors, maybe it has a lose contact
check the player and the cd/dvd youre using.
Dec 10, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Cd jumps tracks
The CD lens may need cleaning.
Try a 'wet' CD lens cleaner.
The laser PU may be low emision.
Nov 09, 2007 | Emerson MS9700 CD Shelf System
you could try this http://www.fixya.com/support/t244156-denon_2910_cd_player_malfunctions or clean the lens
Nov 06, 2007 | Denon DVD-2900 DVD Player
Won't play any songs.
I had this problem with my player (th 1101) when I was transferring songs from iMesh. After awhile I found out that even though I could listen to the files on the computer some wouldn't go on the mp3 player. Looked it up and there is an encoding on some tracks (preimium tracks they call it) that unless you pay for them they won't transfer off the computer (CD, MP3 players ect.). They also had free tracks that works just fine. Hope that helps
Nov 02, 2007 | RCA TH1101 MP3 Player
Stanton C-504 Dual Cd Player CD Player Logo
109 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Anthony
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
