Question about Transmission & Drivetrain for Ford Transit Connect
2003 Crown Vic drops to 1st gear instead of shifting into 3rd
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 44 Answers
Run diagnostic or replace transmission computer sounds like tranny computer or shifter module on transmission
Posted on Jun 27, 2014
3 Suggested Answers
whammy45
  • 84 Answers
SOURCE: 2000 crown vic no forward gears
If you have a crown Vic..then it is a rear wheel drive vehicle...If the car will operate in reverse but won't engage any forward gears..sounds like you may have a problems with the bands in the transmission need adjusting, and the car is no moving because of lack of friction in the forward gears.You may want to see an honest mechanic about this problem to get a sure diagnosis.....thank you....
Posted on Dec 13, 2011
smtransmissi
  • 100 Answers
SOURCE: 2003 crown vic when shifting from 2nd to 3rd it
If the computer is commanding 3rd, and it's not going into 3rd, then there may be an internal trans problem. Are there any codes (usually a check eng light will come on)? It could be helpful in diagnosis.
Posted on Oct 14, 2013
2000 yz250 shift to bottom (neutral) won't drop into 1st
check your shifting drum.may have left a pin out of the shifting drum.
Apr 01, 2014 | 2003 Yamaha YZ 250
2003 crown vic when shifting from 2nd to 3rd it drops back down in low
Oct 14, 2013 | Transmission & Drivetrain for Ford Transit...
Selecting 3rd gear
Do you mean you can\'t find 3rd gear or it won\'t shift into 3rd gear? If you can\'t find 3rd gear, shift all the way down to neutral, then shift up 2 clicks. On my Suzuki Boulevard S-50 (VS-800) the shift order is 1st gear down, then up for neutral, 2nd, 3rd, 4th, and 5th. Your crotch rocket probably also has a 6th. If the problem is that it won\'t shift into 3rd, then you had best take it to the shop as it is not readily repairable without specialized tools and knowledge.
Oct 02, 2013 | 2003 Suzuki GSX-R 600
98 crown vic transmission slipping
Change the filter and fluid. This car if the transmission is original should have a torque converter drain. Drain the torque converter also,it gets almost all the fluid out of the transmission. Doing this the car will require almost 12 quarts of fluid. Worth a shot. I change mine at 25000 mile intervals.
Oct 31, 2012 | 1998 Ford Crown Victoria
Why my 2007 crown Vic won't shift in gear
this can be due to out of adjutment of shifter cable which releases the shifter when brake is pressed.
Nov 18, 2011 | 2007 Ford Crown Victoria LX Sedan
Transmission jerks on 1985 Crown Vic when cold. Doesn't want to shift, and transmission jerks violently when cold. Also, automatic transmission doesn't like to shift into 3rd gear, unless you exceed 45...
Unless you are low on fluid, I suspect you are in need of a rebuild. I have had similar problems before. Any shop will tell you to try a fluid and filter change. It has never brought one of mine back. I would suggest adding fluid to the top of the 'add fluid' area of the dipstick and no more. It can foam if it is to full, causing similar problems as being to low. I would add that if you have to replace the transmission - you need to consider that the car may not be worth the cost.
Good Luck.
Nov 25, 2010 | 1985 Ford Crown Victoria
1985 Ford Crown Vic won't shift sometimes. Seems
Have he transmission drained and the screens cleaned
Jun 05, 2009 | 1995 Ford Crown Victoria
1995 crown vic gear problems/gear shift wont lock
most likely the shift tube bushings are bad- you may have also lost a few screws in the shift tube or they could just be loose. you have to pull the steernig column down to inspect/repair it.
May 30, 2009 | 1995 Ford Crown Victoria
Transmission & Drivetrain for Ford Transit Connect Logo
54 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
