Question about Xerox ColorQube 9201 9202 9203 Cleaning Unit 108R00841
Get an error 94-622 on a colorqube 9203 - Xerox ColorQube 9201 9202 9203 Cleaning Unit 108R00841
What causes error code 091-720 on a xerox colorqube 8900x printer?
That error signifies a printhead tilt fault. You need to replace the process drive camshaft kit, part number 8900-Z1.
http://www.iteminconline.com/8900-z1_8900-z1-xerox-8900-process-drive-camshaft-kit.htm
Feb 29, 2016 | Xerox ColorQube 8900X Multifunction Color...
What is Xerox 8570 ColorQube error 93 984.00:3683
93,984 means: Cyan obstructed, reservoir not filled
• Check for ink spills around the Printhead.
• Check the Ink Loader for bent melt tips.
• Check the Ink Loader power cable misrouting around melt tips.
• Check height of ink levels in the head reservoir.
Mar 15, 2015 | Xerox Office Equipment & Supplies
Xerox problems
Hi Anonymous,
I suspect your question has answer by now.
If not, just visit the www.xerox.com website.
Regards.
Jul 29, 2014 | Xerox STANDARD CAPACITY MAINTENANCE KIT...
What does error code 093-547 on a Xerox ColorQube 9301 mean?
Interesting. Recommend reading and trying the software from Microsoft. http://www.saetechnologies.com/colorqube-error-code-093-547/
Jul 17, 2014 | Xerox Office Equipment & Supplies
How to solve streaks in printout
If you have tried running the "eliminate light stripes" process in the troubleshoot print quality without success, you may want to look at the print quality sheet and do "jet substitution" on the ink nozzle numbers that aren't printing out. That will slightly slow down the printing, but will eliminate white streaks down your prints.
May 04, 2014 | Xerox Office Equipment & Supplies
Our Colorqueb 9303 have the error 093-545, how can we solve it? Thank you
I think you better get in touch with Xerox ASAP.
Sorry this problem is beyond the scope of questions and answers like these.
Good Luck.
Mar 12, 2014 | Xerox Corporation ColorQube CQ9303 9303/P...
Xerox error code 093-559
On the ColorQube 9201 and 9300, this error says "Head 3 cyan reservoir did not fill within the correct time." This a difficult machine to service so you shouldn't start without full documentation and experience.
This code may require one of a dozen parts, most of which are expensive and challenging to install.
Good luck ...Whit at www.iteminconline.com
Sep 03, 2013 | Xerox ColorQube 9201 9202 9203 Cleaning...
Xerox ColorQube 9201 error code 093-559
The ColorQube is a big $20K machine that is rather difficult to repair. Hiring a professional is the best practice. Even so, being informed will assist your discussions with the technician.
This error tells us that a Cyan reservoir isn't filling up. There are many suspects, probably Purge Line, Ink Reservoir, or Printhead. If you want to repair it on your own, you will need a service manual, and tech support.
Whit
Item, Inc.
What does error code 91,721.00:1039 on Xerox ColorQube 8570 mean
The error is a printhead tilt fault. It's unable to tilt on the axis, caused by a fault camshaft and process motor. The part you need to fix it is 8570-Z1.
http://www.iteminconline.com/8570-z1_8570-z1-xerox-colorqube-8570-8580-8700-process-drive-camshaft-kit-includes-process-drive-motor-drum-maintenance-camshaft-transfix-camshaft.htm
Aug 13, 2012 | Xerox Office Equipment & Supplies
Xerox ColorQube 9201 9202 9203 Cleaning Unit 108R00841 Logo
297 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
