Question about Maytag Bravos MTW6600T Top Load Washer
How do i remove top of washer to look at suspension mtw6600tbo
How do I remove top on (mtw6600tbo)maytag washer to inspect for unbalance problem?
huuum
  • 750 Answers
SOURCE: How to remove body on top load maytag washer to inspect & lube
hello welcome to fixya.
below is the site with schematics. to your machine. Just click on your choice of schematic on the left side and you can open them into the full window too!
And buy parts here
http://www.pcappliancerepair.com/model-display.php
Please remember to leave a solved rating before you sign out!
Thank You Huuum
Posted on Jan 23, 2009
Maytag317
  • 1136 Answers
SOURCE: Top loading maytag washer leaking water during wash cycle
Hi, There are two spring clips located in the gap between the top and front panel. They are the edges.
If the pump and hoses aare ok, fill the washer with water and look up toward the center of the tub abd transmission area. It migth have a seal going bad.
I hope this helps.
Vic
Posted on May 30, 2009
  • 2180 Answers
SOURCE: REMOVAL OF TOP AGITATOR ON MAYTAG WASHER
i believe all you have to do is put you fingers underneath it grab the sides and pull up,that will remove the whole agitator,if you want to change the dogs,pop off the top fabric softener dispenser and take out the 7/16 bolt and remove middle section,change your parts and put it back the same way you took it apart
Posted on Nov 03, 2009
Testimonial: "Super fast and accurate info. Thanks so very much."
TheMobilian
  • 8220 Answers
SOURCE: i have an error code
Error codes are given whenever the washer has a problem. Could be overuse of soap to overloaded clothes. Who knows? You ain't said what the error code is. Their are several styles of these machines. The Oasis, the Bravos, and the Cabrio are all tailored after the Fisher and Paykel washers. I have written a tip which features the error codes HERE
Posted on Jun 30, 2011
ginko
  • 19396 Answers
SOURCE: Maytag top-load washer Mod.MTW6600TBO Push to
Hi.
To find the tech sheet you need to remove the top. The top is held by two clips that can be removed using a putty knife.
Regarding the error code F1 means Pressure Signal Out-Of-Range. Some forum incorrectly says that F1 means defective control board. Even if F1 may be caused by defective control its meaning according to service literature is: "F then 1 flashes when the control detects an out of range pressure signal."
Unfortunately the error sometimes occur when control board is faulty. Other times means that there is a clogged pressure hose. In some case the error is caused by use of incorrect detergent that clogs the pressure hose.
• Check pressure hose connection from tub to machine/motor control. Is hose pinched or kinked?
• If F then 1 repeats numerous times after POWER is pressed and the pressure hose connection is not pinched or kinked, replace the machine/motor control.
Here the service manual.
Regards.
Ginko
Posted on Aug 21, 2011
How do you remove the cover for Cabrio Platinum Top Load Washer to see if clothes have gotten stuck between wall & basket of washer. I can not wash one load without getting the UL Off Balance Code!
it is extremely unlikely that clothes have got to the position you mentioned
unbalance comes from
1--- clothes out of balance in the tub--too much on one side
2--machine not level on the floor --- rubber feet missing from adjuster bolts
3-- suspension rods and insulators for the tub broken or missing
these suspension rubbers/ plastics break on a regular basis and allow the tub to sit at an unlevel state causing an unbalance situation when spinning
top covers are either held in place with screws at the front and back ( under plastic trim buttons ) or simply clip on to the side walls at the top
talk with a service agent as to how to remove the top or download a workshop manual for the machine from the net
Oct 29, 2016 | Whirlpool WTW6400SW Cabrio Washer
Maytag bravos top loading washer; LD error and all lights blinking. It seems to be draining now after I turned off and tried rinse only
Why is my Maytag Bravo washer Model #MTW6600TBO ...
www.shopyourway.com > Manage My Life > Questions
May 12, 2010 - LD error please check for the following: Check for kinked or clogged Drain Hose: ... Bravos® Top Load Washer w/ PowerWash® System.
Aug 08, 2015 | Maytag Washing Machines
We just moved and the house came with a Maytag Neptune TL which won't spin if there are clothes in the cylinder. It will spin empty. Please help! Thanks.
Washer bangs around in spin cycle and throws a DC or UC unballance code with cloths in the wash basket is that correct?
If so it's a Clutch issue.
If you want read more about what I feel is your issue read this post Maytag Neptune load unbalance
Sep 08, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Model fav6800aww drains during the wash and rinse cycle but does not drain during the spin cycle. it give an dc code during the spin cycle which i know that means unbalance but what does that have to do...
Clutch issue and possible time for a tub seal replacement
Google this for a post that covers the Clutch removal and inspection/repair;
""Neptune TL Washer FAV6800AWW"" you will find the Service Manual in post 5 of that sticky.
Google this for Outer Tub bearing rebuild;""
FAV6800A/FAV9800A Outer Tub bearing replacement""
Aug 20, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have an error code on maytag washer model # mtw6600tbo what does code mean
Jun 30, 2011 | Maytag Washing Machines
Maytag FAV6800AW won't spin. COuld this be the
Hello leaweber,
Yes most times it is a Clutch malfunction . Is the machine failing with “dc” and or “UC” unbalance error codes in spin cycle? If you are you may have a Clutch malfunction or Tub Displacement Sensor failure more likely a Clutch issue.
You can do a quick TDS sensor check thru the lid just follow this from the Service Manual. If you machine will pass the TDS check the next step would be to remove the clutch from the machine and inspect as I describe in this post.
Tub Displacement Sensor check from the SM slightly modified;
Tub Displacement Sensor Diagnostics check. This test is done with the washer lid raised see page 19 for the details.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
If you get these results your TDS sensor should be just fine. Time to look at a clutch repair/replacement. Let me know if you need help…. Rich aka dh1200s
Nov 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer becomes unbalances on heavy loads already replaced springs
I have same issue... My model i s FAV6800AWW. Failure Code is dC and uC for unbalance. I had replaced the clutch assembly 4 months ago (dyi) due to no spin.. it worked fine until now, where the unbalance issue is happening. For this issue, I have self tested the displacement sensor and it worked fine... I saw that on another forum that struts may have been issue.. so, I replaced the front struts. The back of the tub is hooked in by two suspension rods. The washer is leveled.. The tub spins/works when there is NO clothes in the tub... Only when I add any clothes, the tub starts to spin wildly until the displacement sensor kicks in and/or retrys or shuts things down... what's left to do??
Oct 26, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Not happy with Maytag Neptune TL Washer
I assume you are taking dc/UC errors to the console. This is a classic problem with the FAV6800AW/FAV9800AW after the 3yr to 5 yr mark. I own the machine and decided to learn what was involved to repair the machine. Take a look at this post and see if will give you some insight to a DIY fix to resolve the unbalance errors. No fix for the tumbler action of twisting up the clothes. After a re-lube of the one-way roller clutch bearing I could wash a single pair of socks or over load the wash basket with bath towels and extra water in the tub with no unbalance errors (dc/UC).
Shout back if you have any questions.
Here is a quick test for the TSD sensor but I believe you have a clutch issue. The TDS test is in the SM I’ve typed it out if you want to give a quick check. I’m sure you will pass and find the one-way roller clutch berings are dry/rusted and causing the dc/UC unbalance condition.
3.0 Tub Displacement Sensor Diagnostics check.
3a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
3b. Press the Super Wash key display reads “in”…something like that.
3c. Press Delicates the Display will show “UC” (Unbalance Closed).
3d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
3e. Press Hand Wash.
3f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). If you get these results your Tub Displacement sensor should be OK and I believe it’s not the component failure producing dc/UC errors in spin cycle. I would remove the clutch for inspection and re-lube or replace if necessary. There is a more technical troubleshooting method to check Tub Displacement Sensor in the Troubleshooting guide and Service manual.
Jun 26, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL 6800 dc code
Hello ldrpc
Take a look at the Service Manual page 42. I have to leave for work in a few minutes. I can attach a pic of mine later today if you need. Are you throwing dc/UC errors did you do this check?
1. Tub Displacement Sensor Diagnostics check.
It is possible the Tub Displacement Sensor may have failed try this check which is the Troubleshooting guide stored in your washer console or refer to the SM.
3f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). If you receive these results your Tub Displacement sensor should be OK and I believe it’s not the component failure producing dc/UC errors in spin cycle. I would remove the clutch for inspection and re-lube. There is a more technical troubleshooting method to check Tub Displacement Sensor in the Troubleshooting guide and Service manual. Rich
Mar 20, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
32 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
