Question about Dishwashers
Bosch Ascenta SHX3AR55UC/08 I interrupted the cycle and now it won't reset. Some standing water in the bottom that isn't completely draining. Have tried to reset, tried different cycles, switching off power source. It is only running a very short cycle (+/-2 mins). We just had a garborator installed
  • 1462 Answers
SOURCE: Bosch 24 in. SGS43C12 Classixx Free-Standing
if no drain, then no cycle. problem is probably that draining is not taking place. check the following: if plumbed in under the sink, remove drain hose from spigot and check no blockage. start any program - all programs start with drain. listen carefully for a low humming noise. if you hear this, it means you have something stuck in the pump impellor - bit of bone, cocktail stick etc. get back to me if you like with what you find
Posted on Jun 27, 2007
aborcass
  • 2651 Answers
SOURCE: dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
  • 1462 Answers
SOURCE: Bosch dishwasher is stuck on drain cycle
cause is water in the bottom tray which operates an anti-flood switch and all machine will do is drain.
disconnect from mains
remove bottom panel and mop out water and it will work. if fault re-occurs, then you have a leak which you will have to identify
Posted on Oct 20, 2008
rylee_smith
  • 8619 Answers
SOURCE: Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Posted on Feb 13, 2009
  • 218 Answers
SOURCE: Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Posted on Jul 03, 2009
How can I reset our dishwasher
Open the dishwasher door sufficiently to see the control buttons, then hold the two buttons with labels "Cancel Drain" and press for 3 seconds.
Close the door. Wait nearly 1 minute for the dishwasher to complete the cycle.
Open the door and hold the "ON/OFF" toggle.
Reset Bosch Ascenta Dishwashers
Shut off the child lock if needed by pressing and holding "Open the door far enough to see the keys, then hold the "START RESET" toggle until the "ACTIVE" LED become extinguished. On the SHE5AM model of Bosch Dishwashers, hold the "START RESET" key until the display clock shows "0:01".
Close the door and rest about 60 seconds. On the SHE5AM, wait until the display clock displays "0:00".
Apr 06, 2016 | Bosch SHE4AP06UC Dishwasher
DISHWASHER WON'T DRAIN ANLY HAD IT FOR 6 MONTHS. CLEANED FILTER. DID NOT HELP. WHAT TO DO?
Hi, if its still under warranty you should call bosch and get them to arrange a service engineer to come out and check it for a fault.
Jan 15, 2016 | Bosch Dishwashers
Need a Service Repair manual Bosch Ascenta she3ar56uc
You can get one here:
https://www.manualowl.com/p/Bosch/SHE3AR56UC/Manual/117427
Sep 22, 2015 | Bosch Washing Machines
Bosch dishwasher door pops open during cycle
Latch needs adjustment or replacement.
Jul 07, 2015 | Bosch Dishwashers
My bosch dishwasher is stuck on a cycle, it keeps on flashing and won't start
try shutting off the power at the breaker panel and wait a minute sometimes rebooting will clear up a problem
Oct 27, 2014 | Bosch SHE6AP15UC Ascenta Evolution Series...
Where is the thermal fuse
Go to Utube and copy and paste this in : Bosch dishwasher thermal fuse replacement location . You will be able to fix it yourself with the videos .
Here is the link :
https://www.youtube.com/results?search_query=Bosch+dishwasher+thermal++fuse+replacement+location
Hope this helps , Grant
Aug 11, 2014 | Bosch SHE3AR75UC Ascenta Series 50 dBA 62...
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Dishwashers Logo
112 people viewed this question
Top Dishwashers Experts
