Question about Kodak HERO 5.1 All-in-One Printer 1326479
Kodak Hero 5.1 Printer just stopped working and is now dead!!!
Can I change the print font on a Kodak hero7.1
KODAK HERO 7.1 All-in-One Printer - Extended User Guide
support.en.kodak.com/.../kodak-hero-7.1-all-in-one-prin...
Eastman KodakUnited States [ Change ]. Consumer Products ... KODAK HERO 7.1 All-in-One Printer- Extended User Guide. Published 08/31/2011 12:06 PM ' Updated ...
Sep 26, 2015 | Kodak Office Equipment & Supplies
Tip
Reset memory on Ink supply for Kodak printers through computer maintenance
Communicating with computer
1 With printer on, remove cartridges.
2 Turn printer off for 5 sec's./then back on
3 Double click Kodak printer icon, go to maintenance
4 From the menu, select Ink level. It will warn there are no cartraiges. Press OK
(At this point the memory has been reset)
5 Replace your cartridges and power off printer again for 5 sec's./Turn back on.
ironically, this does NOT work on my Office Hero 6.1
on Nov 17, 2015 | Kodak Office Equipment & Supplies
Poor print quality
KODAK HERO 7.1 All-in-One Printer - Extended User Guide, you can try to find answer in their site, their support will help you
Apr 17, 2015 | Kodak Hero 7.1 Wireless All-in-One Printer
When I clicked as always "Print" it showed me in the window "Printer" the "Microsoft XPS Writer" instead of my set up Kodak Hero 9.1. Please HELP!!!
Hi there
This can happen. Go to Control Panel > Devices and Printers.
Here you should see a hardware list of icons, including both your Kodak Hero and the XPS Writer. If the Kodak Hero is not there you will need to re-install the drivers and software from the disk which came with the printer. However, if it is there all you need to do is right click on the Kodak icon and from the menu that comes up click on "Set as default" and a green arrow should appear against the icon like this showing that the Kodak is the default printer and will show up first in any programme from which you print. 25277964-2fs4ue52shjy2lvm2lcqhtal-4-2.jpg
Cheers
Nov 10, 2014 | Office Equipment & Supplies
Why instead of my Kodak Hero 9.1 printer appears the Microsoft XPS Writer when I'm trying to print the document online?
go in to device and printers and change default back to ur printer. probs office or some other sw hijacked printers default setting
Nov 10, 2014 | Kodak Hero 9. Inkjet Multifunction Printer...
How to remove print head on a Kodak ESP 5250
If the ink cartridges and printhead are already in the printer, remove them, then reinstall them.
  1. Remove the color and black ink cartridges.
  2. Remove the existing printhead by lifting the latch in the center of the carriage. printhead_removal.jpg p342_0064aa.jpg ESP 3, 5, 7, 9, 3250, 5250, 5210,
    ESP Office 6150, 7250, 9250;
    HERO 7.1, 9.1, OFFICE HERO 6.1 ESP 1.2, 3.2, 3.2s, C110, C310, C315,
    ESP Office 2150, 2170;
    HERO 3.1, 5.1
  3. Close the printer access door.
Oct 21, 2014 | Office Equipment & Supplies
My kodak hero 4.2 won't power up?
Hello, First check to see that the power plug has power. If it does then make sure the power cord and seated correctly into the back of the printer. Reseat the power cord and try the power switch. If that doesn't work, will have too replace the power cord. If that doesn't fix will have to take in for repair or call kodak tech support with model and serial number and walk thru trouble shooting.
May 17, 2014 | Kodak ESP 5 Printer
Printer is offline and wont print
Press Home, Network settings, wifi settings,then choose your wireless network within range. click your netwrok name and enter your security key..when the confirmation message appears, click ok, make sure that your kodak hero wireless printer software are installed on your computer.
click start menu,printers and faxes,right click your kodak wireless printer and set as default.
Aug 10, 2013 | Kodak Hero 9.1 Wireless Color Printer
Clearing Code 3527 from Kodak Hero 9.1
Hi friends,
I was able to solve this problem (error code 3527 on Kodak hero 9.1) by opening the printer entirely (dis-assembled), Checking the cartridge carriage assembly, i discovered that the belt that drive carriage assembly had a locker that was broken as such, the carriage assembly could not move in the direction as the motor drives the belt on.
I simply inserted the belt in position and drop a little drop of super glue to it, let it dry off.
Assemble my printer, and it was ok and is working.
Aug 01, 2012 | Kodak HERO 9.1 All-in-One Printer with...
Kodak HERO 5.1 All-in-One Printer 1326479 Logo
44 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
