Question about Vtech Lands Phones
Is there a way to setup call blocking the cs6719-2
Why is facebook blocked by netgear
Assuming your router is a netgear. Many routers can be setup to do keyword blocking, in this case Facebook. So whoever setup said router you are connected to has put a block on Facebook.
Comment back if you need more help
Sep 10, 2011 | Computers & Internet
I want block 2 site so plz send mail.
You need to access the Setup page of Dlink DIR 300 wireless router:
1. Use a working computer that is hard wired to the router.
2. Open a Web Browser (IE, Firefox etc.) on the computer.
3. In the address bar of the browser type http://192.168.0.1 and press Enter.
4. When the login window appears, set the user name to admin and leave the password box empty. Click OK to continue.
(Note: If you setup your own Usename and Password on your router please use those info to login instead of using the default)
You will then see the Setup page of the router.
5. CLick on the ADVANCED tab.
6. On the left side of the screen Click on Parental Control.
7. On the "Configure Parental Control below: " select the option "Turn Parental Control ON and DENY computers access to ONLY these sites".
8. ON the "Website URL" tyoe in the website that you want to block
9. Click on the Save settings button.
Once completed then the sites you entered are completely denied and blocked on your router.
Feb 11, 2011 | D-Link DIR-300 Wireless Router
My web cam is not attach my pc so what i do cam no vfo 330
Follow these steps :
•1
Get your webcam.
•2
Now Connect USB via Webcam.Then via PC.
•3
Now you will then have a setup popup so if you have a popup block un block it now and restart your computer.
•4
When computer it restarted you will do the setup. If the setup doesn't come up then check the connection and restart computer
•5
Then when setup is completed then make sure your web cam is up on your computer very stedy.Then do a test before you do a conversation. This is usually to see if you would need any extra lighting or not.
•6
Now enjoy webcam.I would recommend to keep your web cam connected so you wouldn't have to go though this again but if you cant then just reconnect and usually you would be ok.
Sep 25, 2010 | Creative Labs WebCam Live!
I have a tally 2250 dmp. The setup is blocked. How to unblock the setup options
simple, power on the printer with pressing onine button, then it will unlock the setup button.
Aug 10, 2010 | Tally T2250 Matrix Printer
I have a dual carb manifold setup with the number
You can tell by the intake ports. If there's 2 close in the middle then it's for a small block chevy. If they're evenly spaced then more than likely it's for a big block.
Mar 17, 2010 | 1984 Chevrolet Chevy
How can i block a junk fax number in a hp j3640 thanks in advance
Set the junk fax mode
By default, Block Junk Fax mode is turned On . If you do not subscribe to a caller ID service through your phone provider, or do not want to use this feature, you can turn off this setting.
To set the junk fax mode
Press Setup .
Press the right arrow to select Basic Fax Setup , and then press OK .
Press the right arrow to select Junk Fax Blocker Set Up .
Press the right arrow to select Block Junk Fax the press OK .
When prompted, press 1 for Yes or 2 for No .
Add numbers to the junk fax list
There are two ways to add a number to your junk list. You can select numbers from your caller ID history, or you can enter new numbers. The numbers in your junk list will be blocked if Block Junk Fax mode is set to On .
To select a number from the caller ID list
Press Setup .
Press the right arrow to select Basic Fax Setup then press OK .
Press the right arrow to select Add Number to Junk List , and then press the right arrow to select Number and then press OK .
Press the right arrow to scroll through the numbers from which you have received faxes. When the number you want to block appears, press OK to select it.
When the Select Another? prompt displays, do one of the following:
If you want to add another number to the list of junk fax numbers , press 1 to select Yes , and then repeat step 4 for each number you want to block.
If you are done , press 2 to select No .
To manually enter a number to block
Press Setup .
Press the right arrow to select Basic Fax Setup press OK .
Then press the right arrow to select Junk Fax Blocker Set Up and then press OK .
Press the right arrow to select Add Number to Junk List press OK , and then press the right arrow to select Enter Number .
Use the keypad to enter a fax number to block and then press OK . Make sure you enter the fax number as it appears on the display, and not the fax number that appears on the fax header of the received fax, as these numbers can be different.
When the Enter Another? prompt displays, do one of the following:
Remove numbers from the junk fax list
If you no longer want to block a fax number that number can be removed from the junk fax list.
To remove numbers from the junk fax list
Press Setup .
Press the right arrow to select Basic Fax Setup then press OK , and then press the right arrow again to select Junk Fax Blocker Set Up then press OK .
Press the right arrow to select Remove Number from Junk List .
Press the right arrow to scroll through the blocked numbers. When the number you want to remove displays, press OK to select it.
When the Delete Another? prompt displays, do one of the following:
If you want to remove another number from the list of junk fax numbers , press 1 to select Yes , and then repeat step 4 for each number you want to block.
If you subscribe to a caller ID service through your phone provider, you can block specific fax numbers, so the HP Fax does not print faxes received from those numbers in the future. When an incoming fax call is received, the HP Fax compares the number to the list of junk fax numbers you set up to determine if the call should be blocked. If the number matches a number in the blocked fax numbers list, the fax is not printed. (The maximum number of fax numbers you can block varies by model.)
Thank you.
Sep 17, 2009 | HP J3680 Officejet All In One Printer
Can't recieved fax faxs are blocks
Are you sure they are blocked? I think that someone has possibly set to "manually receive" faxes instead of "automatically receiving " faxes.
Press the Setup button, select Basic Fax Setup and go thru your configuration to make sure it is set up correctly. If you don't have a copy of the user manual, use this link to download it...
http://h10032.www1.hp.com/ctg/Manual/c01669504.pdf
Aug 13, 2009 | HP Officejet 6500 Wireless All-in-One...
Electrical plug is not attatched
3 wire setup, middle wire goes on the middle of terminal block,and one wire each on each side of it,4 wire setup white wire goes to middle of terminal block ,red and black goes to does not matter which side(both 120 volts) goes on each side of block,the green wire gets mounted to the cabinet,it is the extra ground-mike
Mar 09, 2009 | Kenmore Dryers
Disable Block WAN
You will see on the setup page of the router under the Security tab. Do you know how to access the setup page of the router?
Jul 02, 2008 | Linksys Wireless-G WRT54G Router
Lands Phones Logo
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
